    VeYe IMX462 driver on Jetson Orin Nx 8G
    17 Posts 4 Posters 6.1k Views 1 Watching
    • V Offline
      Vincentng @john
      @john THanks for supporting to report the issue to SeeedStudio, I think we can do nothing but pray...
      @veye_xumm anything we can try to revise the I2C or CSI driver ?
        veye_xumm @Vincentng
        @vincentng @john
        @vincentng said in VeYe IMX462 driver on Jetson Orin Nx 8G:
        The current situation is that even i2cdetect cannot detect the VEYE camera properly, so I believe that adjusting the higher-level driver logic will not be useful.
        • V Offline
          Vincentng @veye_xumm
          @veye_xumm If that's the case, we can only give up J401 board from Seeed studio ? Or can you help to advise which carrier board with Orin NX 8GB can match veye IM462 camera ?
          J veye_xummV 2 Replies Last reply Reply Quote 0
          • J Offline
            john @Vincentng
            @vincentng We are close to giving up on the Seeed Orin Nano carrier board, and will try to return the units we bought.
            I have the same question for Orin Nano Carrier boards, do you have any advice on boards that do work with the Veye IMX462? (And that have the same dimensions, we don't have room in our device for something bigger).
              @vincentng
              I am very disappointed with Seeed's attitude towards handling our issue.
              They completely ignored our questions and have not responded to our emails or WeChat messages. The board below is one that we have collaborated on and debugged the driver together.
              http://www.plink-ai.com/cn/NVJetson.html
              • J Offline
                john @veye_xumm
                @veye_xumm Understood, and thanks for the Plink reference, which looks good. However, this has a larger format and would not fit in our unit.
                • J Offline
                  john @john
                  @veye_xumm It is good news that you are finally getting a response from Seeed Studio, but do you think the fault could be corrected by software or might it require a hardware redesign of the Seeed Carrier Board?
                  • H Offline
                    Howard @Vincentng
                    @vincentng We had the same problem with our 462 on the J202 with an Xavier NX Module. We ended up purchasing A206 boards and they worked fine. ReComputer uses a raspberry pi chip for power management on their carrier boards. I think it communicates over i2c I think. I think this is where the problem lies. We never dug into it any further. If there is a solution, I would be eager to know about. I would also be interested to know if your Orin NX works with a more generic carrier board and the IMX462. We may need that combination for our project soon. Good luck.
                    • J Offline
                      john @Howard
                      @howard, @vincentng, @veye_xumm is making some progress with Seeed after trying to get a response from them many times over (thanks!). We need the highly sensitive NIR IMX462 for our application and have tuned our code for the Veye ISP. @Howard what is the A206? Perhaps it could help us.
                        veye_xumm @john
                        @john @Vincentng
                        Good news.
                        Seeed's engineers have already solved this problem and it requires upgrading the firmware of the USB hub chip.
                        If necessary, you can contact Seeed's engineers or wait for Seeed to officially release the solution.
                        • V Offline
                          @veye_xumm Thanks for updates. WIll check with Seeed studio how to upgrade the firmware.
