    IMX385 on Jetson Xavier NX JetPack5.01DP can't find camera
    25 Posts 2 Posters 9.7k Views 1 Watching
    • M Offline
      maponarooo
      Hello~
      I have done as following manual.
      But can't find camera.
      What is the matter?
      ls /sys/bus/i2c/drivers/
      bd9571mwv ir-kbd-i2c max_gmsl_dp_ser rk808 tps65132
      bq27xxx-battery lp855x nvvrs_pseq rohm-bd718x7 veye_imx335
      dummy max77620 pca953x sec_pmic
      imx390 max9295 pca954x tegra_edid
      ina3221 max9296 'PEX9749 thermal sensor' tmpm32xi2c
      $ sudo ls /proc/device-tree/cam_i2cmux/i2c@*
      [sudo] password for quad:
      '#address-cells' name phandle rbpcv2_veyeimx335_a@3b reg '#size-cells'
      '#address-cells' name phandle rbpcv2_veyeimx335_c@3b reg '#size-cells'
      quad@quad-nx:~$ dmesg | grep veye
      [ 26.342849] veye_imx335: loading out-of-tree module taints kernel.
      [ 26.343769] veye_imx335 9-003b: probing v4l2 sensor
      [ 26.344068] veye_imx335 9-003b: tegracam sensor driver:veyecam_v2.0.6
      [ 26.403074] veye_imx335 9-003b: probe failed
      [ 26.403213] veye_imx335 9-003b: board setup failed
      [ 26.403519] veye_imx335 10-003b: probing v4l2 sensor
      [ 26.403737] veye_imx335 10-003b: tegracam sensor driver:veyecam_v2.0.6
      [ 26.462606] veye_imx335 10-003b: veyecam_identify_module: invalid sensor model id: 117217536
      [ 26.462826] veye_imx335 10-003b: board setup failed
      ls /dev/video*
      ls: cannot access '/dev/video*': No such file or directory
        veye_xumm @maponarooo
        @maponarooo
        Which camera do you use indeed?
        IMX385 or IMX335? Plese use the correct dtb.
        • M Offline
          maponarooo @veye_xumm
          @veye_xumm These are Xavier NX dtbs. Which one is IMX385 dtb?
          quad@quad-nx:~/QIDS/nvidia_jetson_veye_bsp/dtbs/Xavier-NX/JetPack_5.0.1_DP_Linux_JETSON_XAVIER_NX_TARGETS/dts dtb$ ls
          common CS-MIPI-SC132 VEYE-MIPI-CAM2M
          CS-MIPI-IMX307 CS-MIPI-SC132-fpdlink VEYE-MIPI-CAM2M-fpdlink
          CS-MIPI-IMX307-fpdlink MV-MIPI-CAM VEYE-MIPI-IMX335
          $ find . -name tegra194-p3668-0000-p3509-0000.dtb
          ./dtbs/Xavier-NX/JetPack_5.0.1_DP_Linux_JETSON_XAVIER_NX_TARGETS/dts dtb/CS-MIPI-SC132/tegra194-p3668-0000-p3509-0000.dtb
          ./dtbs/Xavier-NX/JetPack_5.0.1_DP_Linux_JETSON_XAVIER_NX_TARGETS/dts dtb/VEYE-MIPI-CAM2M-fpdlink/tegra194-p3668-0000-p3509-0000.dtb
          ./dtbs/Xavier-NX/JetPack_5.0.1_DP_Linux_JETSON_XAVIER_NX_TARGETS/dts dtb/VEYE-MIPI-CAM2M/tegra194-p3668-0000-p3509-0000.dtb
          ./dtbs/Xavier-NX/JetPack_5.0.1_DP_Linux_JETSON_XAVIER_NX_TARGETS/dts dtb/MV-MIPI-CAM/tegra194-p3668-0000-p3509-0000.dtb
          ./dtbs/Xavier-NX/JetPack_5.0.1_DP_Linux_JETSON_XAVIER_NX_TARGETS/dts dtb/CS-MIPI-SC132-fpdlink/tegra194-p3668-0000-p3509-0000.dtb
          ./dtbs/Xavier-NX/JetPack_5.0.1_DP_Linux_JETSON_XAVIER_NX_TARGETS/dts dtb/CS-MIPI-IMX307/tegra194-p3668-0000-p3509-0000.dtb
          ./dtbs/Xavier-NX/JetPack_5.0.1_DP_Linux_JETSON_XAVIER_NX_TARGETS/dts dtb/VEYE-MIPI-IMX335/tegra194-p3668-0000-p3509-0000.dtb
          ./dtbs/Xavier-NX/JetPack_5.0.1_DP_Linux_JETSON_XAVIER_NX_TARGETS/dts dtb/CS-MIPI-IMX307-fpdlink/tegra194-p3668-0000-p3509-0000.dtb
            @maponarooo said in IMX385 on Jetson Xavier NX JetPack5.01DP can't find camera:
            VEYE-MIPI-CAM2M
            section 3.4
            • M Offline
              @veye_xumm Okay. but can't play camera. What's the matter?
              4.2.3 gstreamer examples on Jetpack5.x
              New clock: GstSystemClock
              Additional debug info:
              Buffer pool activation failed
              Waiting for EOS...
              Caught SIGSEGV
              #0 0x0000ffff9b480f08 in __GI___poll
              #1 0x0000ffff9b5aeb30 in () at /lib/aarch64-linux-gnu/libglib-2.0.so.0
              #2 0x0000ffff9b5aeef0 in g_main_loop_run ()
              #3 0x0000ffff9b751ac4 in gst_bus_poll
              #4 0x0000aaaae8aa4980 in event_loop
              #5 0x0000aaaae8aa38c8 in main (argc=<optimized out>, argv=<optimized out>)
              Spinning. Please run 'gdb gst-launch-1.0 3457' to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
                @maponarooo
                Sorry, I have not encountered this problem, this gstreamer command works just fine in our case.
                The 5.0.1DP version is unstable and has many bugs. NVIDIA should release a stable version soon, within a day or two, as far as I know.
                You can submit the problem to nvidia's forum, but I guess they won't give a solution and will make you wait for the next version. That's what I suggested.
                • M Offline
                  @veye_xumm Oh! No.............
                  I have already build my applications all on JetPack5.01DP.
                  Why this is so complicate?
                  I can't wait new version....
                  • M Offline
                    @veye_xumm And this log is right?
                    $ dmesg | grep veye
                    [ 26.415448] veyecam: loading out-of-tree module taints kernel.
                    [ 26.418410] veyecam 9-003b: probing v4l2 sensor
                    [ 26.418573] veyecam 9-003b: tegracam sensor driver:veyecam_v2.0.6
                    [ 26.430446] veyecam 9-003b: probe failed VEYECAM_MODEL_ID_ADDR
                    [ 26.431893] veyecam 9-003b: board setup failed
                    [ 26.433188] veyecam 10-003b: probing v4l2 sensor
                    [ 26.433346] veyecam 10-003b: tegracam sensor driver:veyecam_v2.0.6
                    [ 26.444597] veyecam 10-003b: camera id is veyecam
                    [ 26.450485] veyecam 10-003b: sensor is IMX385
                    [ 26.451703] veyecam 10-003b: board type is ONE board
                    [ 26.453870] tegra-camrtc-capture-vi tegra-capture-vi: subdev veyecam 10-003b bound
                    [ 26.458594] veyecam 10-003b: Detected VEYECAM sensor
                      Yes, the board have 2 mipi csi interface ,you connect just one camera.
                      • M Offline
                        @veye_xumm I have posted this matter at the nvidia forum site.
                        https://forums.developer.nvidia.com/t/xavier-nx-with-jetpack5-01dp-cant-play-veye-mipi-imx385-camera/223524
                        • M Offline
                          @veye_xumm By any chance, does the IMX385 camera firmware version matter?
                            I do not think so.
                            • M Offline
                              @veye_xumm NVIDIA has replied, but I don't know the meaning...
                              Pls explain what they say...
                              **Please collect the trace log to check.
                              Also be aware below for r35 release.
                              Skew calibration is required if sensor or deserializer is using DPHY, and the output data rate is > 1.5Gbps.
                              An initiation deskew signal should be sent by sensor or deserializer to perform the skew calibration. If the deskew signals is not sent, the receiver will stall, and the capture will time out.
                              You can calculate the output data rate with the following equation:**
                              https://elinux.org/Jetson/l4t/Camera_BringUp
                                @maponarooo
                                • M Offline
                                    @maponarooo
                                    • M Offline
                                      alt text
                                      alt text
                                      Caught SIGSEGV
                                      Waiting for EOS...
                                      What do I do?
                                        @maponarooo
                                        Please try
                                        dmesg
                                        check if any errors.
                                        • M Offline
                                          What's the matter?
                                          $dmesg
                                          [ 22.356665] handlers:
                                            @maponarooo
