SOLVED Jetson Nano B01 MV IMX264
 Hi, I have used Image and DTB file from your github release and I recognize the camera well, but i got this error and obviously I dont have /dev/video0.
 Also the ./mv_mipi_i2c.sh script works fine.[ 1.396676] mvcam 7-003b: veye mv series camera driver version: 01.01.03 [ 1.897990] veye_mvcam: mvcam_read: Reading register 0x04 failed [ 1.904085] mvcam 7-003b: failed to read chip id [ 1.908761] mvcam 7-003b: mvcam_identify_module failed. [ 1.914139] mvcam 8-003b: veye mv series camera driver version: 01.01.03 [ 2.415604] mvcam 8-003b: camera is: MV-MIPI-IMX264M [ 2.415968] mvcam 8-003b: firmware version: 0x1410206 [ 2.428133] mvcam 8-003b: Unsupported pixel format [ 2.432983] mvcam 8-003b: Failed to read mode0 image props [ 2.438520] mvcam 8-003b: Could not initialize sensor properties. [ 2.444668] mvcam 8-003b: Failed to initialize tegra common for mvcam. [ 2.451263] mvcam: probe of 8-003b failed with error -22would you tell me how can I handle this?
 @otca by the way I dont see any Patches for 32.7.5: nvidia_jetson_veye_bsp$ find . -name *l4t-r32.7* ./kernel_patch_4_mv/l4t-r32.7.3 ./kernel_patch_4_mv/l4t-r32.7.1 ./kernel_patch_4_mv/l4t-r32.7.4could U please email or share it with me ?
 also would u mind tell me how to apply the patch?
 Thanks alot
 @otca It looks like your Image doesn't contain the patches needed by the mv camera, so it reports an error: unrecognised data type.
 Can I ask you the hardware and software version of your board, and which Image you replaced in it is from github?
 @veye_xumm sure!
 Board: Jetson Nano B01 Devkit (4GB)uname -r 4.9.337-tegraOS: Ubuntu 18.04.6 LTS aarch64 dpkg-query --show nvidia-l4t-core nvidia-l4t-core 32.7.5-20240611161210The release Version: https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/download/v1.29/nvidia_jetson_veye_bsp.tar.gzDTB:nvidia_jetson_veye_bsp/dtbs/Nano/JetPack_4.6.5_Linux_JETSON_NANO_TARGETS/dts dtb/MV-MIPI-MVCAM/tegra210-p3448-0000-p3449-0000-b00.dtbImage:kernel_image/Image_l4t_r32.7.5_veyecam.tar.gzKernel:cat /etc/nv_tegra_release # R32 (release), REVISION: 7.5, GCID: 36557527, BOARD: t210ref, EABI: aarch64, DATE: Tue Jun 11 23:12:44 UTC 2024Camera./mv_mipi_i2c.sh -r -f version -b 8 version is C 01.41 and L 02.06
 @otca
 "You did the right thing.
 The Jetpack 4.6.5 version of the kernel does not yet support the MV series cameras.
 Please switch to Jetpack 4.6.4 for your operations.
 @veye_xumm well, I thanks you.
 you helped me a lot long the pass and finally I was able to successfully work with the IMX264 on jetson Nano B01-Devkit 4GB jetpack 4.6.1 ( L4T 32.7.1).
 i tested both cameras and both are Ok.
 Still I have issues on other forum for Jetson Orin NX - Jetpack 6.0 (L4T 36.3).
 @otca I will continue discussing that issue with you in the other post.
