    Is there 4 camera system for CS-FPD-CAM Series?
    12 Posts 3 Posters 5.8k Views 1 Watching
    • S Offline
      serene
      I am interested in 4 camera system over FPD-Link III that would work with Jetson Nano, TX2, and ARM-based system (i.e. RK3399) such as ASUS Tinkerboard.
      Is there any VEYE product in CS-FPD-CAM series with that spec?
      Thanks.
        veye_xumm @serene
        @serene
        We are very sorry, fpdlink has been out of stock for a long time due to chip availability.
        • S Offline
          serene @veye_xumm
          Thank you for the prompt response.
          How about for GMSL2?
            veye_xumm @serene
            @serene We do not have GMSL2 products.
            • S Offline
              serene @veye_xumm
              Thank you. How about MIPI CS-2?
              Do you have a set of breakout board with 4 cameras that is compatible with Jetson (Nano and TX2) and Raspberry Pi equivalent - i.e. ASUS Tinkerboard (RK3399) and NXP iMX8M SBC?
                veye_xumm @serene
                @serene
                Hello, I think this first depends on whether the motherboard support, rather than the camera can access.
                For example: Jetson,nano,imx8m,rk3399 and rpi, they do not support 4 mipi csi-2 interfaces.
                For TX2, yes.
                http://wiki.veye.cc/index.php/CS-TX2-XAVIER-nCAM_Series
                • S Offline
                  serene @veye_xumm
                  Thank you.
                  I found CS-TX2-XAVIER-nCAM-IMX385 in Amazon:
                  Amazon - CS-TX2-XAVIER-nCAM-IMX385
                  On the description it says:
                  "Support Raspberry Pi Zero & W,Pi 4,3 b+,Pi 3, Pi CM. Jetson Nano, Xavier NX."
                  Btw, how about with UCM-iMX8PLUS that has 2x MIPI-CSI, 4 data lanes?
                    veye_xumm @serene
                    @serene
                    Yes, this is our product.
                    We don't have access to UCM-iMX8PLUS yet. imx8mplus is in the plan.
                    • S Offline
                      serene @veye_xumm
                      What I meant was, on that product description (CS-TX2-XAVIER-nCAM-IMX385), it says that it supports Raspberry Pi. But you mentioned that Raspberry Pi doesn't support 4 cameras.
                      Could you clarify what it means?
                        veye_xumm @serene
                        @serene
                        Sorry, that was a mistake. CS-TX2-XAVIER-nCAM-IMX385 is designed only for TX2 and agx xavier.
                        This kit takes VEYE-MIPI-IMX385 as its core and makes an adapter board, which supports many platforms.
                        • S Offline
                          sophiajackson22
                          Hi, Did you check e-con Systems' FPD-Link camera? It has interesting features like Global shutter, onboard ISP, up to 15m coaxial cable support, and many more.
                          https://www.e-consystems.com/nvidia-cameras/jetson-agx-orin-cameras/ar0234-global-shutter-fpd-link-iii-synchronized-multi-camera.asp
                            veye_xumm @sophiajackson22
                            @sophiajackson22 Thank you for the information, I will keep an eye on it.
