    有关veye_mvcam驱动编译的问题
    11 Posts 3 Posters 6.9k Views 1 Watching
    • 潘 Offline
      潘阳刚
      我想在RK3588s (khadas的edge2开发板)上使用RAW MIPI SC132M,按照步骤修改了设备树文件,将veye_mvcam.c和veye_cam.h文件放到了对应的路径下,在编译过程中报错了,log如下。
      make[1]: Entering directory '/home/pyg/project/khadas/fenix/build/linux'
        SYNC    include/config/auto.conf.cmd
        CALL    scripts/atomic/check-atomics.sh
        CALL    scripts/checksyscalls.sh
        GEN     usr/initramfs_data.cpio
        SHIPPED usr/initramfs_inc_data
        AS      usr/initramfs_data.o
        AR      usr/built-in.a
        CHK     include/generated/compile.h
        UPD     include/generated/compile.h
        CC      init/version.o
        AR      init/built-in.a
        UPD     kernel/config_data
        GZIP    kernel/config_data.gz
        CC      kernel/configs.o
        AR      kernel/built-in.a
        CC      drivers/media/i2c/veye_mvcam.o
      drivers/media/i2c/veye_mvcam.c: In function 'mvcam_ioctl':
      drivers/media/i2c/veye_mvcam.c:859:10: error: 'RKMODULE_GET_CSI_DSI_INFO' undeclared (first use in this function); did you mean 'RKMODULE_GET_CHANNEL_INFO'?
        859 |     case RKMODULE_GET_CSI_DSI_INFO:
      drivers/media/i2c/veye_mvcam.c:859:10: note: each undeclared identifier is reported only once for each function it appears in
      drivers/media/i2c/veye_mvcam.c:860:17: error: 'RKMODULE_CSI_INPUT' undeclared (first use in this function)
        860 |   *(int *)arg = RKMODULE_CSI_INPUT;
      drivers/media/i2c/veye_mvcam.c: In function 'mvcam_compat_ioctl32':
      drivers/media/i2c/veye_mvcam.c:918:10: error: 'RKMODULE_GET_CSI_DSI_INFO' undeclared (first use in this function); did you mean 'RKMODULE_GET_CHANNEL_INFO'?
        918 |     case RKMODULE_GET_CSI_DSI_INFO:
      drivers/media/i2c/veye_mvcam.c:919:17: error: 'RKMODULE_CSI_INPUT' undeclared (first use in this function)
        919 |   *(int *)arg = RKMODULE_CSI_INPUT;
      make[4]: *** [scripts/Makefile.build:273: drivers/media/i2c/veye_mvcam.o] Error 1
      make[3]: *** [scripts/Makefile.build:516: drivers/media/i2c] Error 2
      make[3]: *** Waiting for unfinished jobs....
      make[2]: *** [scripts/Makefile.build:516: drivers/media] Error 2
      make[2]: *** Waiting for unfinished jobs....
      make[1]: *** [Makefile:1917: drivers] Error 2
      make[1]: Leaving directory '/home/pyg/project/khadas/fenix/build/linux'
      请问怎么才能让veye_mvcam.o编译通过,谢谢。
        veye_xumm @潘阳刚
        @潘阳刚
        我们没有对接过edge2板子,看起来是khadas的kernel版本不支持报错的这几个ioctl命令。
        你可以参考一下khadas平台原来支持的sensor的驱动,修改一下veye_mvcam.c的代码。
        ——比如注掉这几个ioctl,或者以其他方式实现这个功能。
        潘 1 Reply Last reply Reply Quote 0
        • 潘 Offline
          潘阳刚 @veye_xumm
          @veye_xumm 您好,我注释掉了有关RKMODULE_GET_CSI_DSI_INFO的case,编译通过了,我连接好相机后却没能识别到相机。我使用的是i2c-3和i2c-4。
          [   10.906532] mvcam 3-003b: veye mv series camera driver version: 01.01.04
          [   11.909428] mvcam: mvcam_read: Reading register 0x04 failed
          [   11.909481] mvcam 3-003b: failed to read chip id
          [   11.909905] mvcam 4-003b: veye mv series camera driver version: 01.01.04
          [   12.912928] mvcam: mvcam_read: Reading register 0x04 failed
          [   12.913033] mvcam 4-003b: failed to read chip id
          我觉得我的硬件连线没有问题,与电路原理图一一对应,通过定制的软线排连接。图像传感器也没有发热。我希望先排查软件方面的问题,但是我不知道该从何处开始排查起,或者有哪些可以使用的工具。图片里左侧为开发板相机接口线序,右侧为SC132M接口线序。
          设备树相关代码:
          &csi2_dcphy0 {
          	status = "okay";
          	ports {
          		#address-cells = <1>;
          		#size-cells = <0>;
          		port@0 {
          			reg = <0>;
          			#size-cells = <0>;
          			mipi_in_dcphy0: endpoint@1 {
          				reg = <1>;
          				remote-endpoint = <&mvcamb_out0>;
          				data-lanes = <1 2>;
          		port@1 {
          			reg = <1>;
          			#size-cells = <0>;
          			csidcphy0_out: endpoint@0 {
          				reg = <0>;
          				remote-endpoint = <&mipi0_csi2_input>;
          &mipi_dcphy0 {
          	status = "okay";
          &csi2_dcphy1 {
          	status = "okay";
          	ports {
          		#size-cells = <0>;
          		port@0 {
          			reg = <0>;
          			#size-cells = <0>;
          			mipi_in_dcphy1: endpoint@1 {
          				reg = <1>;
          				remote-endpoint = <&mvcamf_out1>;
          				data-lanes = <1 2>;
          		port@1 {
          			reg = <1>;
          			#size-cells = <0>;
          			csidcphy1_out: endpoint@0 {
          				reg = <0>;
          				remote-endpoint = <&mipi1_csi2_input>;
          &mipi_dcphy1 {
          	status = "okay";
          &csi2_dphy0 {
          	status = "okay";
          	ports {
          		#size-cells = <0>;
          		port@0 {
          			reg = <0>;
          			#size-cells = <0>;
          				reg = <1>;
          				remote-endpoint = <&imx415c_out0>;
          				data-lanes = <1 2 3 4>;
          		port@1 {
          			reg = <1>;
          			#size-cells = <0>;
          			csidphy0_out: endpoint@0 {
          				reg = <0>;
          &csi2_dphy0_hw {
          	status = "okay";
          &i2c4 {
          	status = "okay";
          	pinctrl-names = "default";
          	pinctrl-0 = <&i2c4m3_xfer>;
          	dw9714b: dw9714b@c {
          		status = "okay";
          		reg = <0x0c>;
          		pinctrl-names = "focusb_gpios";
          		pinctrl-0 = <&focusb_gpio>;
          		focus-gpios = <&gpio1 RK_PA0 GPIO_ACTIVE_HIGH>;
          		rockchip,vcm-start-current = <20>;
          		rockchip,vcm-rated-current = <76>;
          		rockchip,vcm-step-mode = <0>;
          	imx415b: imx415b@1a {
          		compatible = "sony,imx415";
          		status = "okay";
          		reg = <0x1a>;
          		clock-names = "xvclk";
          		pinctrl-names = "default", "camb_gpios";
          		pinctrl-0 = <&mipim1_camera1_clk>, <&camb_gpio>;
          		rockchip,grf = <&sys_grf>;
          		pwdn-gpios = <&gpio1 RK_PB3 GPIO_ACTIVE_HIGH>;
          		lens-focus = <&dw9714b>;
          		port {
          			imx415b_out0: endpoint {
          				remote-endpoint = <&mipi_in_dcphy0>;
          	mvcamb: mvcamb@3b{
          		compatible = "veye,mvcam";
          		reg = <0x3b>;
          		reset-gpios = <&gpio1 RK_PB2 GPIO_ACTIVE_HIGH>;//&gpio3 RK_PC4 GPIO_ACTIVE_HIGH
          		pwdn-gpios = <&gpio1 RK_PB3 GPIO_ACTIVE_HIGH>;//&gpio3 RK_PC1 GPIO_ACTIVE_HIGH
          		port {
          			mvcamb_out0: endpoint {
          					remote-endpoint = <&mipi_in_dcphy0>;//&mipidphy0_in_ucam0
          					data-lanes = <1 2>;
          &i2c3 {
          	status = "okay";
          	pinctrl-0 = <&i2c3m0_xfer>;
          	dw9714f: dw9714f@c {
          		status = "okay";
          		reg = <0x0c>;
          		pinctrl-names = "focusf_gpios";
          		pinctrl-0 = <&focusf_gpio>;
          		focus-gpios = <&gpio1 RK_PA1 GPIO_ACTIVE_HIGH>;
          		rockchip,camera-module-facing = "front";
          	imx415f: imx415f@1a {
          		status = "okay";
          		reg = <0x1a>;
          		clocks = <&cru CLK_MIPI_CAMARAOUT_M2>;
          		pinctrl-names = "default", "camf_gpios";
          		pinctrl-0 = <&mipim1_camera2_clk>, <&camf_gpio>;
          		reset-gpios = <&gpio3 RK_PC6 GPIO_ACTIVE_LOW>;
          		pwdn-gpios = <&gpio3 RK_PC5 GPIO_ACTIVE_HIGH>;
          		lens-focus = <&dw9714f>;
          		port {
          			imx415f_out1: endpoint {
          				remote-endpoint = <&mipi_in_dcphy1>;
          	mvcamf: mvcamf@3b{
          		reg = <0x3b>;
          		pinctrl-0 = <&mipim1_camera2_clk>;
          		reset-gpios = <&gpio3 RK_PC6 GPIO_ACTIVE_HIGH>;//&gpio3 RK_PC4 GPIO_ACTIVE_HIGH
          		pwdn-gpios = <&gpio3 RK_PC5 GPIO_ACTIVE_HIGH>;//&gpio3 RK_PC1 GPIO_ACTIVE_HIGH
          		port {
          			mvcamf_out1: endpoint {
          					remote-endpoint = <&mipi_in_dcphy1>;//&mipidphy0_in_ucam0
          					data-lanes = <1 2>;
          &i2c8 {
          	status = "okay";
          	pinctrl-0 = <&i2c8m2_xfer>;
          	dw9714c: dw9714c@c {
          		status = "okay";
          		reg = <0x0c>;
          		pinctrl-names = "focusc_gpios";
          		pinctrl-0 = <&focusc_gpio>;
          		focus-gpios = <&gpio1 RK_PA6 GPIO_ACTIVE_HIGH>;
          	imx415: imx415@1a {
          		reg = <0x1a>;
          		clocks = <&cru CLK_MIPI_CAMARAOUT_M3>;
          		pinctrl-names = "default", "camc_gpios";
          		pinctrl-0 = <&mipim1_camera3_clk>, <&camc_gpio>;
          		reset-gpios = <&gpio3 RK_PB4 GPIO_ACTIVE_LOW>;
          		pwdn-gpios = <&gpio1 RK_PA4 GPIO_ACTIVE_HIGH>;
          		lens-focus = <&dw9714c>;
          		port {
          			imx415c_out0: endpoint {
          &pinctrl {
          	cam {
          		camf_gpio: camf-gpio {
          			rockchip,pins =
          				<3 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>,
          				<3 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>;
          		camb_gpio: camb-gpio {
          			rockchip,pins =
          				<1 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>,
          				<1 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>;
          		camc_gpio: camc-gpio {
          			rockchip,pins =
          				<3 RK_PB4 RK_FUNC_GPIO &pcfg_pull_none>,
          				<1 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>;
          		focusb_gpio: focusb-gpio {
          			rockchip,pins =
          				<1 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>;
          		focusf_gpio: focusf-gpio {
          			rockchip,pins =
          				<1 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>;
          		focusc_gpio: focusc-gpio {
          			rockchip,pins =
          				<1 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>;
          &mipi0_csi2 {
          	status = "okay";
          	ports {
          		#size-cells = <0>;
          		port@0 {
          			reg = <0>;
          			#size-cells = <0>;
          			mipi0_csi2_input: endpoint@1 {
          				reg = <1>;
          				remote-endpoint = <&csidcphy0_out>;
          		port@1 {
          			reg = <1>;
          			#size-cells = <0>;
          			mipi0_csi2_output: endpoint@0 {
          				reg = <0>;
          				remote-endpoint = <&cif_mipi_in0>;
          &mipi1_csi2 {
          	status = "okay";
          	ports {
          		#size-cells = <0>;
          		port@0 {
          			reg = <0>;
          			#size-cells = <0>;
          			mipi1_csi2_input: endpoint@1 {
          				reg = <1>;
          				remote-endpoint = <&csidcphy1_out>;
          		port@1 {
          			reg = <1>;
          			#size-cells = <0>;
          			mipi1_csi2_output: endpoint@0 {
          				reg = <0>;
          				remote-endpoint = <&cif_mipi_in1>;
          &mipi2_csi2 {
          	status = "okay";
          	ports {
          		#size-cells = <0>;
          		port@0 {
          			reg = <0>;
          			#size-cells = <0>;
          				reg = <1>;
          		port@1 {
          			reg = <1>;
          			#size-cells = <0>;
          				reg = <0>;
          &rkcif {
          	status = "okay";
          &rkcif_mipi_lvds {
          	status = "okay";
          	port {
          		cif_mipi_in0: endpoint {
          			remote-endpoint = <&mipi0_csi2_output>;
          &rkcif_mipi_lvds_sditf {
          	status = "okay";
          	port {
          		mipi_lvds_sditf: endpoint {
          &rkcif_mipi_lvds1 {
          	status = "okay";
          	port {
          		cif_mipi_in1: endpoint {
          			remote-endpoint = <&mipi1_csi2_output>;
          &rkcif_mipi_lvds1_sditf {
          	status = "okay";
          	port {
          		mipi1_lvds_sditf: endpoint {
          			remote-endpoint = <&isp0_vir1>;
          &rkcif_mipi_lvds2 {
          	status = "okay";
          	port {
          		cif_mipi2_in0: endpoint {
          &rkcif_mipi_lvds2_sditf {
          	status = "okay";
          	port {
          		mipi_lvds2_sditf: endpoint {
          &rkcif_mmu {
          	status = "okay";
          &rkisp0 {
          	status = "okay";
          &isp0_mmu {
          	status = "okay";
          &rkisp0_vir0 {
          	status = "okay";
          	port {
          		#size-cells = <0>;
          		isp0_vir0: endpoint@0 {
          			reg = <0>;
          			remote-endpoint = <&mipi_lvds_sditf>;
          &rkisp0_vir1 {
          	status = "okay";
          	port {
          		#size-cells = <0>;
          		isp0_vir1: endpoint@0 {
          			reg = <0>;
          			remote-endpoint = <&mipi1_lvds_sditf>;
          &rkisp1 {
          	status = "okay";
          &isp1_mmu {
          	status = "okay";
          &rkisp1_vir0 {
          	status = "okay";
          	port {
          		#size-cells = <0>;
          		isp1_vir0: endpoint@0 {
          			reg = <0>;
            veye_xumm @潘阳刚
            @潘阳刚 现在显示i2c不通。
            你要检查两个。
            1. 测量一下供电是否正常。
            2. 我们的11脚,也就是power enable引脚,你要确认是否拉高了? 如果没有拉高,需要修改一下dts。
            • 潘 Offline
              潘阳刚 @veye_xumm
              @veye_xumm 11号引脚power enable需要多少V?我将该引脚拉高,电压表测量结果为1.8V,log显示没有检测到相机。我也检测了电源引脚,为3.3V,没有问题。
              • 潘 Offline
                潘阳刚 @潘阳刚
                @潘阳刚 根据veye为适配firefly开发板所制作的转接板所示,需要添加1.8V和3.3V的电平转换。RK3588s引脚电平为1.8V,直接采用软线排改变rk3588s引脚线序的方式不可取。
                  veye_xumm @潘阳刚
                  @潘阳刚 对的。我们的板子现在是3.3V标准的。i2c和power enable都是这个标准的。
                  • 潘 Offline
                    潘阳刚 @veye_xumm
                    @veye_xumm 有没有1.8V的其他图像传感器?
                      veye_xumm @潘阳刚
                      @潘阳刚 我们家的板子都是按照3.3V设计的。
                      • M Offline
                        m4416202
                        你好,我在SC130这个摄像头驱动移植时也遇到这个问题,一开始我注释掉了有关RKMODULE_GET_CSI_DSI_INFO的case,编译通过了,但是无法出图,相机寄存器读取正常;尝试从另外一个SDK里将rk_moudle.h的RKMODULE_GET_CSI_DSI_INFO拷贝过来,进行测试目前还是不行,请问你怎么解决的?
                          veye_xumm @m4416202
                          @m4416202 请问取图的时候有什么报错吗? dts是否已根据你的主板上的硬件做了调整?
