    2. milank
    M
    Offline
    • Topics 3
    • Posts 20
    milank
    @milank
    Joined
    Last Online
    Email milank2010@gmail.com
    milank Unfollow Follow
    Latest posts made by milank
    • RE: VEYE-MIPI-IMX462 - manual gain not consistent
      Hello,
      now, it seems that this additional line did the trick.
      No brightness drop seen anymore.
      Thank you for your help.
      M
      milank
      fine, thank you, I will test, my init script now looks like:
      ./veye_mipi_i2c.sh -w -f new_expmode -p1 1
      sleep 1
      ./veye_mipi_i2c.sh -w -f new_mshutter -p1 40000 # fixed 40 ms
      sleep 1
      ./veye_mipi_i2c.sh -w -f new_mgain -p1 23 # between 20 and 25
      sleep 1
      ./veye_mipi_i2c.sh -w -f brightness -p1 0
      sleep 1
      special code for sky imaging, to turn automatic bad point correction off
      ./i2c_write 10 0x3b 0x0007 0xFE
      ./i2c_write 10 0x3b 0x0010 0xDB
      ./i2c_write 10 0x3b 0x0011 0x9F
      ./i2c_write 10 0x3b 0x0012 0x00
      ./i2c_write 10 0x3b 0x0013 0x00
      sleep 1
      ./i2c_read 10 0x3b 0x0014 1
      ./veye_mipi_i2c.sh -w -f paramsave
      M
      milank
      @milank
      FF_CZ0004_20230315_204426_226_0277248.fits_maxpixel.jpg FF_CZ0004_20230315_204416_011_0276992.fits_maxpixel.jpg
      M
      milank
      @milank
      Another change has been detected last night, around 20:44:25 UTC.
      Unfortunatelly, no change detected in spoken registers.
      The reading interval was set to 5 seconds.
      I am also attaching two full BMP images just before/after the change of brightness.![1_1678948719448_FF_CZ0004_20230315_204426_226_0277248.fits_maxpixel.bmp](Nahrávám 100%) ![0_1678948719448_FF_CZ0004_20230315_204416_011_0276992.fits_maxpixel.bmp](Nahrávám 100%)
      03/15/2023 20:44:11 reg addr 0x14 val is 0x53
      03/15/2023 20:44:11 reg addr 0x20 val is 0x1
      03/15/2023 20:44:11 reg addr 0x21 val is 0x0
      03/15/2023 20:44:11 reg addr 0x22 val is 0x0
      03/15/2023 20:44:12 reg addr 0x9 val is 0x11
      03/15/2023 20:44:17 reg addr 0x14 val is 0x53
      03/15/2023 20:44:17 reg addr 0x20 val is 0x1
      03/15/2023 20:44:18 reg addr 0x21 val is 0x0
      03/15/2023 20:44:18 reg addr 0x22 val is 0x0
      03/15/2023 20:44:18 reg addr 0x9 val is 0x11
      03/15/2023 20:44:24 reg addr 0x14 val is 0x53
      03/15/2023 20:44:24 reg addr 0x20 val is 0x1
      03/15/2023 20:44:24 reg addr 0x21 val is 0x0
      03/15/2023 20:44:25 reg addr 0x22 val is 0x0
      03/15/2023 20:44:25 reg addr 0x9 val is 0x11
      03/15/2023 20:44:30 reg addr 0x14 val is 0x53
      03/15/2023 20:44:30 reg addr 0x20 val is 0x1
      03/15/2023 20:44:31 reg addr 0x21 val is 0x0
      03/15/2023 20:44:31 reg addr 0x22 val is 0x0
      03/15/2023 20:44:31 reg addr 0x9 val is 0x11
      03/15/2023 20:44:36 reg addr 0x14 val is 0x53
      03/15/2023 20:44:37 reg addr 0x20 val is 0x1
      03/15/2023 20:44:37 reg addr 0x21 val is 0x0
      03/15/2023 20:44:37 reg addr 0x22 val is 0x0
      03/15/2023 20:44:38 reg addr 0x9 val is 0x11
      03/15/2023 20:44:43 reg addr 0x14 val is 0x53
      03/15/2023 20:44:43 reg addr 0x20 val is 0x1
      03/15/2023 20:44:43 reg addr 0x21 val is 0x0
      03/15/2023 20:44:44 reg addr 0x22 val is 0x0
      03/15/2023 20:44:44 reg addr 0x9 val is 0x11
      M
      milank
      fine, understood, now it is running in the background for spoken registers.
      I will come back with the results once I see the spike again.
      M
      milank
      for this, please see:
      https://github.com/CroatianMeteorNetwork/RMS/blob/master/Utils/PlotFieldsums.py
      M
      milank
      @milank
      the same procedure runs on many installations using the IP camera without strange phenomenons like on the picture.
      This is the attempt to replace them by a MIPI camera.
      M
      milank
      The camera runs in the continuous streaming mode, 25 fps.
      250 frames (10s series) are used for creating the maxpixel frame.
      Maxpixel frames are then used for creating the graph on the picture.
      M
      milank
      I mean automatic operation (start and stop capture).
      According to the script, the exposure is in manual mode.
      M
      milank
      yes, this is weird.
      No other devices are connected to the I2C port (pi4, I2C-1 on pins 3 and 5).
      The camera is operated in automated mode overnight, without rebooting in the morning.
      The script can be ran only manually.
      I have also another example, see below. Here, it happened twice in series.
      M
      milank
