    关于IMX385抓图问题
    10 Posts 2 Posters 6.3k Views 1 Watching
    • T Offline
      teo.chan
      你好,我尝试制作FPC排线让 rock5b开发板能支持 IMX385, 设备树如下
      /dts-v1/;
      /plugin/;
      #include <dt-bindings/clock/rk3588-cru.h>
      #include <dt-bindings/power/rk3588-power.h>
      #include <dt-bindings/gpio/gpio.h>
      #include <dt-bindings/pinctrl/rockchip.h>
      	metadata {
      		title ="Enable VEYE CSI-2 Camera Modules";
      		compatible = "radxa,rock-5b";
      		category = "camera";
      		exclusive = "csi2_dphy0";
      		description = "Enable VEYE CSI-2 Camera Modules.";
      	fragment@0 {
      		target = <&i2c3>;
      		__overlay__ {
      			status = "okay";
      			#address-cells = <1>;
      			#size-cells = <0>;
      			veyecam2m: veyecam2m@3b{
      				status = "okay";
      				reg = <0x3b>;
      				clocks = <&cru CLK_MIPI_CAMARAOUT_M3>;
      				clock-names = "xvclk";
      				pinctrl-names = "default";
      				pinctrl-0 = <&mipim0_camera3_clk>;
      				pwdn-gpios = <&gpio1 RK_PB0 GPIO_ACTIVE_HIGH>;
      				reset-gpios = <&gpio4 RK_PA0 GPIO_ACTIVE_HIGH>;
      				port {
      					veyecam2m_out0: endpoint {
      						data-lanes = <1 2>;
      	fragment@1 {
      		target = <&csi2_dphy0_hw>;
      		__overlay__ {
      			status = "okay";
      	fragment@2 {
      		target = <&csi2_dphy0>;
      		__overlay__ {
      			status = "okay";
      			ports {
      				#size-cells = <0>;
      				port@0 {
      					reg = <0>;
      					#size-cells = <0>;
      						reg = <1>;
      						data-lanes = <1 2>;
      				port@1 {
      					reg = <1>;
      					#size-cells = <0>;
      					csidphy0_out: endpoint@0 {
      						reg = <0>;
      	fragment@3 {
      		target = <&mipi2_csi2>;
      		__overlay__ {
      			status = "okay";
      			ports {
      				#size-cells = <0>;
      				port@0 {
      					reg = <0>;
      					#size-cells = <0>;
      						reg = <1>;
      				port@1 {
      					reg = <1>;
      					#size-cells = <0>;
      						reg = <0>;
      	fragment@4 {
      		target = <&rkcif>;
      		__overlay__ {
      			status = "okay";
      	fragment@5 {
      		target = <&rkcif_mipi_lvds2>;
      		__overlay__ {
      			status = "okay";
      			firefly,yuv_camera;
      			port {
      				cif_mipi2_in0: endpoint {
      	fragment@6 {
      		target = <&rkcif_mipi_lvds2_sditf>;
      		__overlay__ {
      			status = "disabled";
      			port {
      				mipi_lvds2_sditf: endpoint {
      	fragment@7 {
      		target = <&rkcif_mmu>;
      		__overlay__ {
      			status = "okay";
      	fragment@8 {
      		target = <&isp0_mmu>;
      		__overlay__ {
      	fragment@9 {
      		target = <&rkisp0>;
      		__overlay__ {
      	fragment@10 {
      		target = <&rkisp0_vir0>;
      		__overlay__ {
      			port {
      				#size-cells = <0>;
      				isp0_vir0: endpoint@0 {
      					reg = <0>;
      开发板能够正确识别相机
      [    6.032099] veyecam2m 3-003b: veye camera driver version: 00.01.01
      [    6.032129] veyecam2m 3-003b: Failed to get power-gpios, maybe no use
      [    6.032183] veyecam2m 3-003b: Looking up avdd-supply from device tree
      [    6.032195] veyecam2m 3-003b: Looking up avdd-supply property in node /i2c@feab0000/veyecam2m@3b failed
      [    6.032227] veyecam2m 3-003b: supply avdd not found, using dummy regulator
      [    6.032336] veyecam2m 3-003b: Looking up dovdd-supply from device tree
      [    6.032348] veyecam2m 3-003b: Looking up dovdd-supply property in node /i2c@feab0000/veyecam2m@3b failed
      [    6.032364] veyecam2m 3-003b: supply dovdd not found, using dummy regulator
      [    6.032398] veyecam2m 3-003b: Looking up dvdd-supply from device tree
      [    6.032409] veyecam2m 3-003b: Looking up dvdd-supply property in node /i2c@feab0000/veyecam2m@3b failed
      [    6.032424] veyecam2m 3-003b: supply dvdd not found, using dummy regulator
      [    6.032457] veyecam2m 3-003b: could not get default pinstate
      [    6.032574] veyecam2m 3-003b: could not get sleep pinstate
      [    6.032676] veyecam2m 3-003b: Success to get veyecam2m endpoint data lanes, dts uses 2 lanes
      [    6.155079] veyecam2m 3-003b:  camera id is veyecam2m
      [    6.158461] veyecam2m 3-003b: sensor is IMX385
      [    6.158547] veyecam2m 3-003b: board type is ONE board
      [    6.160004] rockchip-csi2-dphy csi2-dphy0: dphy0 matches m00_b_veyecam2m 3-003b:bus type 5
      当我使用以下命令抓图的时候
      会报错
      [  162.928606] rockchip-mipi-csi2 fdd30000.mipi2-csi2: stream on, src_sd: 00000000e7b2a9e6, sd_name:rockchip-csi2-dphy0
      [  162.928674] rockchip-mipi-csi2 fdd30000.mipi2-csi2: stream ON
      [  164.876990] mipi2-csi2 ERR1:0x1000010 (fs/fe mis,vc: 0) (crc,vc: 0)
      [  164.877110] rkcif-mipi-lvds2: ERROR: csi size err, intstat:0x1000002, lastline:29!!
      [  166.528086] mipi2-csi2 ERR1:0x10 (fs/fe mis,vc: 0)
      [  168.179137] mipi2-csi2 ERR1:0x1000000 (crc,vc: 0)
      [  169.830230] rkcif-mipi-lvds2: ERROR: csi size err, intstat:0x1000002, lastline:63!!
      [  169.830333] mipi2-csi2 ERR1:0x10 (fs/fe mis,vc: 0)
      请教一下问题出在哪里,我应该如何进行排查。
        veye_xumm @teo.chan
        @teo-chan 看起来i2c现在没问题,mipi数据接收有问题。
        建议你查一下rock5b有没有官方已经支持的camera? dts跟官方支持的camera做一下对比看看。
        • T Offline
          teo.chan @veye_xumm
          @veye_xumm 有的,radxa官方有支持一款 IMX415的camera,这是他们官方的设备树
          /dts-v1/;
          /plugin/;
          	metadata {
          		title ="Enable Radxa Camera 4K";
          		description = "Enable Radxa Camera 4K.";
          	fragment@0 {
          		target = <&i2c3>;
          		__overlay__ {
          			status = "okay";
          			#size-cells = <0>;
          			imx415: imx415@1a {
          				status = "okay";
          				compatible = "sony,imx415";
          				reg = <0x1a>;
          				reset-gpios = <&gpio4 RK_PA0 GPIO_ACTIVE_LOW>;
          				rockchip,camera-module-name = "RADXA-CAMERA-4K";
          				rockchip,camera-module-lens-name = "DEFAULT";
          				port {
          					imx415_out0: endpoint {
          						data-lanes = <1 2 3 4>;
          	fragment@1 {
          		__overlay__ {
          			status = "okay";
          	fragment@2 {
          		__overlay__ {
          			status = "okay";
          			ports {
          				#size-cells = <0>;
          				port@0 {
          					reg = <0>;
          					#size-cells = <0>;
          						reg = <1>;
          						remote-endpoint = <&imx415_out0>;
          				port@1 {
          					reg = <1>;
          					#size-cells = <0>;
          						reg = <0>;
          	fragment@3 {
          		__overlay__ {
          			status = "okay";
          			ports {
          				#size-cells = <0>;
          				port@0 {
          					reg = <0>;
          					#size-cells = <0>;
          						reg = <1>;
          				port@1 {
          					reg = <1>;
          					#size-cells = <0>;
          						reg = <0>;
          	fragment@4 {
          		target = <&rkcif>;
          		__overlay__ {
          			status = "okay";
          	fragment@5 {
          		__overlay__ {
          			status = "okay";
          			port {
          	fragment@6 {
          		__overlay__ {
          			status = "okay";
          			port {
          	fragment@7 {
          		__overlay__ {
          			status = "okay";
          	fragment@8 {
          		__overlay__ {
          			status = "okay";
          	fragment@9 {
          		target = <&rkisp0>;
          		__overlay__ {
          			status = "okay";
          	fragment@10 {
          		__overlay__ {
          			status = "okay";
          			port {
          				#size-cells = <0>;
          					reg = <0>;
          我对比了一下 rkips 为disabled,其他的基本一致。
          &rkcif_mipi_lvds2_sditf {
          &rkisp0 {
          &isp0_mmu {
          &rkisp0_vir0 {
            veye_xumm @teo.chan
            @teo-chan 从代码上看不出啥问题。
            需要检查一下你的转接板,data lane的信号连接有没有问题?
            • T Offline
              teo.chan @veye_xumm
              @veye_xumm 我们做了根FPC排线,这是原理图
                veye_xumm @teo.chan
                @teo-chan 你量一下现在3.3V供电在camera端排线上实际电压是多少?
                • T Offline
                  teo.chan @veye_xumm
                  @veye_xumm 刚才量了一下,排线输出的是3.3V,到camera端拉低了一点变成3.0V了。
                    veye_xumm @teo.chan
                    @teo-chan 这个电压太低了。你用杜邦线单独给摄像头供一个5V试试。
                    https://wiki.veye.cc/index.php/VEYE-MIPI-IMX385数据手册
                    J6
                    • T Offline
                      teo.chan @veye_xumm
                      @veye_xumm 单独给摄像头供5V没问题了,谢谢。
                        veye_xumm @teo.chan
                        @teo-chan 不客气。
