    ISP vs NOISP
    • P
      pimat last edited by pimat
      hola!
      I currently have a 327 no ISP version and I realize I can't get too much quality/light at night , no way closer to veye videos
      I'm using raspberry with libcamera, so if raspberry acts as an ISP, and you can control parameters like shutter, gain, denoise, I wonder what is the difference against the version with integrated ISP? are there other parameters that libcamera does not have access to and an ISP does?
      By other hand, My project is about capture video at 1920x1080@30fps and process it with openCV, Knowing this, is there any noticeable difference between 327 and 462? I don't know which one to buy
      My intention is to buy it on Aliexpress through the link you provide, I see there are several board versions in the wiki, can I be sure that I will receive the last version?
      Thanks!!
        veye_xumm @pimat last edited by veye_xumm
        @pimat
        In fact isp has a much greater impact on image quality than is generally believed.But I'm not familiar with libcamera, so I can't give you an in-depth explanation.
        The imx462 has better NIR band sensitivity than the imx327, and the price is about the same as the imx327, so I recommend the imx462.
        Newly purchased products will be the latest version.
        • P
          pimat @veye_xumm last edited by
          @veye_xumm Thank you so much for your reply, I understand both 327S/462 are same board, dimension, lens mount, driver and I can just interchange models without changing anything , is that correct?
            @pimat correct.
