    SOLVED radxa zero 3e, debian, linux 5.10, imx287: Inappropriate ioctl for device
    Rockchip App camera
    • N
      nkos last edited by
      Hi, I'm trying to use imx287 on radxa zero 3e using the same C code I successfully used for rpi zero 2w:
      int fd = open("/dev/video0", O_RDWR);
      int camIdx = 0;
      int input = camIdx;
      int ret = ioctl(m_cam_fd, VIDIOC_S_INPUT, &input);
      // ret < 0: strerror(errno) == "Inappropriate ioctl for device"
      Could you please tell if I'm missing something?
      Do I need to select different device or VIDIOC_S_INPUT argument?
      After selecting the camera, I was going to use the same approach which worked for rpi zero 2w: VIDIOC_TRY_FMT/VIDIOC_S_FMT/VIDIOC_REQBUFS/VIDIOC_QUERYBUF/VIDIOC_QBUF/VIDIOC_DQBUF, is it possible? Does driver support this?
      I'm able to set cam params using mv_mipi_i2c_new.sh and it works (I set different metime values - and I see that laser (connected to cam output) brightness is changing)
      ./i2c_tools$ sudo ./mv_mipi_i2c_new.sh -b 2 -w metime 18
      ./i2c_tools$ sudo ./mv_mipi_i2c_new.sh -b 2 -w metime 180
      $ media-ctl -p -d /dev/media0
      Media controller API version 5.10.160
      Media device information
      driver          rkcif
      model           rkcif_mipi_lvds
      serial
      bus info
      hw revision     0x0
      driver version  5.10.160
      Device topology
      - entity 1: stream_cif_mipi_id0 (1 pad, 4 links)
                  type Node subtype V4L flags 0
                  device node name /dev/video0
      	pad0: Sink
      		<- "rockchip-mipi-csi2":1 [ENABLED]
      		<- "rockchip-mipi-csi2":2 []
      		<- "rockchip-mipi-csi2":3 []
      		<- "rockchip-mipi-csi2":4 []
      - entity 5: stream_cif_mipi_id1 (1 pad, 4 links)
                  device node name /dev/video1
      	pad0: Sink
      		<- "rockchip-mipi-csi2":1 []
      		<- "rockchip-mipi-csi2":2 [ENABLED]
      - entity 9: stream_cif_mipi_id2 (1 pad, 4 links)
                  device node name /dev/video2
      	pad0: Sink
      		<- "rockchip-mipi-csi2":3 [ENABLED]
      - entity 13: stream_cif_mipi_id3 (1 pad, 4 links)
                   device node name /dev/video3
      	pad0: Sink
      		<- "rockchip-mipi-csi2":4 [ENABLED]
      - entity 17: rkcif_tools_id0 (1 pad, 4 links)
                   device node name /dev/video4
      	pad0: Sink
      - entity 21: rkcif_tools_id1 (1 pad, 4 links)
                   device node name /dev/video5
      	pad0: Sink
      - entity 25: rkcif_tools_id2 (1 pad, 4 links)
                   device node name /dev/video6
      	pad0: Sink
      - entity 29: rkcif-mipi-luma (0 pad, 0 link)
                   device node name /dev/video7
      - entity 32: rockchip-mipi-csi2 (5 pads, 29 links)
      	pad0: Sink
      		[fmt:Y8_1X8/704x544 field:none
      		 crop.bounds:(0,0)/704x544
      		 crop:(0,0)/704x544]
      		<- "rockchip-csi2-dphy0":1 [ENABLED]
      	pad1: Source
      		-> "stream_cif_mipi_id0":0 [ENABLED]
      		-> "stream_cif_mipi_id1":0 []
      		-> "stream_cif_mipi_id2":0 []
      		-> "stream_cif_mipi_id3":0 []
      		-> "rkcif_tools_id0":0 []
      		-> "rkcif_tools_id1":0 []
      		-> "rkcif_tools_id2":0 []
      	pad2: Source
      		-> "stream_cif_mipi_id0":0 []
      		-> "stream_cif_mipi_id1":0 [ENABLED]
      	pad3: Source
      		-> "stream_cif_mipi_id2":0 [ENABLED]
      	pad4: Source
      		-> "stream_cif_mipi_id3":0 [ENABLED]
      - entity 38: rockchip-csi2-dphy0 (2 pads, 2 links)
      	pad0: Sink
      		[fmt:Y8_1X8/704x544@100/52300 field:none]
      		<- "m00_b_mvcam 2-003b":0 [ENABLED]
      	pad1: Source
      		-> "rockchip-mipi-csi2":0 [ENABLED]
      - entity 43: m00_b_mvcam 2-003b (1 pad, 1 link)
      	pad0: Source
      		-> "rockchip-csi2-dphy0":0 [ENABLED]
        veye_xumm @nkos last edited by
        @nkos
        Below is a tutorial on using this camera module on Radxa boards.
        https://wiki.veye.cc/index.php/MV_Camera_on_Radxa_Boards
        Unlike the Raspberry Pi platform, on RK platforms, some preparatory work is required to use our module, which involves configuring the appropriate image parameters using media-ctl.
        However, based on the information you provided, it seems you have already set it up correctly.
        Once this preparation is complete, the process of capturing images is the same as on the Raspberry Pi.
        If you encounter any issues, you can refer to the code example at:
        https://wiki.veye.cc/index.php/MV_Camera_on_Radxa_Boards#Example_of_yavta
        Additionally, we have an open-source client software available for your use and reference.
        https://github.com/veyeimaging/veye_viewer
        • N
          nkos @veye_xumm last edited by
          @veye_xumm, thanks a lot, yavta example helped, I can receive images now, topic is resolved
          There are diffirences between rpi and radxa: buffer format, image packing and setting params (I can use approach from i2cwrite.c)
          Both my code and yavta are not able to do some things I can do on rpi (e.g. VIDIOC_S_INPUT), but it seems I can use camera without them
            @nkos Cheers!
