    I2C IR-day/night mode
    18 Posts 2 Posters 5.2k Views 2 Watching
    • R Offline
      rob77
      i see my confusion now from the wiki that they are bus numbers 😛
      however i can not seem to find the i2c bus for the camera, everything should be connected correctly but command i2cdetect -y -r 1 is not finding anything even tho it is connect to bus 1
      and i am now also confused on how to use the cmd sudo ./veye5_mipi_i2c.sh -w -f daynightmode -p1 [0,2]
      please tell me how to do this 😅 sorry for being noob.
        veye_xumm @rob77
        @rob77 said in I2C IR-day/night mode:
        IMX385 wiki J7 are the Auxiliary IIC
        Please do not use this IIC, the main 15pin FFC cable has an IIC bus already.
        i2cdetect -y -r 1
        Do not use 1 here, use the correct i2c bus number corresponding to your board.
        1.2.3 Nano B01
        i2c num 7 or 8
        1.2.4 Nano A02, Nano 2GB
        i2c bus number is 6.
        • R Offline
          rob77 @veye_xumm
          @veye_xumm ah i see, i was mistaken thinking it used another I2C conection, cool i unpluged the Aux IIC and did a check, i have a nano B01 and checked the i2cdetect bus 7 and 8 and yep it found it connected, strangely bus 6 is also active even tho nothing is being used on it i think. that solves that.
          my next problem is useing the day/night comand, im just not sure how to use it as veye_mipi_i2c.sh dosent do anything.
          my goal is while the camera is on that i can switch between IR filter on and off easly.
            veye_xumm @rob77
            @rob77
            http://wiki.veye.cc/index.php/VEYE-MIPI-290/327_i2c/#daynightmode
            ./veye_mipi_i2c.sh -w -f daynightmode -p1 0xFF or 0x FE -b 7 or 8
            • R Offline
              rob77 @veye_xumm
              @veye_xumm thank you for that i tryed ./veye_mipi_i2c.sh -w -f daynightmode -p1 0xFE -b 7 and 8 to get the ir mode but it still dosent seem to work. i end up getting
              their is probably a step im missing due to still being new to the nano.
                veye_xumm @rob77
                @rob77
                http://wiki.veye.cc/index.php/VEYE_CS_Camera_for_Jetson_TX2#Using_i2c_script_to_modify_camera_parameters
                part 4.3
                • R Offline
                  rob77 @veye_xumm
                    veye_xumm @rob77
                    @rob77 no
                    • R Offline
                      rob77 @veye_xumm
                      @veye_xumm ok.
                      running the files just ends with error no such file or directory. ive tryed running them in terminal and vim with no luck. there is clearly something im missing or not understanding, unlike the raspberry pi you have to enable ./enable_i2c_vc.sh but on jetson nano it is already enabled meaning first steps are not required, so i continue with commands that should work but for some reason are not. is there another directory the files are ment to go in? or is there another way to control day/night mode?
                        veye_xumm @rob77
                        @rob77
                        This is a common knowledge of linux.
                        • R Offline
                          rob77 @veye_xumm
                          i have the files and tryed this.
                          rob@rob-desktop:~$ ./veye_mipi_i2c.sh
                          bash: ./veye_mipi_i2c.sh: No such file or directory
                          rob@rob-desktop:~$ '/home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh'
                          /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh: line 1: $'\r': command not found
                          /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh: line 3: $'\r': command not found
                          /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh: line 7: $'\r': command not found
                          /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh: line 8: $'\r': command not found
                          /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh: line 9: $'\r': command not found
                          /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh: line 10: $'\r': command not found
                          /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh: line 11: syntax error near unexpected token `$'\r''
                          /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh: line 11: `print_u'age()
                          rob@rob-desktop:~$
                          i thought maybe it needed a dynamic loader so i did a check.
                          rob@rob-desktop:~$ ldd '/home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh'
                          	not a dynamic executable
                          rob@rob-desktop:~$ file '/home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh'
                          /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh: ISO-8859 text, with CRLF line terminators
                            veye_xumm @rob77
                            @rob77
                            first
                            • R Offline
                              rob77 @veye_xumm
                              rob@rob-desktop:~$ cd /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/
                              rob@rob-desktop:~/nvidia_jetson_veye_bsp/i2c_cmd/bin$ ./veye_mipi_i2c.sh
                              ./veye_mipi_i2c.sh: line 1: $'\r': command not found
                              ./veye_mipi_i2c.sh: line 3: $'\r': command not found
                              ./veye_mipi_i2c.sh: line 7: $'\r': command not found
                              ./veye_mipi_i2c.sh: line 8: $'\r': command not found
                              ./veye_mipi_i2c.sh: line 9: $'\r': command not found
                              ./veye_mipi_i2c.sh: line 10: $'\r': command not found
                              ./veye_mipi_i2c.sh: line 11: syntax error near unexpected token `$'\r''
                              '/veye_mipi_i2c.sh: line 11: `print_usage()
                              rob@rob-desktop:~/nvidia_jetson_veye_bsp/i2c_cmd/bin$ ./veye_mipi_i2c.sh -w -f daynightmode -p1 0xFE -b7
                                veye_xumm @rob77
                                @rob77
                                Please try this.
                                sudo apt install dos2unix
                                dos2unix ./veye_mipi_i2c.sh
                                • R Offline
                                  rob77 @veye_xumm
                                  @veye_xumm thanks that fixd the file into unix and i was able to open it. i then enter the day/night command
                                  should be root!
                                  it says should be root? so i redo it as root superuser, but got file/directory error. i tryed other types of commands but getting same error.
                                  rob@rob-desktop:~/nvidia_jetson_veye_bsp/i2c_cmd/bin$ sudo -i ./veye_mipi_i2c.sh -w -f daynightmode -p1 0xFE
                                  [sudo] password for rob:
                                  -bash: ./veye_mipi_i2c.sh: No such file or directory
                                  • R Offline
                                    rob77
                                    JUST fixed it 😊 sudo -s 😊
                                    want to say thank you for your help and patience with me, a person who has very little experience using linux. the camera is perfect for my project and i will be using it to learn more.
                                      veye_xumm @rob77
                                      @rob77 You are welcome.
