    I2c tools failed
    21 Posts 2 Posters 6.8k Views 1 Watching
    • V Offline
      Viktor
      Trying to set fixed fps. First try to read:
      sudo ./veye_mipi_i2c.sh -r -f devid
      ====I2C write:<0x3b> <0x7> <0xfe>====
      device id is 0x 0
      Failed to write register index 0
      Device is on the bus 6 addr 3b present UU
      Have copied i2c folder from git bsp for veye and chmod +x.
      Dmesg:
      [25639.695508] i2c i2c-6: Setting clock rate 100000 on next transfer
      [25639.698513] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x3b
      [25639.711008] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x3b
      [25639.720439] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x3b
      [25639.731618] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x3b
      [25639.760191] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x3b
      • V Offline
        Viktor @Viktor
        Have added -d -b:
        sudo ./veye_mipi_i2c.sh -r -f devid -b 6 -d 0x3b
        device id is 0xc8
        sudo ./veye_mipi_i2c.sh -r -f hdver -b 6 -d 0x3b
        hardware version is 0xc8
        Direct bin run:
        out=$(./i2c_read 6 0x3b 0x01)
        echo $out
        Using i2C device /dev/i2c-6 ====I2C read:<0x3b> <0x1> <0x1>==== Read i2c addr 3B
        Tell me please, what is default AE/framerate state?
        • V Offline
          Viktor @Viktor
          Tried bus 7:
          sudo ./veye_mipi_i2c.sh -r -f devid -b 7
          device id is 0x 6
          sudo ./veye_mipi_i2c.sh -r -f hvdev -b 7
          sudo ./veye_mipi_i2c.sh -r -f hdver -b 7
          hardware version is 0x 3
          It works now.
          • V Offline
            Viktor @Viktor
            I wrote mshutter to 0x41 for constant 25 fps, am i right?
            Cause in low light i have high exposure.
            night
              veye_xumm @Viktor
              @viktor
              This camera is fixed frame rate. You do not need to change the exposure time for that.
              I suggest you use default parameters first, and change if necessary.
              Please use videofmt for 25fps. It is 30fps by default.
              http://wiki.veye.cc/index.php/VEYE-MIPI-290/327_i2c/zh#videoformat
              • V Offline
                Viktor @veye_xumm
                @veye_xumm Ok, I tryed wdmode, Pal and mshutter. And now it is good night picture.
                • V Offline
                  Viktor @Viktor
                  Hi Meng,
                  Can you explain what parameter makes that effect with multiple shadows on image?
                  alt text
                    veye_xumm @Viktor
                    @viktor
                    Please try close wdr.
                    http://wiki.veye.cc/index.php/VEYE-MIPI-290/327_i2c/zh#wdrmode
                    Because WDR uses two frames of data at different time points to be merged into one frame.
                    If the exposure time is long and the vehicle is fast, there will be problems in your image.You can also try to reduce ghosting by reducing the exposure time without turning off WDR.
                    • V Offline
                      Viktor @veye_xumm
                      Ok, and which parameter controls exposure in i2c?
                      Like on CS?
                      ./cs_mipi_i2c.sh -w -f aetime -p1 XXX
                      range:(100,1/framerate]
                        veye_xumm @Viktor
                        @viktor
                        The parameters of the veye series are not as flexible as those of the cs series, and the parameter you want is mshutter.
                        • V Offline
                          Viktor @veye_xumm
                          Ok. Have tried mshutter, but shadows presents in all cases.
                          If i write mshutter 0x46( 1/1000 ) i expect very short exposure and more dark image. It is ok because we are using light at night.
                          But at daylight frame is over exposured. So works only 0x40 (auto shutter). Then at night we have this effect: http://forum.veye.cc/post/185
                          Here is only mshutter auto:
                          alt text
                            veye_xumm @Viktor
                            @viktor said in I2c tools failed:
                            Pls try close wdr as I suggested before.
                            • V Offline
                              Viktor @veye_xumm
                              Wdr already closed.
                              May be i should restart system?
                              Pal i set before run programm.
                              But other controls can i set before too?
                                veye_xumm @Viktor
                                @viktor
                                1. pls post your cmd to close wdr.
                                2. pls try close 3d denoise.
                                V 2 Replies Last reply Reply Quote 0
                                • V Offline
                                  Viktor @veye_xumm
                                  • V Offline
                                    Viktor @veye_xumm
                                    Here is cmd:
                                    sudo ./veye_mipi_i2c.sh -w -f videoformat -p1 PAL
                                    sudo ./veye_mipi_i2c.sh -w -f wdrmode -b 7 -p1 0x00
                                    sudo ./veye_mipi_i2c.sh -w -f mshutter -b 7 -p1 0x40
                                    alt text
                                    So it is a daylight. Sensor has auto shutter mode, cars speed is slow because it is parking barrier.
                                    Why is double image?
                                      veye_xumm @Viktor
                                      please add this one :
                                      ./veye_mipi_i2c.sh -w -f denoise -p1 x00 -b7
                                      • V Offline
                                        Viktor @veye_xumm
                                        Thanks. Looks like fixed.
                                        alt text
                                          veye_xumm @Viktor
                                          @viktor
                                          OK. So 3D denoise is the key. You can try to have a low level 2d denoise.
                                          • V Offline
                                            Viktor @veye_xumm
                                            Thank you Meng.
