    RAW-MIPI-SC132M驱动编译后无法正常播放
    12 Posts 2 Posters 5.3k Views 1 Watching
    • A Offline
      ashengzi
      8f9c1cbf-f04f-4ee2-b525-3c96ae3a0f83-image.png 报了这个错误
        veye_xumm @ashengzi
        @ashengzi
        你调用
        python3 ./v4l2dev_2_opencv_show_grey.py --width 1024--height 1280--fps 60 --i2c 2
        试一下
        • A Offline
          ashengzi
          • A Offline
            ashengzi @veye_xumm
            @veye_xumm said in RAW-MIPI-SC132M驱动编译后无法正常播放:
            @ashengzi
            你调用
            试一下
            试过了,也不行
              veye_xumm @ashengzi
              @ashengzi 比较奇怪,按理说v4l2-ctl取图成功,用python预览也就可以成功的。因为其底层都是v4l2驱动接口。
              • A Offline
                ashengzi @veye_xumm
                v4l2-ctl -D --verbose -d /dev/video0 --set-fmt-video=width=$WIDTH,height=$HEIGHT,pixelformat=GREY --stream-mmap --stream-count=1 --stream-to=y8-${WIDTH}x${HEIGHT}.raw
                VIDIOC_QUERYCAP: ok
                Driver Info:
                Driver name : rkcif
                Card type : rkcif
                Bus info : platform:rkcif_mipi_lvds
                Driver version : 5.10.160
                Capabilities : 0x84201000
                Video Capture Multiplanar
                Streaming
                Extended Pix Format
                Device Capabilities
                Device Caps : 0x04201000
                Streaming
                Extended Pix Format
                Media Driver Info:
                Driver name : rkcif
                Model : rkcif_mipi_lvds
                Serial :
                Bus info :
                Media version : 5.10.160
                Hardware revision: 0x00000000 (0)
                Interface Info:
                Type : V4L Video
                Entity Info:
                Function : V4L2 I/O
                Pad 0x01000004 : 0: Sink
                Link 0x0200002f: from remote pad 0x1000022 of entity 'rockchip-mipi-csi2': Data, Enabled
                Link 0x0200003d: from remote pad 0x1000023 of entity 'rockchip-mipi-csi2': Data
                Link 0x0200004b: from remote pad 0x1000024 of entity 'rockchip-mipi-csi2': Data
                Link 0x02000059: from remote pad 0x1000025 of entity 'rockchip-mipi-csi2': Data
                VIDIOC_G_FMT: ok
                VIDIOC_S_FMT: ok
                Format Video Capture Multiplanar:
                Width/Height : 1024/1280
                Pixel Format : 'GREY' (8-bit Greyscale)
                Field : None
                Number of planes : 1
                Flags :
                Colorspace : Default
                Transfer Function : Default
                YCbCr/HSV Encoding: Default
                Quantization : Default
                Plane 0 :
                Bytes per Line : 1024
                Size Image : 1310720
                VIDIOC_REQBUFS returned 0 (Success)
                VIDIOC_QUERYBUF returned 0 (Success)
                VIDIOC_QBUF returned 0 (Success)
                VIDIOC_STREAMON returned 0 (Success)
                cap dqbuf: 0 seq: 0 bytesused: 1310720 ts: 1211.810033 delta: 1211810.033 ms (ts-monotonic, ts-src-eof)
                gstreamer版本没有问题,单张抓图也没有问题,抓帧也没问题,搞不明白问题出在哪里了?
                • A Offline
                  ashengzi @ashengzi
                  @ashengzi said in RAW-MIPI-SC132M驱动编译后无法正常播放:
                  VIDIOC_QUERYCAP: ok
                  Driver Info:
                  Driver name : rkcif
                  Card type : rkcif
                  Streaming
                  Extended Pix Format
                  Device Capabilities
                  Streaming
                  Extended Pix Format
                  Media Driver Info:
                  Driver name : rkcif
                  Serial :
                  Bus info :
                  Interface Info:
                  Type : V4L Video
                  Entity Info:
                  Function : V4L2 I/O
                  VIDIOC_G_FMT: ok
                  VIDIOC_S_FMT: ok
                  Field : None
                  Flags :
                  Plane 0 :
                  我这边发现我编译的radxa官方固件是5.10.160-1,而veye官网上用的是Linux radxa-zero3 5.10.160-26,这个有影响吗
                    veye_xumm @ashengzi
                    这个没有关系。
                    我这边测试了一下没问题啊。
                    另外提一下,我这边OS用的是radxa发布的debain系统,不是ubuntu系统。 不知你这用的什么系统?
                    • A Offline
                      ashengzi @veye_xumm
                      这个没有关系。
                      我这边测试了一下没问题啊。
                      我这个也是deban系统,驱动运行正应该是正常的,但就是无法正常播放,好像卡在哪个地方了
                      • A Offline
                        ashengzi @veye_xumm
                        系统启动时好像有报错,不知道和这个是否有关?
                          veye_xumm @ashengzi
                          客户已解决。是kernel配置中关于rkcif的配置原因。
