    imx462 lowlight 0x20 parameter
    3 Posts 2 Posters 1.2k Views 1 Watching
    • V Offline
      Vaa
      Hello, I asked for lowlight default parameter and I got 0x20 value which is not defined in the i2c command manual. What does it mean?
        veye_xumm @Vaa
        @vaa
        0x20: bit5 is set to 1, which means that when operating in low-light conditions and starting to reduce the frame rate, the frame rate doesn't change continuously; instead, it changes in integer steps.
        I suggest se bit5 to 0.
        • V Offline
          Vaa @veye_xumm
          @veye_xumm Thank you very much!
