    Taking images with different shutter settings i2c
    10 Posts 2 Posters 2.4k Views 1 Watching
    • S Offline
      Seka
      Hi there,
      I am trying to use the Starvis 327 RPI Mipi Camera with an RPI4B to take images with different illumination settings. For our use case, I need to change the shutter settings to adjust for different levels of light.
      I tried to enable the "capture mode" in order to change the shutter settings but always get a kernel error when trying to do so.
      Here is the script:
      from time import sleep
      from signal import pause
      import datetime
      import time
      import RPi.GPIO as GPIO
      import D_mipicamera as Dcam
      import os
      status = os.system('sh ./veye_mipi_i2c.sh -w -f videoformat -p1 PAL  -b 10')
      status = os.system('sh ./veye_mipi_i2c.sh -w -f cameramode -p1 0x1 -b 10')
      print status
      camera = Dcam.mipi_camera()
      camera.init_camera()
      #Folder CREATION
      #os.makedirs("/home/pi/testmipi")
      directory="/home/pi/testmipi/"
      directory
      sleep(2)
      date = datetime.datetime.now().strftime("%m_%d_%Y_%H_%M_%S")
      frame = camera.capture(encoding = 'jpeg')
      frame.as_array.tofile((directory)+"nm385"+ date + ".jpg")
      camera.release_buffer(frame)
      del frame
      time.sleep(1)
      print("Close camera...")
      camera.close_camera()
      GPIO.cleanup(Alled)
      The error I get is:
      An error ocurred while starting the kernel
      mmal: mmal_component_enable w 1920 h 1080
      It works in stream mode, but node in capture mode...
      But in stream mode it seams like i cannot change the shutter speed.
      • S Offline
        Seka @Seka
        These are the 2c settings:
        I2C Settings
        Devid: 0x6
        Hdver: 0x3
        Wdrmode: 0x0
        Videomode: frame rate reg 1, NTSC (60Hz)
        Mirrormode: 0x0
        Denoise: 0x5
        AGC: 0x c
        Lowlight: 0x 0
        Daynightmode: 0xfc
        Mshutter: 0x41
        Cameramode: 0x0
        Nodf: 0x0
        CAPTURE  ????
        Csienable 0x1
        Brightness: NTSC60 brightness is 0x20
        Agcspeed: agcspeed is 0x a shutter speed is 0x50
        Contrast: 0x80
        Saturation: 0x28
        Sharpen : enable is 0x1 cal is 0x3
        Wdrtargetbr: 0x30
        Boardmodel: no information
        I2cwen: no information
        I2cauxenable: no information
          veye_xumm @Seka
          @seka
          1. about capture mode:
          • http://wiki.veye.cc/index.php/VEYE-MIPI-290/327_i2c/#cameramode
            Caputre mode: output the next frame each capture cmd.
            You have to run the cmd below to get one picture.
          ./veye_mipi_i2c.sh -w -f capture -b 10
          • camera.capture(encoding = 'jpeg')
            This function do CAPTURE one frame from the MIPI csi-2 port.
          1. So I suggest add this cmd before capture a frame.
          • S Offline
            Seka @veye_xumm
            @veye_xumm and then change the shutter with mshutter or with lowlight command?
            S veye_xummV 2 Replies Last reply Reply Quote 0
            • S Offline
              Seka @Seka
              @seka Sometimes I have the impression that the frame I get in the images is an old one. Can there be a problem with having "old" frames in the images?
                veye_xumm @Seka
                @seka
                mshutter is manual exposure time.
                  veye_xumm @Seka
                  @seka said in Taking images with different shutter settings i2c:
                  Could you add a little sleep between mshutter cmd and capture cmd?
                  • S Offline
                    Seka @veye_xumm
                    @veye_xumm OK, so accordin to your suggestion,
                    I now switched back to stream mode and discard one frame taken with the capture command before taking another one and saving it:
                    import os
                    status = os.system('sh ./veye_mipi_i2c.sh -w -f cameramode -p1 0x0 -b 10')
                    print status
                    status = os.system('sh ./veye_mipi_i2c.sh -w -f daynightmode -p1 0xFC -p1 0x00 -b 10')
                    #print status
                    ##turn off automatic exposure
                    status = os.system('sh ./veye_mipi_i2c.sh -w -f agc -p1 0 -b 10')
                    print status
                    ##turn off white balance
                    status = os.system('sh ./veye_mipi_i2c.sh -w -f wbmode -p1 0x1b -b 10')
                    print status
                    status = os.system('sh ./veye_mipi_i2c.sh -w -f lowlight -p1 0x09  -b 10')
                    print status
                    del frame
                    time.sleep(1)
                    frame.as_array.tofile((directory)+"nm590"+ date + ".jpg")
                    del frame
                    Now it is taking repeatedly and reliably the same images. That is good.
                    However, I feel like I am not in control of the shutter/ frame rate. I tried different framerate settings with *lowlight -p1 XX but nothing changed.
                    How can I change the exposure time now?
                    • S Offline
                      Seka @Seka
                      @seka Sorry, my bad, I can change the exposure now with the mshutter command.
                      THANK YOU for your help!
                        veye_xumm @Seka
                        @seka
                        It's really nice to know this. You are welcome.
