    Struggling with connecting and using any of the veye camera modules on rpi 3A and B
    8 Posts 2 Posters 3.0k Views 1 Watching
    • J Offline
      jgg
      Hello.
      I have several veye camera modules and raspberry pi 3A and B. I know the camera and ribbon cable work properly, at least for my VEYE-MIPI-327E. I also have an VEYE-MIPI-327S.
      I am struggling to set up anything with these cameras on rpi. I just want, first and foremost, to do live streaming of the camera on my rpi 3A. I have followed the info in this guide
      https://wiki.veye.cc/index.php/VEYE-MIPI-290/327_for_Raspberry_Pi
      But either there is something i dont understand or there are something wrong or something not stated in this guide. I am completely in the dark here...
      Could i please get some help on how to use these cameras?
      Kind regards,
      Jgg
        veye_xumm @jgg
        @jgg I understand your situation, may I ask what specific problems you are experiencing?
        The i2c pass?
        Can you implement image preview?
        • J Offline
          jgg @veye_xumm
          @veye_xumm I connected the camera to my rpi and enabled camera and i2c in raspi-config. I have cloned the software toolkit from github, navigated to the sw toolkit /bin folder and made the tools executable using the chmod +x command. At this point I should be able to use the commands like ./veye_raspipreview -t -1 to live stream. But the camera is not detected. I do have another rpi setup with a breakout board for power management and an sd card running a specific code made for using the veye cameras. When i connect the camera to this rpi it works as expected. But, like i said, with a rpi 3 clean install sd card and just ribbon cable (and 5v + ground fpr 327E) the camera is not detected and I can not figure out why.. My impression from the guide and the little information i can find in english online is that this should be plug and play. If you could supply me with a clear and concise guide for how I can connect the 327E to a Rpi 3A (with specifications of OS, sw and firmare etc, if needed) and just do a live stream to vlc or similar it would be highly appreciated. I am powering the rpi with a standard rpi adapter (5.1V, 2.5A).
            veye_xumm @jgg
            @jgg
            Please give me a glimpse of your implementation of . /veye_raspipreview -t -1 the output of this command.
            Also, in this directory, try recompiling veye_raspipreview?
            Also you should be reminded that legacy mode is only available for 32bit piOS, not for 64bit piOS.
            • J Offline
              jgg @veye_xumm
              Thank you for getting back to me.
              Output from . /veye_raspipreview -t -1 :
              before create camera com time out -1
              Hardare version: 9020e0
              mmal: mmal_component_create_core: could not find component 'vc.ril.rawcam'
              mmal: Failed to create camera component
              mmal: main: Failed to create camera component
              Output from /raspberrypi/D_mipi_rpi/python_demo/ python preview.py:
              Load libdmipicam fail.
              What do you mean by recompile veye_raspiview? How do I do this?
              I am running Buster OS on rpi 3A, 32bit (armv7l).
              I would really appreciate if I could get a clear explanation and step-by-step solution to get the camera to live stream and show the output.
              Kind regards
              Jgg
                veye_xumm @jgg
                @jgg In the raspberrypi\veye_raspcam\source directory, there is a buildme file, execute . /buildme,you see if you can get a new veye_raspipreview.
                There are so many version differences in piOS, it does happen sometimes.
                • J Offline
                  jgg @veye_xumm
                  Perfect, thank you! Now i can run the commands from the source folder. If I may, I highly suggest including all steps in the guide. To some point its very precise, e.g. navigate using cd, access raspi-config. But then a lot of this info is missing. But now it works for me at least:)
                  Again, thanks!
                  Kind regards,
                  Jgg
                    veye_xumm @jgg
                    @jgg You are welcome, will improve the wiki doc.
