    IMX327S with reComputer Xavier/Nano
    12 Posts 2 Posters 4.7k Views 1 Watching
      veye_xumm @newleaf
      @newleaf
      The "probe failed" error indicates that there might be an issue with the hardware connection. Please check the FPC cable orientation, ensuring it is correctly connected.
      We have customers who have been successfully using our camera+seed boards.
      • N Offline
        newleaf
        Thx for the help!
        Pics attached for verification.
          veye_xumm @newleaf
          @newleaf
          I think the hardware connection is fine. Please execute the part3.7 and part4.1 command and send me the output to take a look.
          • N Offline
            newleaf @veye_xumm
            @veye_xumm Will do. Might be a bit later today or first thing morning (PST).
            I just got the module to work on a RasPi with gstreamer. So the module is good! Wanted to ensure that I didn't brick it.
            Once again, thank you.
            • N Offline
              newleaf @veye_xumm
              @veye_xumm Below are the results with the camera connected as shown.
              '#address-cells'   linux,phandle   name   phandle   rbpcv2_veyecam_a@3b   reg  '#size-cells'
              '#address-cells'   linux,phandle   name   phandle   rbpcv2_veyecam_c@3b   reg  '#size-cells'
              ls /sys/bus/i2c/drivers/
               bq27xxx-battery   dummy     ina230x    lp855x     nct1008_nct72   pca954x                   rt5640   rtc-rx8025   stepper_pca   tegra_edid   tps65132   usb3503
               cs53l30           ina219x   ina3221x   max77620   pca953x        'PEX9749 thermal sensor'   rt5659   sgtl5000     tas2552       tmpm32xi2c   ucsi_ccg   veyecam
              dmesg | grep veye
              [    6.214128] veyecam 9-003b: probing v4l2 sensor
              [    6.214385] veyecam 9-003b: tegracam sensor driver:veyecam_v2.0.6
              [   16.243950] veyecam 9-003b: probe failed
              [   16.244034] veyecam 9-003b: board setup failed
              [   16.244245] veyecam 10-003b: probing v4l2 sensor
              [   16.244499] veyecam 10-003b: tegracam sensor driver:veyecam_v2.0.6
              [   26.481745] veyecam 10-003b: probe failed
              [   26.481863] veyecam 10-003b: board setup failed
              Thank you!
                veye_xumm @newleaf
                @newleaf
                I think you did everything correctly. The software operations are all correct, but there is a failure in I2C communication.
                I once encountered a similar issue on Seeed's J401-3 carrier board and worked with Seeed's engineers to resolve it.
                The solution at that time was to upgrade the firmware (vl822-fw.tar.bz2)provided by Seeed.
                I suggest you check with Seeed to confirm if it's the same issue. The I2C address for our camera is 0x3b.
                • N Offline
                  newleaf @veye_xumm
                  @veye_xumm This seems to align with what I saw on one of their forums. Thx for the firmware update filename, I can reference it in an email to them.
                    veye_xumm @newleaf
                    @newleaf You are welcome.
                      veye_xumm @newleaf
                      @newleaf
                      vl822-fw.tar.bz2.a
                      Please change the file extension of the attachment to .tar.bz2.
                      **I found a previous document for your reference. **
                      The issue has been traced to a firmware problem with the USB hub chip.
                      Engineers at Seeed have provided a solution, which I have verified to be effective.
                      The specific steps are as follows:
                      STEP 1. Use SSH to remotely log in to your Orin Nano or Orin NX, as during the upgrade process, it is required that no external devices be connected to the USB interface.
                      STEP 2. Find a way to copy the compressed file in the attachment to the Jetson system. If using a USB drive to copy, remember to unplug the USB drive after the copy is complete.
                      STEP 3. Follow the instructions below to perform the upgrade.
                      $ tar -xjvf vl822-fw.tar.bz2
                      $ cd vl822-fw
                      STEP 4. Power off and wait for 5 seconds before powering on again. Then, execute the command below to confirm the version of the USB hub firmware.
                      $ ./run_2822_ver.sh
                      STEP 5.
                      Congratulations, the upgrade has been successful. You should now be able to use i2cdetect to detect the VEYE camera at 0x3b.
                      • N Offline
                        newleaf
                        Sorry for the late reply.
                        Applied the USB bus firmware update from Seeed and the camera WORKS!!!
                        Thank you for the help. The 327S module is very nice BTW. Also got it to work on the Pi.
                          veye_xumm @newleaf
