    获取图像的测试代码,依赖opencv4.2的动态库,测试可以正常出图,用opencv4.6的库出现cap.isOpened()返回false
    7 Posts 3 Posters 4.4k Views 1 Watching
    • N Offline
      nb
      //#include <opencv2/opencv.hpp>
      #include "AlgorithmAT.h"
      #include "AlgorithmSLF.h"
      #include <opencv.hpp>
      #include <iostream>
      #include <string>
      //using namespace std;
      int main(int argc, char* argv[])
      	int width = 1080;
          int height = 1080;
          int fps = 30;
          if (argc > 1) {
              width = std::stoi(argv[1]);
          if (argc > 2) {
              height = std::stoi(argv[2]);
          if (argc > 3) {
              fps = std::stoi(argv[3]);
      	//创建客户端实例
      	AlgorithmAT* at = new AlgorithmAT();
      	std::string configPath = "/home/gensong/project/ATDllDemo/config/config.yaml";
      	std::string algorithmConfigPath = "/home/gensong/project/ATDllDemo/config/algorithmConfig.yaml";
      	at->Init(configPath,algorithmConfigPath);
      	int launchMode = 0;
      	//cv::Mat src_frame = cv::imread("/home/gensong/project/ATDllDemo/picture/1.jpg");
      	//bool ret_val = cap.read(src_frame);
          system(v4l2_cmd.c_str());
          printf("func is %s,%d\n",__func__,__LINE__);
          cv::VideoCapture cap("v4l2src io-mode=dmabuf device=/dev/video0 ! video/x-raw, format=(string)GRAY8, width=(int)" + std::to_string(width) + ", height=(int)" + std::to_string(height) + " ! appsink");
          if (cap.isOpened()) {
              while (true) {
      			cv::Mat src_frame;
                  printf("func is %s,%d,ret_val is %d\n",__func__,__LINE__,ret_val);
                  if (ret_val) {
                      cv::imshow("demo", src_frame);
                      cv::waitKey(1);
      				long long frameTime = 20240222153410123;
      				std::vector<Algorithm_Pos_t> locRes;
      				cv::Mat dst_frame;
         				cv::medianBlur(src_frame, dst_frame, 5); //
      				bool retPos = at->GetPos(launchMode,dst_frame,frameTime,locRes);
      				std::cout << "retPos:" << retPos << std::endl;
      				vector<Algorithm_Pos_t>::iterator locItem;
      				for(locItem = locRes.begin();locItem != locRes.end();locItem++)
      					std::cout << "id:" << (*locItem).id << std::endl;
      					std::cout << "timeDelay:" << (*locItem).timeDelay << std::endl;
      					std::cout << "x:" << (*locItem).x << std::endl;
      					std::cout << "y:" << (*locItem).y << std::endl;
      					std::cout << "z:" << (*locItem).z << std::endl;
      					std::cout << "yaw:" << (*locItem).yaw << std::endl;
      					std::cout << "pitch:" << (*locItem).pitch << std::endl;
      					std::cout << "roll:" << (*locItem).roll << std::endl;
                  } else {
                      std::cout << "camera open failed" << std::endl;
                      break;
          } else {
      	cv::destroyAllWindows();
      	//接收并打印数据
      	// while(true)
      	// 	//std::cout<< "getPose:"<<vision.aprilTag_t.id<<"-"<<vision.aprilTag_t.x<<"-"<<vision.aprilTag_t.y<<"-"<<vision.aprilTag_t.z<<std::endl;
      	// 	usleep(30*1000);
      	return 0;
      • N Offline
        nb
        #include <iostream>
        #include <string>
        int main() {
        cv::VideoCapture cap("/home/gensong/test.mp4"); // 打开本地视频文件
        if (!cap.isOpened()) { // 检查文件是否成功打开
        std::cout << "Failed to open video file!" << std::endl;
        return -1;
        cv::Mat frame;
        while (cap.read(frame)) {          // 读取每一帧画面
            cv::imshow("Video", frame);    // 显示视频
            cv::waitKey(1);
        cap.release();                     // 释放资源
        return 0;
        } 基于opencv4.6的库 用这个代码可以正常打开播放视频
        • N Offline
          nb
          麻烦问下 cv::VideoCapture cap("v4l2src io-mode=dmabuf device=/dev/video0 ! video/x-raw, format=(string)GRAY8, width=(int)" + std::to_string(width) + ", height=(int)" + std::to_string(height) + " ! appsink"); 和 cv::VideoCapture cap("/home/gensong/test.mp4"); 两者的区别是什么? 为什么 cv::VideoCapture cap("/home/gensong/test.mp4"); 就可以打开视频, 而 cv::VideoCapture cap("v4l2src io-mode=dmabuf device=/dev/video0 ! video/x-raw, format=(string)GRAY8, width=(int)" + std::to_string(width) + ", height=(int)" + std::to_string(height) + " ! appsink"); 就会提示 cap.isOpened()返回false
            veye_xumm @nb
            @nb said in 获取图像的测试代码,依赖opencv4.2的动态库,测试可以正常出图,用opencv4.6的库出现cap.isOpened()返回false:
            不好意思,回复的晚了。 我们对opencv的研究并不深入,只是给了一个简单的调试demo。 我想这个问题我现在无法给您准确的回复。
            • N Offline
              nb @veye_xumm
              @veye_xumm said in 获取图像的测试代码,依赖opencv4.2的动态库,测试可以正常出图,用opencv4.6的库出现cap.isOpened()返回false:
              好的 谢谢 这个问题 我已经自己解决了的
              veye_xummV W 2 Replies Last reply Reply Quote 0
                veye_xumm @nb
                @nb 好的。真棒~
                • W Offline
                  w88121446 @nb
                  @nb 您好,我遇到了类似的问题,请问一下您的解决方案就是将4.6的opencv更换成4.2的opencv吗?
