    cssc132 (Raspberry pi 5). Not a video capture device. /dev/videoXX: No such device
    14 Posts 2 Posters 2.9k Views 1 Watching
    • S Offline
      Sheko @Sheko
        veye_xumm @Sheko
        @sheko
        The RAW-MIPI-SC132M module requires the mvcam driver, not cssc132.
        • S Offline
          Sheko @veye_xumm
          @veye_xumm , Where can I get the driver I need?
            veye_xumm @Sheko
            @sheko
            https://wiki.veye.cc/index.php/Raspberry_Pi_Application_Note_Index
            part1.2
            • S Offline
              Sheko @veye_xumm
              @veye_xumm The video is not displayed in the program
              sheko@raspberrypi:~/mv_tools_rpi $ ./mv_mipi_i2c_new.sh
              Usage: ./mv_mipi_i2c_new.sh [-r/w] [function name] [param1] [param2 ] [param3] [param4] -b bus
              options:
              -r read
              -w write
              [function name] function name
              [param1] param1 of each function
              [param1] param2 of each function
              [param3] param3 of each function
              [param4] param4 of each function
              Please open this srcipt and read the COMMENT on top for support functions and samples
              sheko@raspberrypi:~/mv_tools_rpi $ ./mv_mipi_i2c_new.sh -r manufacturer -b 11
              ./mv_mipi_i2c_new.sh: line 453: Read i2c err -1
              -36345312: syntax error in expression (error token is "i2c err -1
              -36345312")
              sheko@raspberrypi:~/mv_tools_rpi $ ./mv_mipi_i2c_new.sh -r manufacturer -b 10
              Manufacturer is VEYE
              sheko@raspberrypi:~/mv_tools_rpi $ ./mv_mipi_i2c_new.sh -r version -b 10
              version is C 01.04 and L 00.00
              sheko@raspberrypi:~/mv_tools_rpi $ ./mv_mipi_i2c_new.sh -r errcode -b 10
              errcode is 0x0
              sheko@raspberrypi:~/mv_tools_rpi $ ./mv_mipi_i2c_new.sh -r fmtcap -b 10
              fmtcap is 0x3
              sheko@raspberrypi:~/mv_tools_rpi $ ./mv_mipi_i2c_new.sh -r readmodecap -b 10
              r read mode capbility is 0x3
              sheko@raspberrypi:~/mv_tools_rpi $ ./mv_mipi_i2c_new.sh -r i2caddr -b 10
              r i2c addr is 0x01
              sheko@raspberrypi:~/mv_tools_rpi $ ./mv_mipi_i2c_new.sh -r minwh -b 10
              r ROI min width is -1 height is -1
              sheko@raspberrypi:~/mv_tools_rpi $ ./mv_mipi_i2c_new.sh -w imgacq [0/1] -b 10
              ./mv_mipi_i2c_new.sh: line 615: printf: [0/1]: invalid number
              w image acq is 00
              sheko@raspberrypi:~/mv_tools_rpi $ ./mv_mipi_i2c_new.sh -w trgmode [0,2] -b 10
              ./mv_mipi_i2c_new.sh: line 815: printf: [0,2]: invalid number
              w trigger mode is 0
              sheko@raspberrypi:~ $ dmesg | grep mvcam
              [ 0.029049] /axi/pcie@1000120000/rp1/i2c@80000/veyemvcam@3b: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@128000
              [ 0.029059] /axi/pcie@1000120000/rp1/i2c@88000/veyemvcam@3b: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@110000
              [ 0.029082] /axi/pcie@1000120000/rp1/csi@110000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@88000/veyemvcam@3b
              [ 0.029089] /axi/pcie@1000120000/rp1/csi@128000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@80000/veyemvcam@3b
              [ 0.029211] /axi/pcie@1000120000/rp1/i2c@80000/veyemvcam@3b: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@128000
              [ 0.029221] /axi/pcie@1000120000/rp1/i2c@88000/veyemvcam@3b: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@110000
              [ 0.029246] /axi/pcie@1000120000/rp1/csi@110000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@88000/veyemvcam@3b
              [ 0.029254] /axi/pcie@1000120000/rp1/csi@128000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@80000/veyemvcam@3b
              [ 0.410283] /axi/pcie@1000120000/rp1/i2c@80000/veyemvcam@3b: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@128000
              [ 0.410360] /axi/pcie@1000120000/rp1/i2c@88000/veyemvcam@3b: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@110000
              [ 0.410672] /axi/pcie@1000120000/rp1/i2c@88000/veyemvcam@3b: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@110000
              [ 0.410689] /axi/pcie@1000120000/rp1/csi@110000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@88000/veyemvcam@3b
              [ 0.410753] /axi/pcie@1000120000/rp1/i2c@80000/veyemvcam@3b: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@128000
              [ 0.410767] /axi/pcie@1000120000/rp1/csi@128000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@80000/veyemvcam@3b
              [ 0.676352] /axi/pcie@1000120000/rp1/csi@128000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@80000/veyemvcam@3b
              [ 0.676383] /axi/pcie@1000120000/rp1/i2c@80000/veyemvcam@3b: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@128000
              [ 0.676753] /axi/pcie@1000120000/rp1/csi@110000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@88000/veyemvcam@3b
              [ 0.676776] /axi/pcie@1000120000/rp1/i2c@88000/veyemvcam@3b: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@110000
              [ 3.139990] rp1-cfe 1f00110000.csi: found subdevice /axi/pcie@1000120000/rp1/i2c@88000/veyemvcam@3b
              [ 3.142880] rp1-cfe 1f00128000.csi: found subdevice /axi/pcie@1000120000/rp1/i2c@80000/veyemvcam@3b
              [ 3.157307] veye_mvcam: loading out-of-tree module taints kernel.
              [ 3.198535] mvcam 11-003b: veye mv series camera driver version: 01.01.08
              [ 3.200894] mvcam 11-003b: Unable to load veye_vbyone driver,will go on
              [ 3.703320] mvcam: mvcam_read: Reading register 0x04 failed
              [ 3.703334] mvcam 11-003b: failed to read chip id
              [ 3.704032] mvcam 10-003b: veye mv series camera driver version: 01.01.08
              [ 3.709591] mvcam 10-003b: Unable to load veye_vbyone driver,will go on
              [ 4.211903] mvcam 10-003b: camera is: RAW-MIPI-SC132M
              [ 4.213695] mvcam 10-003b: firmware version: 0x1040000
              [ 4.218412] mvcam 10-003b: Success to get mvcam endpoint data lanes, dts uses 2 lanes,will set to camera
              [ 4.228280] mvcam 10-003b: mvcam_enum_controls success
              [ 4.229657] rp1-cfe 1f00110000.csi: Using sensor mvcam 10-003b for capture
              sheko@raspberrypi:~ $ v4l2-ctl --list-devices
              pispbe (platform:1000880000.pisp_be):
              /dev/video20
              /dev/video21
              /dev/video22
              /dev/video23
              /dev/video24
              /dev/video25
              /dev/video26
              /dev/video27
              /dev/video28
              /dev/video29
              /dev/video30
              /dev/video31
              /dev/video32
              /dev/video33
              /dev/video34
              /dev/video35
              /dev/media0
              /dev/media1
              rp1-cfe (platform:1f00110000.csi):
              /dev/video0
              /dev/video1
              /dev/video2
              /dev/video3
              /dev/video4
              /dev/video5
              /dev/video6
              /dev/video7
              /dev/media2
              rp1-cfe (platform:1f00128000.csi):
              /dev/media3
              rpi-hevc-dec (platform:rpi-hevc-dec):
              /dev/video19
              /dev/media4
              sheko@raspberrypi:~ $ v4l2-ctl --device=/dev/video0 --all
              Driver Info:
              Driver name : rp1-cfe
              Card type : rp1-cfe
              Bus info : platform:1f00110000.csi
              Driver version : 6.12.47
              Capabilities : 0xaca00001
              Video Capture
              Metadata Capture
              Metadata Output
              Streaming
              Extended Pix Format
              Device Capabilities
              Device Caps : 0x24a00001
              Video Capture
              Metadata Capture
              Streaming
              Extended Pix Format
              Media Driver Info:
              Model : rp1-cfe
              Serial :
              Media version : 6.12.47
              Hardware revision: 0x00114666 (1132134)
              Interface Info:
              Type : V4L Video
              Entity Info:
              Function : V4L2 I/O
              Pad 0x01000013 : 0: Sink, Must Connect
              Link 0x02000034: from remote pad 0x1000006 of entity 'csi2' (Video Interface Bridge): Data
              Priority: 2
              Video input : 0 (rp1-cfe-csi2_ch0: ok)
              Format Video Capture:
              Width/Height : 1280/1080
              Pixel Format : 'YUYV' (YUYV 4:2:2)
              Field : None
              Bytes per Line : 2560
              Size Image : 2764800
              Colorspace : Raw
              Transfer Function : None
              YCbCr/HSV Encoding: ITU-R 601
              Quantization : Full Range
              Flags :
              Format Metadata Capture:
              Sample Format : 'SENS' (Sensor Ancillary Metadata)
              Buffer Size : 16384
              sheko@raspberrypi:~ $ ffplay /dev/video0
              ffplay version 5.1.8-0+deb12u1+rpt1 Copyright (c) 2003-2025 the FFmpeg developers
              built with gcc 12 (Debian 12.2.0-14+deb12u1)
              configuration: --prefix=/usr --extra-version=0+deb12u1+rpt1 --toolchain=hardened --incdir=/usr/include/aarch64-linux-gnu --enable-gpl --disable-stripping --disable-mmal --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libglslang --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librist --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libsvtav1 --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sand --enable-sdl2 --disable-sndio --enable-libjxl --enable-neon --enable-v4l2-request --enable-libudev --enable-epoxy --libdir=/usr/lib/aarch64-linux-gnu --arch=arm64 --enable-pocketsphinx --enable-librsvg --enable-libdc1394 --enable-libdrm --enable-vout-drm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-libplacebo --enable-librav1e --enable-shared
              libavutil 57. 28.100 / 57. 28.100
              libavcodec 59. 37.100 / 59. 37.100
              libavformat 59. 27.100 / 59. 27.100
              libavdevice 59. 7.100 / 59. 7.100
              libavfilter 8. 44.100 / 8. 44.100
              libswscale 6. 7.100 / 6. 7.100
              libswresample 4. 7.100 / 4. 7.100
              libpostproc 56. 6.100 / 56. 6.100
              %(#ff0000)[[video4linux2,v4l2 @ 0x7ffe94000c20] ioctl(VIDIOC_G_PARM): Inappropriate ioctl for device
              %(#ff0000)[[video4linux2,v4l2 @ 0x7ffe94000c20] Time per frame unknown
              [video4linux2,v4l2 @ 0x7ffe94000c20] ioctl(VIDIOC_STREAMON): %(#ff0000)[Invalid argument
              /dev/video0: Invalid argument]
              nan : 0.000 fd= 0 aq= 0KB vq= 0KB sq= 0B f=0/0
              sheko@raspberrypi:~ $ vlc
              VLC media player 3.0.21 Vetinari (revision 3.0.21-0-gdd8bfdbabe8)
              [000055563a0e9560] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
              [000055563a1898d0] main playlist: playlist is empty
              libpng warning: iCCP: known incorrect sRGB profile
              qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
              [00007fff8c007cd0] v4l2 demux error: cannot get streaming parameters: Inappropriate ioctl for device
              libv4l2: error turning on stream: Invalid argument
              [00007fff8c007cd0] v4l2 demux error: cannot start streaming: Invalid argument
              [00007fff8c007cd0] v4l2 demux error: not a radio tuner device
              [00007fff8c0078d0] v4l2 stream error: cannot get streaming parameters: Inappropriate ioctl for device
              %(#ff0000)[[00007fff8c0078d0] v4l2 stream error: cannot start streaming: Invalid argument
              sheko@raspberrypi:~ $]
                veye_xumm @Sheko
                @sheko
                You have successfully loaded the driver and detected the camera. Please refer to the instructions for the veye_viewer client software in the previous link to directly preview the images:
                https://wiki.veye.cc/index.php/Mv_series_camera_appnotes_4_rpi#veye_viewer
                • S Offline
                  Sheko
                  @veye_xumm './config/.sh': No such file or directory
                  what am I doing wrong?
                  sheko@raspberrypi:~ $ cd veye_viewer
                  chmod +x ./
                  chmod 755 ./config/.sh
                  ./start_veye_viewer.sh
                  chmod: cannot access './config/.sh': No such file or directory
                  Platform detected: raspberrypi5
                  veye_viewer binary not found or not executable.
                    veye_xumm @Sheko
                    @sheko
                    It looks like you downloaded the source code, but didn’t compile it. You can download the precompiled binary from the link below and run it directly.
                    https://github.com/veyeimaging/veye_viewer/releases/download/v1.1.4_rpi/veye_viewer_RaspberryPi_bin.zip
                    • S Offline
                      Sheko @veye_xumm
                      here is the result^
                      heko@raspberrypi:~/veye_viewer_RaspberryPi_bin $ ./start_veye_viewer.sh
                      bash: ./start_veye_viewer.sh: Permission denied
                      sheko@raspberrypi:~/veye_viewer_RaspberryPi_bin $ chmod 755 ./config/.sh
                        veye_xumm @Sheko
                        @sheko
                         cd veye_viewer
                            chmod +x ./*
                        	chmod 755 ./config/*.sh
                        • S Offline
                          Sheko
                          the program started
                          white screen - no image
                          chmod +x ./*
                          Launching veye_viewer...
                          [2026-01-28 07:59:42.882][INFO ][Main.cpp:0029] Start cleaning expired logs. Keep days: 30 | Deadline date: 2025-12-29
                          [2026-01-28 07:59:42.886][INFO ][Main.cpp:0056] Log clean completed. Total deleted files: 0
                          Done --> /home/sheko/veye_viewer/config/auto_camera_index.json
                          (veye_viewer:2119): GLib-GObject-CRITICAL **: 07:59:44.547: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
                          [2026-01-28 08:00:53.233][WARN ][unknown_file:----] libpng warning: iCCP: known incorrect sRGB profile
                          [2026-01-28 08:00:53.234][WARN ][unknown_file:----] libpng warning: iCCP: known incorrect sRGB profile
                          [2026-01-28 08:00:53.235][WARN ][unknown_file:----] libpng warning: iCCP: known incorrect sRGB profile
                            veye_xumm @Sheko
                            @sheko It looks like nothing is abnormal. You haven’t installed a lens, right?
                            • S Offline
                              Sheko @veye_xumm
                              That's right. It worked with the lens. Thank you very much for your technical support.
