    Direct download img from baidu
    16 Posts 2 Posters 3.4k Views 1 Watching
    • V Offline
      Viktor
      Tell me please how i can download img for nano imx327 directly?
      Baidu wants install some app.
      Best regards, Viktor.
      • V Offline
        Viktor @Viktor
        Ok. I found google drive here:
        https://drive.google.com/drive/folders/1KHSMTdyw-ZczR1yJPj-5y9eIv7izbgt3?usp=sharing
        Closed.
          veye_xumm @Viktor
          @viktor
          Burning the prebuilt Image to upgrade Jetson Nano and Xavier NX Devkit
          This method is no longer recommended because in this mode, the DTB partition reverts to the default value in some cases. It is recommended to use pre-compiled Image and DTB for driver upgrade.
          http://wiki.veye.cc/index.php/VEYE_CS_Camera_for_Jetson_TX2#Burning_the_prebuilt_Image_to_upgrade_Jetson_Nano_and_Xavier_NX_Devkit
          • V Offline
            Viktor @veye_xumm
            @veye_xumm Hi, have testes 4.3 img and all is ok, imx327 works fine.
            But system wants software update and after restart i can't see /dev/video0.
            Tell me please, where i can get new 4.5.1 img?
            Can i do apt upgrade, apt dist-upgrade?
            Or how i can fix camera disappearing now?
              veye_xumm @Viktor
              @viktor
              please check your new system version and follow this guide.
              V 3 Replies Last reply Reply Quote 0
              • V Offline
                Viktor @veye_xumm
                @veye_xumm Hi, have tried.
                cat /etc/nv_tegra_release -> r32, 4.4
                Download Image and dtb.
                Copy to /boot
                Edit /boot/extlinux/extlinux.conf -> FDT /boot/dtb file
                And now i have nvidia logo only and loop reboot.
                My system nano b01, imx327.
                Updated: mount sd to host and removed line from extlinux.conf
                Now it is bootable, but camera does not work.
                Also i see initrd.img->initrd.img-4.9.140-tegra in /boot
                Here is kern.log: cam360.tv/etc/kern.log
                Please help.
                • V Offline
                  Viktor @veye_xumm
                  @veye_xumm I also have tried from host:
                  copy dtb to kernel/dtb
                  sudo ./flash.sh -r -k DTB jetson-nano-qspi-sd mmcblk0p1
                  from L4T but nothing, /dev/video0 is not present.
                  About system:
                  R32 (release), REVISION: 4.4, GCID: 23942405, BOARD: t210ref, EABI: aarch64, DATE: Fri Oct 16 19:44:43 UTC 2020
                  number@number:~$ dpkg-query --show nvidia-l4t-core
                  nvidia-l4t-core 32.4.4-20201016124427
                  Bsp from here:
                  https://github.com/veyeimaging/nvidia_jetson_veye_bsp/tree/master/Nano/JetPack_4.4.1_Linux_JETSON_NANO_DEVKIT/dts dtb/VEYE-MIPI-327
                  Kernel from here:
                  https://github.com/veyeimaging/nvidia_jetson_veye_bsp/blob/master/kernel_image/Image_l4t_r32.4.4_veyecam.tar.gz
                  So, please tell me how to repair Veye327 system after ubuntu software update?
                  • V Offline
                    Viktor @veye_xumm
                    @veye_xumm Here is screenshot, after fresh installation, ubuntu wants 600mb updates, include nvidia l4t4.4: cam360.tv/etc/43-44.jpg
                    So i need to update system without reflash as on other native jetson platforms.
                    Please help.
                      veye_xumm @Viktor
                      @viktor
                      If you want to upgrade new version of L4T, I suggest you upgrade the system first, then do our VEYE bsp upgrade.
                      This is the list of version we provide:
                      Jetpack4.2.2,L4T r32.2.1
                      Jetpack4.3,L4T r32.3.1
                      Jetpack4.4,L4T r32.4.3
                      Jetpack4.4.1,L4T r32.4.4
                      Jetpack4.5,L4T r32.5
                      Jetpack4.5.1,L4T r32.5.1
                      About your failure here:
                      @viktor said in Direct download img from baidu:
                      Copy to /boot
                      Please check the dtb file name and the line you add in /boot/extlinux/extlinux.conf, they must be the same.
                      • V Offline
                        Viktor @veye_xumm
                        Have build 4.5.1 from scratch and it works.
                        About upgrade.
                        Can i apply VEYE image/drivers without reflash and changing /app/home partition?
                          veye_xumm @Viktor
                          @viktor
                          • V Offline
                            Viktor @veye_xumm
                            @veye_xumm Yes. It was first method what i did, but it does not work for Nano. Fdt line brokes system.
                              veye_xumm @Viktor
                              @viktor
                              pls paste your fdt line here. It must be wrong.
                              • V Offline
                                Viktor @veye_xumm
                                It was:
                                FDT /boot/tegra210-p3448-0000-p3449-0000-b00.dtb
                                It must works?
                                  veye_xumm @Viktor
                                  @viktor
                                  I think this line is correct.
                                  It's very strange. It works normally in my place.
                                  • V Offline
                                    Viktor @veye_xumm
                                    @veye_xumm ok. Will try again.
