IMX178 roi problem - rpi5
Hello,
I can't set proper roi on rpi5 and imx178 . Command history:./media_setting_rpi5.sh mvcam -fmt RAW8 -w 3088 -h 2064 This is a Raspberry Pi 5. camera name mvcam; width 3088; height 2064; media_fmt Y8_1X8; pixel_fmt GREY CAM1 probed: media device is /dev/media2 set CAM1 finish, plese get frame from /dev/video0 and use /dev/v4l-subdev2 for camera setting # v4l2-ctl --set-fmt-video=width=2600,height=2064 -d /dev/video0 # v4l2-ctl -d /dev/video0 --set-fmt-video=width=2600,height=2064,pixelformat=GREY --stream-mmap --stream-count=1 --stream-to=y8-2600x2064.raw VIDIOC_STREAMON returned -1 (Invalid argument) # v4l2-ctl -d /dev/video0 --set-fmt-video=width=3088,height=2064,pixelformat=GREY --stream-mmap --stream-count=1 --stream-to=y8-2600x2064.raw <(data captured)
Second example:
# ./media_setting_rpi5.sh mvcam -fmt RAW8 -w 2600 -h 2064 -c 1 # v4l2-ctl --set-ctrl roi_x=100 -d /dev/v4l-subdev2 # gst-launch-1.0 v4l2src device=/dev/video0 num-buffers=1 ! "video/x-raw,format=GRAY8,width=2600,height=2064, framerate=25/1" ! jpegenc ! filesink location=/tmp/test_roi100.jpgno matter what "number" I set in "v4l2-ctl --set-ctrl roi_x='number'"
there is no effect on image - always roi begins at 0,0.
Script ./mv_mipi_i2c.sh -r -f roi -b 4
always return: r roi is 0,0,2600,2064Second problem is "overflow" at 256 pixels in setting roi by mv_mipi_i2c.sh. Image captured after setting roi:
./mv_mipi_i2c.sh -w -f roi -p1 256 -p2 0 -p3 2600 -p4 2064 -b 4Is the same when:
./mv_mipi_i2c.sh -w -f roi -p1 0 -p2 0 -p3 2600 -p4 2064 -b 4;setting x-offset at maximus 248 pix works ok:
./mv_mipi_i2c.sh -w -f roi -p1 248 -p2 0 -p3 2600 -p4 2064 -b 4; -
@sanlu First example:
media_setting_rpi5.sh has internally called media-ctl and v4l2-ctl to configure the resolution. So there is no need to run v4l2-ctl after calling media_setting_rpi5.sh.
Try this:./media_setting_rpi5.sh mvcam -fmt RAW8 -w 3088 -h 2064 -c 1 v4l2-ctl -d /dev/video0 --stream-mmap --stream-count=1 --stream-to=y8-3104x2064.rawSecond example:
The configuration of roi requires all 4 relevant parameters to be configured together, not just one. This will not take effect.
@veye_xumm Your example at full resolution works fine. I don't want full resolution but width 2400px centered - it require ROI offseted by 344px, but after setting roi via mv_mipi_i2c.sh script (./mv_mipi_i2c.sh -w -f roi -p1 344 -p2 0 -p3 2400 -p4 2064 -b 4) image is offseted only 88px - offset is "modulo" 256px (i've send you images via e-mail).
Second example: How to set all 4 param in one command while "v4l2-ctl --set-ctrl roi_x " works on device /dev/v4l-subdev2 during "v4l2-ctl --set-fmt-video" works on /dev/video0 ?
Sorry, I didn't explain clearly earlier.
Based on your requirements, I recommend not using
mv_mipi_i2c.shfor configuration because it directly changes the settings inside the camera, but the v4l2 driver won't be aware of your parameter modifications.The following three commands form a complete ROI configuration:
v4l2-ctl --set-ctrl roi_x=344 v4l2-ctl --set-ctrl roi_y=0 v4l2-ctl --set-fmt-video=width=2400,height=2064As for the module issue you mentioned, after performing the above configuration, use the following commands to verify the actual parameters inside the camera:
mv_mipi_i2c.sh -r -f roi -b yourbus mv_mipi_i2c.sh -r -f version -b yourbusPlease send me the results once you've checked.
@veye_xumm Results:
# ./media_setting_rpi5.sh mvcam -fmt RAW8 -w 2400 -h 2064 -c 1 This is a Raspberry Pi 5. camera name mvcam; width 2400; height 2064; media_fmt Y8_1X8; pixel_fmt GREY CAM1 probed: media device is /dev/media1 set CAM1 finish, plese get frame from /dev/video0 and use /dev/v4l-subdev2 for camera setting # v4l2-ctl --set-ctrl roi_x=344 -d /dev/v4l-subdev2 # v4l2-ctl --set-ctrl roi_y=0 -d /dev/v4l-subdev2 # v4l2-ctl --set-fmt-video=width=2400,height=2064 -d /dev/video0 # ./mv_mipi_i2c.sh -r -f roi -b 4 r roi is 0,0,2400,2064 # ./mv_mipi_i2c.sh -r -f version -b 4 version is C 01.36 and L 02.01 -
@sanlu
Please download a new https://github.com/veyeimaging/raspberrypi_v4l2/tree/main/rpi5_scripts
Try./media_setting_rpi5.sh mvcam -fmt RAW10 -x 344 -y 0 -w 2400 -h 2064 -c 1then
mv_mipi_i2c.sh -r -f roi -b yourbus -
@veye_xumm Results below:
root@allsky2:~/raspberrypi_v4l2/rpi5_scripts# ./media_setting_rpi5.sh mvcam -fmt RAW10 -x 344 -y 0 -w 2400 -h 2064 -c 1 This is a Raspberry Pi 5. Kernel version is 6.6.51, do not support unpacked format. camera name mvcam; roi_x 344; roi_y 0;width 2400; height 2064; media_fmt Y10_1X10; pixel_fmt Y10P CAM1 probed: media device is /dev/media1 set CAM1 finish, plese get frame from /dev/video0 and use /dev/v4l-subdev2 for camera setting root@allsky2:~/raspberrypi_v4l2/rpi5_scripts# cd ../mv_tools_rpi/ /root/raspberrypi_v4l2/mv_tools_rpi root@allsky2:~/raspberrypi_v4l2/mv_tools_rpi# ./mv_mipi_i2c.sh -r -f roi -b 4 r roi is 0,0,2400,2064 -
@sanlu said in IMX178 roi problem - rpi5:
Sorry , please pull a new update from github.
@veye_xumm Ok - now "mv_mipi_i2c.sh -r -f roi" show right values, but main problem exists: image not begin at 344px but 88.
But problem exists only at "x" - I've tested image 1200x1200 offseted by 512 and "y" begins at right position -
Perfect. Now is working as expected. Thanks!
