    /dev/video0 not found and in dmesg there is no "probing v4l2 sensor\n"
    14 Posts 2 Posters 10.2k Views 1 Watching
    • C Offline
      chjchoi @veye_xumm
      @veye_xumm Thank you.
      1. It's on the Jetson TX2 official Nvidia devkit.
      2. there is something wrong with your document "VEYE CS Camera for Jetson TX2" method:
      Jetpack 4.6.3 installed devkit + Image to /boot and dtb installation with ./flash.sh -k kernel-dtb jetson-tx2 mmcblk0p1
      the Image is from nvidia_jetson_veye_bsp/kernel_image/Image_l4t_r32.7.1_veyecam.tar.gz
      and it is copied Target(devkit) /boot/
      the dtb is tegra186-quill-p3310-1000-c03-00-base.dtb and it is from jetson_veye_bsp/dtbs/TX2/JetPack_4.6_Linux_JETSON_TX2_TARGETS/"dts dtb"/VEYE-MIPI-327-fpdlink
      and copied to Linux_of_Tegran/kernel/dtb/ and
      Linux_for_Tegra $ sudo ./flash.sh -k kernel-dtb jetson-tx2 mmcblk0p1
      Then the Target shows only black screen and does not show Ubuntu Gnome shell.
      1. So, I have downloaded the sources r32.7.3 by $sudo ./soure_sync.sh and according to your documents "VEYE CS Camera source for Jetson" and copied Image and c03 base dtb to Linux_for_Tegra/kernel and .../dtb and $./flash.sh jetson-tx2 mmcblk0p1
        then Target shows ubuntu gnome shell but the dmesg shows that only I have written..
      C veye_xummV 2 Replies Last reply Reply Quote 0
      • C Offline
        chjchoi @chjchoi
        @chjch The only clue that I found at first method trial,
        it shows some error message about docker starting .
        • C Offline
          chjchoi @chjchoi
          @chjchoi I'm not familiar to docker system. because I'm out of date old engineer.
          Oh, docker manage the version and If in all 4.6.1 environment there is no problem I have checked.
          but your solutions and documents are not for 4.6.3
          and I don't know why camera drivers of 4.6.3 does not evoked when init.
          Please updates your solution to 4.6.3 please.
          Thank you
          • C Offline
            chjchoi @chjchoi
            [0_1675611757566_screenShot.tbz2](Uploading 100%) But the Image from your bsp only works well
            With the Image that I have made on 4.6.1 environment , there is the same result that
            the veyecam.c does not exert as the dmesg that i have written.
            On which conditon and .config do your build the Image?
            Thank you.
            [0_1675611365954_dts_failed_cam_driver.dts](Uploading 100%)
            • C Offline
              chjchoi @chjchoi
              @chjchoi I have build the Image according to the "VEYE CS Camera source for Jetson"
              and with the tegra_veyecam_defconfig of kernel_veyecam_config_r32.7.1
              CROSS_COMPILE is from gcc-linaro-7.3.1-2018.05-linux
              • C Offline
                chjchoi @veye_xumm
                @veye_xumm Sorry I have confused..
                at the /lib/moduels/4.9.../modules.builtin
                there is no veyecam
                there are drivers from Linux_for_Tegra/sources/kernel/nvidia/drivers/media/i2c/
                not from Linux_for_Tegra/sources/kernel/kernel-4.9/drivers/media/i2c/
                So, there are two same items when make menuconfig and only the first was reflected..
                I don't know how to deals.
                first, I will exclude the nvidia folder's and retry..
                Thank you.
                • C Offline
                  chjchoi @chjchoi
                  @chjchoi
                  I have found there are 2 folder at /lib/modules .
                  I think one is for real built-in modules and the other is for modules dependent to other modules.
                  I guess veyecam is located at the folder for dependent built-in modules.
                  when sudo apt-get update and sudo apt-get install v4l2*,
                  installation of v4l2* makes depmod situation and then veyecam is probed and driver is loaded I guess.
                  With the Image from BSP does this process well and depmod
                  but for my case of Image that was built by me, seems not doing this process.
                  tegra_veyecam_defconfig is from your BSP,
                  which makes the difference?
                  Thanks.
                    veye_xumm @chjchoi
                    @chjchoi
                    @chjchoi said in /dev/video0 not found and in dmesg there is no "probing v4l2 sensor\n":
                    For the original system version of the motherboard, we have provided the corresponding Image and dtb. But Jetpack 4.6.3 is the version that just came out and we haven't had time to port the driver yet.
                    We suggest you to re-burn the motherboard to Jetpack4.6.2 first, then use the corresponding Image and dtb.
                    • C Offline
                      chjchoi @veye_xumm
                      Dear,
                      Do you have any ideas on the attached photo image?
                      first time ds90ub954 has successed but at the point it fails to access to 0x30 and
                      it causes camera drivers access failure I think.
                      • C Offline
                        chjchoi @chjchoi
                        @chjchoi On the last photos .. the chip information and not important to functioning.
                        So iwill block the error and will go ahead of test.
                          veye_xumm @chjchoi
                          @chjchoi I think this place means that the 954 chip is not detected properly on the i2c.
