    2. hchorsi
    H
    Offline
    • Topics 3
    • Posts 11
    Recent Best Controversial
    • IMX335 trigger synchronization
      Hello,
      Can the IMX335 sensor be synchronized with an illumination source such as projector using trigger pins? What are the requirements for the trigger signal in terms of the frequency, amplitude, duty cycle,...?
      Thank you
      posted in CS MIPI camera
      H
      hchorsi
    • Long distance MIPI
      Greetings, we are presently utilizing the IMX335 camera module with a MIPI connector. Regrettably, the cable provided is insufficient in length for our specific requirements. Would you kindly offer any potential solutions or recommendations for extending the cable distance? Thank you in advance for your assistance.
      H
      hchorsi
    • RE: ADP-N1-V2.0 Adapter Board
      @veye_xumm Thank you for your reply.
      Would it be possible to disable ISP?
      and then reduce the pixel numbers (say 2592(H)×250(V) pixels ) to run at higher frame rates?
      H
      hchorsi
      I am interested in running IMX335 at 500fps. Is it possible to do this openCV or modifying "veye5_mipi_i2c.sh" file? Could you please let me know how?
      Thank you
      H
      hchorsi
      I use IMX335 along with ADP-N1-V2.0 adapter board on Jetson Orin. I want to make sure that I connect the adapter correctly and properly.
      • Should I connect the adapter board to a 12V external supply for imx335 (for a single camera)?
      • Can the adapter be connected the jetson without any camera or FFC cable attached to the adapter board?
      • Do I need at least one FFC cable connected to the adapter board before connecting to jetson?
      • When should I connect the adapter/camera to the jetson, before powering up the jetson or after powering up?
      H
      hchorsi
      @veye_xumm Any suggestions for me to debug the board? Thank you so much!
      H
      hchorsi
      @veye_xumm Hello,
      I replaced BLM3401 on my ADP-N1-V2.0 Adapter Board and also made sure the board does't short. Please see attached images.
      Unfortunately, my adaptor board gets really really hot a few seconds after connecting to jetson!
      H
      hchorsi
      Is it fine to use Goford3401 (Link below) instead of BLM3401?
      It has the same feature except that the gate-source voltage is +-12 instead of +-20 for BLM3401.
      https://www.digikey.com/en/products/detail/goford-semiconductor/3401/13664831
      Thank you,
      H
      hchorsi
      This might be the case with my adaptor board since mine also looks like it not flat.
      So, do you think replacing the BLM3401 will fix the issue? Or I need a new adaptor board?
      Thank you,
      H
      hchorsi
      @veye_xumm said in ADP-N1-V2.0 Adapter Board:
      BLM3401
      The part that I don't understand is that I didn't connect any FFC cable to the adaptor. I only connected the adaptor board to the Jetson board. Is this an issue?
      Thank you,
      H
      hchorsi
    • ADP-N1-V2.0 Adapter Board
      I have a Jetson AGX Orin which connect to power supply using the USB-C connector.
      I ordered IMX335 which came with ADP-N1-V2.0 Adapter board. When I connected the adaptor to the Jetson board, one component got burned. I didn't connect the adaptor to any power supply.
      Please attached images.
      H
      hchorsi
