    cs_imx307_board_setup: invalid sensor model id
    jetsonxaviernxcsmipiimx307
    3 Posts 2 Posters 2.8k Views 1 Watching
      lubertRoft
      Hello everybody,
      I am using the CS-MIPI-IMX-307 and installed the kernel image and the device tree on a Xavier NX according to step 3.5 from the wiki:
      but when I checked the result from the command "dmesg | grep csx307" I get the following:
      csx307 9-003b: probing v4l2 sensor
      csx307 9-003b: tegracam sensor driver:csx307_v2.0.6
      csx307 9-003b: read sensor id 0132
      csx307 9-003b: cs_imx307_board_setup: invalid sensor model id: 306
      csx307 9-003b: board setup failed
      csx307 10-003b: probing v4l2 sensor
      csx307 10-003b: tegracam sensor driver:csx307_v2.0.6
      csx307 10-003b: read sensor id 0132
      csx307 10-003b: cs_imx307_board_setup: invalid sensor model id: 306
      csx307 10-003b: board setup failed
      why did it fail? What is the problem with the invalid sensor model id?
        lubertRoft @lubertRoft
        EDIT:
        The problem was a wrong assumption of the camera that I am using. After adjusting the dtb-file of the correct camera the camera gets detected properly.
          veye_xumm @lubertRoft
          @lubertroft You solved the problem by yourself. It was great!
