    jetson nano 2GB无法识别相机 MV-MIPI-IMX264M
    39 Posts 2 Posters 23.7k Views 1 Watching
    • H Offline
      hmj
        veye_xumm @hmj
        @hmj 请按照part3.7做一下检查。
        • H Offline
          hmj
          ls /proc/device-tree/host1x/i2c@546c0000/
          '#address-cells' clock-frequency compatible iommus phandle resets '#size-cells'
          avdd_dsi_csi-supply clock-names ina3221x@40 linux,phandle reg scl-gpio status
          bus-pullup-supply clocks interrupts name reset-names sda-gpio
          ls /sys/bus/i2c/drivers
          bq27xxx-battery i2c-ds90ub954 imx477 lp855x mvcam pca953x rt5659 tegra_edid veye327
          cs53l30 imx219 ina219x lt6911uxc nct1008_nct72 pca954x rtc-rx8025 tmpm32xi2c veyecam
          cssc132 imx268 ina230x max77620 ov10823 pca9570 sgtl5000 tps65132 veye_imx335
          csx307 imx318 ina3221x max9295 ov23850 'PEX9749 thermal sensor' stepper_pca ucsi_ccg
          dummy imx390 lc898212 max9296 ov9281 rt5640 tas2552 usb3503
            veye_xumm @hmj
            6:从https://github.com/veyeimaging/nvidia_jetson_veye_bsp/tree/master/dtbs/Nano/JetPack_4.6.1_Linux_JETSON_NANO_TARGETS/dts dtb/MV-MIPI-MVCAM/ 下载tegra210-p3448-0003-p3542-0000.dtb 并替换官方dtb.
            dtb显示不正常。讲一下上面这步你是怎么做的?
            • H Offline
              hmj @veye_xumm
              我先把整个 /boot 压缩备份,
              用浏览器在github上下载zip包, 提取的tegra210-p3448-0003-p3542-0000.dtb,
              md5sum /tmp/tegra210-p3448-0003-p3542-0000.dtb
              e82e10f334ffc7b881e1549a1b100437 /tmp/tegra210-p3448-0003-p3542-0000.dtb
              直接拷贝覆盖/boot的那个同名文件,同时不确定是否到位, 也同步替换/boot//boot/kernel_tegra210-p3448-0003-p3542-0000.dtb.
              最后reboot
                veye_xumm @hmj
                @hmj 替换dtb的话,我们建议的是按照wiki的步骤,修改一下启动文件,配置FDT。参考一下3.5.6.
                • H Offline
                  hmj @veye_xumm
                    veye_xumm @hmj
                    @hmj 好哒,棒棒哒
                    • H Offline
                      hmj @veye_xumm
                      我需要一个C的开发手册, 方便开发应用,谢谢!
                        veye_xumm @hmj
                        @hmj 请参考这篇文章的part7和part8
                        • H Offline
                          hmj @veye_xumm
                          如果用作硬触发模式,如何设置,相机的曝光时间?
                          • H Offline
                            hmj @veye_xumm
                            v4l2-ctl -d /dev/video0 --set-fmt-video=width=2432,height=2048,pixelformat=GREY --stream-mmap --stream-count=1 --stream-to=raw.raw
                            我用gpio触发, 硬件链接没问题, 量到正常电平,但是并没有获取到图片,还需要哪些设置?
                              veye_xumm @hmj
                              https://wiki.veye.cc/index.php/Mv_mipi_i2c.sh_user_guide#metime
                              • H Offline
                                hmj @veye_xumm
                                关于ROI, 有几个问题请教一下
                                  veye_xumm @hmj
                                  @hmj
                                  不需要。
                                  不需要重复设置。
                                  • H Offline
                                    hmj @veye_xumm
                                    如何配置驱动,才能让用户无感无缝切换图片.
                                      veye_xumm @hmj
                                      • H Offline
                                        hmj @veye_xumm
                                        这么做是真实硬件ROI, 会带来FPS得提升吧?
                                          veye_xumm @hmj
                                          @hmj
                                          • H Offline
                                            hmj @veye_xumm
