    I2C IR-day/night mode
    18 Posts 2 Posters 5.2k Views 2 Watching
    • R Offline
      rob77 @veye_xumm
      @veye_xumm thank you for that i tryed ./veye_mipi_i2c.sh -w -f daynightmode -p1 0xFE -b 7 and 8 to get the ir mode but it still dosent seem to work. i end up getting
      their is probably a step im missing due to still being new to the nano.
        veye_xumm @rob77
        @rob77
        http://wiki.veye.cc/index.php/VEYE_CS_Camera_for_Jetson_TX2#Using_i2c_script_to_modify_camera_parameters
        part 4.3
        • R Offline
          rob77 @veye_xumm
            veye_xumm @rob77
            @rob77 no
            • R Offline
              rob77 @veye_xumm
              @veye_xumm ok.
              running the files just ends with error no such file or directory. ive tryed running them in terminal and vim with no luck. there is clearly something im missing or not understanding, unlike the raspberry pi you have to enable ./enable_i2c_vc.sh but on jetson nano it is already enabled meaning first steps are not required, so i continue with commands that should work but for some reason are not. is there another directory the files are ment to go in? or is there another way to control day/night mode?
                veye_xumm @rob77
                @rob77
                This is a common knowledge of linux.
                • R Offline
                  rob77 @veye_xumm
                  i have the files and tryed this.
                  rob@rob-desktop:~$ ./veye_mipi_i2c.sh
                  bash: ./veye_mipi_i2c.sh: No such file or directory
                  rob@rob-desktop:~$ '/home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh'
                  /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh: line 1: $'\r': command not found
                  /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh: line 3: $'\r': command not found
                  /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh: line 7: $'\r': command not found
                  /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh: line 8: $'\r': command not found
                  /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh: line 9: $'\r': command not found
                  /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh: line 10: $'\r': command not found
                  /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh: line 11: syntax error near unexpected token `$'\r''
                  /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh: line 11: `print_u'age()
                  rob@rob-desktop:~$
                  i thought maybe it needed a dynamic loader so i did a check.
                  rob@rob-desktop:~$ ldd '/home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh'
                  	not a dynamic executable
                  rob@rob-desktop:~$ file '/home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh'
                  /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh: ISO-8859 text, with CRLF line terminators
                    veye_xumm @rob77
                    @rob77
                    first
                    • R Offline
                      rob77 @veye_xumm
                      rob@rob-desktop:~$ cd /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/
                      rob@rob-desktop:~/nvidia_jetson_veye_bsp/i2c_cmd/bin$ ./veye_mipi_i2c.sh
                      ./veye_mipi_i2c.sh: line 1: $'\r': command not found
                      ./veye_mipi_i2c.sh: line 3: $'\r': command not found
                      ./veye_mipi_i2c.sh: line 7: $'\r': command not found
                      ./veye_mipi_i2c.sh: line 8: $'\r': command not found
                      ./veye_mipi_i2c.sh: line 9: $'\r': command not found
                      ./veye_mipi_i2c.sh: line 10: $'\r': command not found
                      ./veye_mipi_i2c.sh: line 11: syntax error near unexpected token `$'\r''
                      '/veye_mipi_i2c.sh: line 11: `print_usage()
                      rob@rob-desktop:~/nvidia_jetson_veye_bsp/i2c_cmd/bin$ ./veye_mipi_i2c.sh -w -f daynightmode -p1 0xFE -b7
                        veye_xumm @rob77
                        @rob77
                        Please try this.
                        sudo apt install dos2unix
                        dos2unix ./veye_mipi_i2c.sh
                        • R Offline
                          rob77 @veye_xumm
                          @veye_xumm thanks that fixd the file into unix and i was able to open it. i then enter the day/night command
                          should be root!
                          it says should be root? so i redo it as root superuser, but got file/directory error. i tryed other types of commands but getting same error.
                          rob@rob-desktop:~/nvidia_jetson_veye_bsp/i2c_cmd/bin$ sudo -i ./veye_mipi_i2c.sh -w -f daynightmode -p1 0xFE
                          [sudo] password for rob:
                          -bash: ./veye_mipi_i2c.sh: No such file or directory
                          • R Offline
                            rob77
                            JUST fixed it 😊 sudo -s 😊
                            want to say thank you for your help and patience with me, a person who has very little experience using linux. the camera is perfect for my project and i will be using it to learn more.
                              veye_xumm @rob77
                              @rob77 You are welcome.
