    IMX178 roi problem - rpi5
    11 Posts 2 Posters 4.8k Views 1 Watching
    • S Offline
      sanlu
      Hello,
      I can't set proper roi on rpi5 and imx178 . Command history:
      ./media_setting_rpi5.sh mvcam -fmt RAW8 -w 3088 -h 2064
      This is a Raspberry Pi 5.
      camera name mvcam; width 3088; height 2064; media_fmt Y8_1X8; pixel_fmt GREY
      CAM1 probed: media device is /dev/media2
      set CAM1 finish, plese get frame from /dev/video0 and use /dev/v4l-subdev2 for camera setting
      # v4l2-ctl --set-fmt-video=width=2600,height=2064 -d /dev/video0
      # v4l2-ctl -d /dev/video0 --set-fmt-video=width=2600,height=2064,pixelformat=GREY --stream-mmap --stream-count=1 --stream-to=y8-2600x2064.raw
        VIDIOC_STREAMON returned -1 (Invalid argument)
      # v4l2-ctl -d /dev/video0 --set-fmt-video=width=3088,height=2064,pixelformat=GREY --stream-mmap --stream-count=1 --stream-to=y8-2600x2064.raw
      (data captured)
      Second example:
      # ./media_setting_rpi5.sh mvcam -fmt RAW8 -w 2600 -h 2064 -c 1
      # v4l2-ctl --set-ctrl roi_x=100 -d /dev/v4l-subdev2
      # gst-launch-1.0 v4l2src device=/dev/video0 num-buffers=1 ! "video/x-raw,format=GRAY8,width=2600,height=2064, framerate=25/1" ! jpegenc ! filesink location=/tmp/test_roi100.jpg
      no matter what "number" I set in "v4l2-ctl --set-ctrl roi_x='number'"
      there is no effect on image - always roi begins at 0,0.
      Script ./mv_mipi_i2c.sh -r -f roi -b 4
      always return: r roi is 0,0,2600,2064
      Second problem is "overflow" at 256 pixels in setting roi by mv_mipi_i2c.sh. Image captured after setting roi:
       ./mv_mipi_i2c.sh -w -f roi -p1 256 -p2 0 -p3 2600 -p4 2064 -b 4
      Is the same when:
       ./mv_mipi_i2c.sh -w -f roi -p1 0 -p2 0 -p3 2600 -p4 2064 -b 4;
      setting x-offset at maximus 248 pix works ok:
      ./mv_mipi_i2c.sh -w -f roi -p1 248 -p2 0 -p3 2600 -p4 2064 -b 4;
        veye_xumm @sanlu
        @sanlu First example:
        media_setting_rpi5.sh has internally called media-ctl and v4l2-ctl to configure the resolution. So there is no need to run v4l2-ctl after calling media_setting_rpi5.sh.
        Try this:
        ./media_setting_rpi5.sh mvcam -fmt RAW8 -w 3088 -h 2064 -c 1
        v4l2-ctl -d /dev/video0 --stream-mmap --stream-count=1 --stream-to=y8-3104x2064.raw
        Second example:
        The configuration of roi requires all 4 relevant parameters to be configured together, not just one. This will not take effect.
        • S Offline
          sanlu @veye_xumm
          @veye_xumm Your example at full resolution works fine. I don't want full resolution but width 2400px centered - it require ROI offseted by 344px, but after setting roi via mv_mipi_i2c.sh script (./mv_mipi_i2c.sh -w -f roi -p1 344 -p2 0 -p3 2400 -p4 2064 -b 4) image is offseted only 88px - offset is "modulo" 256px (i've send you images via e-mail).
          Second example: How to set all 4 param in one command while "v4l2-ctl --set-ctrl roi_x " works on device /dev/v4l-subdev2 during "v4l2-ctl --set-fmt-video" works on /dev/video0 ?
            veye_xumm @sanlu
            @sanlu
            Sorry, I didn't explain clearly earlier.
            Based on your requirements, I recommend not using mv_mipi_i2c.sh for configuration because it directly changes the settings inside the camera, but the v4l2 driver won't be aware of your parameter modifications.
            The following three commands form a complete ROI configuration:
            v4l2-ctl --set-ctrl roi_x=344
            v4l2-ctl --set-ctrl roi_y=0
            v4l2-ctl --set-fmt-video=width=2400,height=2064
            As for the module issue you mentioned, after performing the above configuration, use the following commands to verify the actual parameters inside the camera:
            mv_mipi_i2c.sh -r -f roi -b yourbus
            mv_mipi_i2c.sh -r -f version -b yourbus
            Please send me the results once you've checked.
            • S Offline
              sanlu @veye_xumm
              @veye_xumm Results:
              # ./media_setting_rpi5.sh mvcam -fmt RAW8 -w 2400 -h 2064 -c 1
              camera name mvcam; width 2400; height 2064; media_fmt Y8_1X8; pixel_fmt GREY
              CAM1 probed: media device is /dev/media1
              # v4l2-ctl --set-ctrl roi_x=344 -d /dev/v4l-subdev2
              # v4l2-ctl --set-ctrl roi_y=0 -d /dev/v4l-subdev2
              # v4l2-ctl --set-fmt-video=width=2400,height=2064 -d /dev/video0
              # ./mv_mipi_i2c.sh -r -f roi -b 4
              r roi is 0,0,2400,2064
              # ./mv_mipi_i2c.sh -r -f version -b 4
              version is C 01.36 and L 02.01
                veye_xumm @sanlu
                @sanlu
                Please download a new https://github.com/veyeimaging/raspberrypi_v4l2/tree/main/rpi5_scripts
                Try
                ./media_setting_rpi5.sh mvcam -fmt RAW10 -x 344 -y 0 -w 2400 -h 2064 -c 1
                then
                • S Offline
                  sanlu @veye_xumm
                  @veye_xumm Results below:
                  root@allsky2:~/raspberrypi_v4l2/rpi5_scripts# ./media_setting_rpi5.sh mvcam -fmt RAW10 -x 344 -y 0  -w 2400 -h 2064 -c 1
                  Kernel version is 6.6.51, do not support unpacked format.
                  camera name mvcam; roi_x 344; roi_y 0;width 2400; height 2064; media_fmt Y10_1X10; pixel_fmt Y10P
                  root@allsky2:~/raspberrypi_v4l2/rpi5_scripts# cd ../mv_tools_rpi/
                  /root/raspberrypi_v4l2/mv_tools_rpi
                  root@allsky2:~/raspberrypi_v4l2/mv_tools_rpi# ./mv_mipi_i2c.sh -r -f roi -b 4
                    veye_xumm @sanlu
                    @sanlu said in IMX178 roi problem - rpi5:
                    Sorry , please pull a new update from github.
                    • S Offline
                      sanlu
                      @veye_xumm Ok - now "mv_mipi_i2c.sh -r -f roi" show right values, but main problem exists: image not begin at 344px but 88.
                      But problem exists only at "x" - I've tested image 1200x1200 offseted by 512 and "y" begins at right position
                        veye_xumm @sanlu
                        @sanlu
                        This is indeed a bug, please refer to this link below to upgrade the camera firmware to version MV-MIPI-IMX178M_C1.44_L2.01_upgrade_20241121.bin.
                        • S Offline
                          sanlu @veye_xumm
                          Perfect. Now is working as expected. Thanks!
