    How to change FPD-Link 3 Operating Mode (CSI-2 mode -> raw mode)
    FPD LINK III Camera
    2244
    • Y
      yongjin last edited by
      I want to change Operating mode (CSI-2 mode -> raw mode)
      How can I do this?
      I know the input mode of operation is controlled by the FPD3_MODE(Register 0x6D[1:0])
      How can I set the value of this MODE?
      please let me know the process..
      I'm using CS-FPD-XAVIER-nCAM Series DevKit and TI DS90UB913A-Q1 Camera.
        veye_xumm @yongjin last edited by
        @yongjin
        Since our camera module do not support raw output mode, I think it is meaningless to change the fpdlink mode to raw.
        Y 1 Reply Last reply Reply Quote 0
        • Y
          yongjin @veye_xumm last edited by
          @veye_xumm I have cam(TI DS90UB913A-Q1 serializer) which can be operated raw mode and I want adapt them to Jetson xavier via FPD-LINK3-2RX. Can you explain how to do it?
            @yongjin Because we do not do raw camera module, so we really do not have this kind of debugging experience. It should be just to adjust some registers.
            • Y
              @veye_xumm Can you explain how to adjust registers? I have no experience about that.
                @yongjin via i2c
                • Y
                  yongjin @veye_xumm last edited by yongjin
                  Hi Xumm.Unfortunately, I can't understand your meaning.
                  Please let me know more detail procedure.
                  one more If adjusting by I2C, it needs another special tool??
                  Please understand I'm beginner on this technique
                    @yongjin
                    I don't know what your current state of knowledge is. If you don't understand i2C, you don't understand fpdlink, you don't understand registers. I think you should first learn the basics and be able to understand the information and code we provide now, and then proceed to your next work.
                    Good luck.
