    2. sebaszz
    S
    Offline
    • Topics 1
    • Posts 4
    sebaszz
    @sebaszz
    Joined
    Last Online
    sebaszz Unfollow Follow
    Latest posts made by sebaszz
    • RE: VEYE-MIPI-327S gstreamer issue
      FIXED! thank you!
      S
      sebaszz
      I prefer to have a UDP working since it will be used after testing via 4G/LTE connection.
      All these test are currently done via Wifi. Standard Pi camera is working fine.
      S
      sebaszz
      I tried. Without succes. Any suggestions?
      RPI side (192.168.0.163)
      ./veye_raspivid -b 4000000 -t 0 -o -  | gst-launch-1.0 -v fdsrc ! h264parse ! rtph264pay config-interval=1 pt=96 ! gdppay ! tcpserversink host=192.168.0.208 port=7000
      PC side (192.168.0.208)
      gst-launch-1.0 -v tcpclientsrc host=192.168.0.163 port=7000 ! gdpdepay ! rtph264depay ! avdec_h264 ! autovideosink sync=false
      ERROR GSTREAMER
      (gst-launch-1.0:5064): GStreamer-WARNING **: 21:15:29.964: Failed to load plugin 'C:\gstreamer\1.0\msvc_x86\lib\gstreamer-1.0\gstwavpack.dll': The specified module could not be found.
      This usually means Windows was unable to find a DLL dependency of the plugin. Please check that PATH is correct.
      You can run 'dumpbin -dependents' (provided by the Visual Studio developer prompt) to list the DLL deps of any DLL.
      There are also some third-party GUIs to list and debug DLL dependencies recursively.
      Use Windows high-resolution clock, precision: 1 ms
      Setting pipeline to PAUSED ...
      ERROR: from element /GstPipeline:pipeline0/GstTCPClientSrc:tcpclientsrc0: Could not open resource for reading.
      Additional debug info:
      ../gst/tcp/gsttcpclientsrc.c(493): gst_tcp_client_src_start (): /GstPipeline:pipeline0/GstTCPClientSrc:tcpclientsrc0:
      Failed to connect to host '192.168.0.163:7000': No connection could be made because the target machine actively refused it.
      ERROR: pipeline doesn't want to preroll.
      ERROR: from element /GstPipeline:pipeline0/GstTCPClientSrc:tcpclientsrc0: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
      ../libs/gst/base/gstbasesrc.c(3557): gst_base_src_start (): /GstPipeline:pipeline0/GstTCPClientSrc:tcpclientsrc0:
      Failed to start
      Failed to set pipeline to PAUSED.
      Setting pipeline to NULL ...
      Freeing pipeline ...
      ERROR RPI
      14/06/2022 20:15:22 Enabling custom
      mmal: Splitter has 4 output port,you could use num 2,3 for extend
      Pipeline is PREROLLING ...
      ERROR: from element /GstPipeline:pipeline0/GstTCPServerSink:tcpserversink0: Could not open resource for reading.
      gsttcpserversink.c(403): gst_tcp_server_sink_init_send (): /GstPipeline:pipeline0/GstTCPServerSink:tcpserversink0:
      Failed to bind on host '192.168.0.208:7000': Error binding to address: Cannot assign requested address
      mmal: mmal_vc_port_enable: failed to enable port vc.ril.isp:in:0(UYVY): ENOMEM
      mmal: mmal_port_enable: failed to enable connected port (vc.ril.isp:in:0(UYVY))0x1bfef00 (ENOMEM)
      mmal: mmal_connection_enable: output port couldn't be enabled
      mmal: Failed to create rawcam->isp connection
      mmal: Out of memory
      mmal: Camera is not detected. Please check carefully the camera module is installed correctly
      S
      sebaszz
    • VEYE-MIPI-327S gstreamer issue
      Hi,
      I trying to get gstreamer working via UDP
      RPI side
      /home/pi/raspberrypi/veye_raspcam/bin/./veye_raspivid -b 4000000 -t 0 -o -  | gst-launch-1.0 -v fdsrc ! h264parse ! rtph264pay config-interval=1 pt=96 ! gdppay ! udpsink host=192.168.0.208 port=7000 sync=false
      PC side (192.168.0.208:7000)
      gst-launch-1.0 -v udpsrc port=7000 ! gdpdepay ! rtph264depay ! avdec_h264 ! autovideosink sync=false
      I get the following error
      Any help is really appreciated!
      S
      sebaszz
