IMX178M with Raspberry 3 and using trigger mode
Hi there! I need to capture a frame using the raspiOS 32-bit CLI. I did it with v4l2. For example:
v4l2-ctl --set-fmt-video=width=3088,height=2064,pixelformat=UYVY --stream-mmap --stream-count=1 --stream-to=grab-test-01.raw -d /dev/video0 -c trigger_mode=0 --verboseHow can I capture a frame with this key?
trigger_mode=1I tried to use
mv_mipi_i2c.sh -w -f trgone -p1 1but it didn't help me. Do you know other ways?
Thanks all for your help! I found a solution here:
http://wiki.veye.cc/index.php/Mv_series_camera_appnotes_4_rpi.
