    Is there 4 camera system for CS-FPD-CAM Series?
    12 Posts 3 Posters 6.7k Views 1 Watching
    • S Offline
      serene @veye_xumm
      Thank you for the prompt response.
      How about for GMSL2?
        veye_xumm @serene
        @serene We do not have GMSL2 products.
        • S Offline
          serene @veye_xumm
          Thank you. How about MIPI CS-2?
          Do you have a set of breakout board with 4 cameras that is compatible with Jetson (Nano and TX2) and Raspberry Pi equivalent - i.e. ASUS Tinkerboard (RK3399) and NXP iMX8M SBC?
            veye_xumm @serene
            @serene
            Hello, I think this first depends on whether the motherboard support, rather than the camera can access.
            For example: Jetson,nano,imx8m,rk3399 and rpi, they do not support 4 mipi csi-2 interfaces.
            For TX2, yes.
            http://wiki.veye.cc/index.php/CS-TX2-XAVIER-nCAM_Series
            • S Offline
              serene @veye_xumm
              Thank you.
              I found CS-TX2-XAVIER-nCAM-IMX385 in Amazon:
              Amazon - CS-TX2-XAVIER-nCAM-IMX385
              On the description it says:
              "Support Raspberry Pi Zero & W,Pi 4,3 b+,Pi 3, Pi CM. Jetson Nano, Xavier NX."
              Btw, how about with UCM-iMX8PLUS that has 2x MIPI-CSI, 4 data lanes?
                veye_xumm @serene
                @serene
                Yes, this is our product.
                We don't have access to UCM-iMX8PLUS yet. imx8mplus is in the plan.
                • S Offline
                  serene @veye_xumm
                  What I meant was, on that product description (CS-TX2-XAVIER-nCAM-IMX385), it says that it supports Raspberry Pi. But you mentioned that Raspberry Pi doesn't support 4 cameras.
                  Could you clarify what it means?
                    veye_xumm @serene
                    @serene
                    Sorry, that was a mistake. CS-TX2-XAVIER-nCAM-IMX385 is designed only for TX2 and agx xavier.
                    This kit takes VEYE-MIPI-IMX385 as its core and makes an adapter board, which supports many platforms.
                    • S Offline
                      sophiajackson22
                      Hi, Did you check e-con Systems' FPD-Link camera? It has interesting features like Global shutter, onboard ISP, up to 15m coaxial cable support, and many more.
                      https://www.e-consystems.com/nvidia-cameras/jetson-agx-orin-cameras/ar0234-global-shutter-fpd-link-iii-synchronized-multi-camera.asp
                        veye_xumm @sophiajackson22
                        @sophiajackson22 Thank you for the information, I will keep an eye on it.
