    rk3588开发板接RAW-MIPI-SC132M无法获取图片
    rk3588raw-mipi-sc132mmipi
    18 Posts 2 Posters 12.9k Views 1 Watching
    • J Offline
      jihua @veye_xumm
      取图时的信息和dmesg信息如下:
      下面是原来系统里的设备树,接imx415是通的:
       * Copyright (c) 2020 Rockchip Electronics Co., Ltd.
      	ext_cam2_37m_clk: external-camera-37m-clock {
      		compatible = "fixed-clock";
      		clock-frequency = <37125000>;
      		clock-output-names = "ext_cam_37m_clk";
      		#clock-cells = <0>;
      	ext_cam2_25m_clk: external-camera-25m-clock {
      		clock-frequency = <25000000>;
      		clock-output-names = "ext_cam_25m_clk";
      		#clock-cells = <0>;
      	ext_cam2_24m_clk: external-camera-24m-clock {
      		#clock-cells = <0>;
      		clock-frequency = <24000000>;
      		clock-output-names = "ext_cam_24m_clk";
      	vdd_cam2_5v: vdd-cam2-5v-regulator {
      		regulator-name = "vdd_cam_5v";
      		regulator-always-on;
      		regulator-boot-on;
      		regulator-min-microvolt = <3300000>;
      		regulator-max-microvolt = <3300000>;
      	cam2_dovdd: cam2-dovdd {
      		regulator-name = "cam_dovdd";
      		regulator-boot-on;
      		regulator-min-microvolt = <1800000>;
      		regulator-max-microvolt = <1800000>;
      		vin-supply = <&vdd_cam2_5v>;
      	cam2_avdd: cam2-avdd {
      		regulator-name = "cam_avdd";
      		regulator-boot-on;
      		regulator-min-microvolt = <2800000>;
      		regulator-max-microvolt = <2800000>;
      	cam2_dvdd: cam2-dvdd {
      		regulator-name = "cam_dvdd";
      		regulator-boot-on;
      		regulator-min-microvolt = <1200000>;
      		regulator-max-microvolt = <1200000>;
      /* Link path: sensor->csi2_dphy0->mipi2_csi2->rkcif_mipi_lvds2--->rkcif_mipi_lvds2_sditf->rkisp0_vir2 */
      &i2c6 {
      	status = "okay";
      	pinctrl-names = "default";
      	pinctrl-0 = <&i2c6m3_xfer>;
      	dw9714: dw9714@c {
      		status = "okay";
      		reg = <0xc>;
      		rockchip,vcm-max-current = <100>;
      		rockchip,vcm-start-current = <0>;
      		rockchip,vcm-rated-current = <100>;
      		rockchip,vcm-step-mode = <0xd>;
      		rockchip,vcm-dlc-enable = <0>;
      		rockchip,vcm-mclk = <0>;
      		rockchip,vcm-t-src = <0>;
      	ov5647: ov5647@36 {
      		compatible = "ovti,ov5647";
      		status = "disabled";
      		reg = <0x36>;
      		clocks = <&ext_cam2_25m_clk>;
      		clock-names = "ext_cam_25m_clk";
      		pwdn-gpios = <&gpio4 RK_PA7 GPIO_ACTIVE_LOW>;
      		lens-focus = <&dw9714>;
      		port {
      			ov5647_out: endpoint {
      				remote-endpoint = <&dphy0_in_ov5647>;
      				data-lanes = <1 2>;
      	ov5648: camera@36 {
      		compatible = "ovti,ov5648";
      		reg = <0x36>;
      		clocks = <&ext_cam2_24m_clk>;
      		clock-names = "xvclk";
      		dovdd-supply= <&cam2_dovdd>; /* 1.8v */
      		avdd-supply = <&cam2_avdd>;  /* 2.8v */
      		dvdd-supply = <&cam2_dvdd>;  /* 1.2v */
      		pwdn-gpios = <&gpio4 RK_PA7 GPIO_ACTIVE_HIGH>;
      		reset-gpios = <&gpio4 RK_PB2 GPIO_ACTIVE_LOW>;
      		rotation = <180>;
      		rockchip,camera-module-index = <2>;
      		rockchip,camera-module-name = "THDS11073";
      		rockchip,camera-module-lens-name = "Largan-40122a1";
      		port {
      			/* MIPI CSI-2 bus endpoint */
      			ov5648_out: endpoint {
      				remote-endpoint = <&dphy0_in_ov5648>;
      				clock-lanes = <0>;
      				data-lanes = <1 2>;
      	ov8858: ov8858@36 {
      		compatible = "ovti,ov8858";
      		reg = <0x36>;
      		reset-gpios = <&gpio4 RK_PB2 GPIO_ACTIVE_HIGH>;
      		rotation = <180>;
      		rockchip,camera-module-name = "HS5885-BNSM1018-V01";
      		rockchip,camera-module-lens-name = "default";
      		port {
      			ov8858_out: endpoint {
      				remote-endpoint = <&dphy0_in_ov8858>;
      				clock-lanes = <0>;
      				data-lanes = <1 2>;
      	ov13850: ov13850@10 {
      		compatible = "ovti,ov13850";
      		reg = <0x10>;
      		rotation = <180>;
      		rockchip,camera-module-name = "ZC-OV13850R2A-V1";
      		rockchip,camera-module-lens-name = "Largan-50064B31";
      		port {
      			ov13850_out: endpoint {
      				remote-endpoint = <&dphy0_in_ov13850>;
      				clock-lanes = <0>;
      				data-lanes = <1 2>;
      	imx415_2: imx415-2@1a {
      		compatible = "sony,imx415";
      		status = "okay";
      		reg = <0x1a>;
      		clocks = <&ext_cam2_37m_clk>;
      		dovdd-supply = <&cam2_dovdd>;
      		port {
      			imx415_out2: endpoint {
      				remote-endpoint = <&dphy0_in_imx415>;
      				data-lanes = <1 2 3 4>;
      &csi2_dphy0_hw {
      	status = "okay";
      &csi2_dphy0 {
      	status = "okay";
      	ports {
      		#address-cells = <1>;
      		#size-cells = <0>;
      		port@0 {
      			reg = <0>;
      			#size-cells = <0>;
      			dphy0_in_ov5648: endpoint@1 {
      				reg = <1>;
      				remote-endpoint = <&ov5648_out>;
      				data-lanes = <1 2>;
      			dphy0_in_ov8858: endpoint@2 {
      				reg = <2>;
      				remote-endpoint = <&ov8858_out>;
      				data-lanes = <1 2>;
      			dphy0_in_ov13850: endpoint@3 {
      				reg = <3>;
      				remote-endpoint = <&ov13850_out>;
      				data-lanes = <1 2>;
      			dphy0_in_ov5647: endpoint@4 {
      				reg = <4>;
      				remote-endpoint = <&ov5647_out>;
      				data-lanes = <1 2>;
      			dphy0_in_imx415: endpoint@5 {
      				reg = <5>;
      				remote-endpoint = <&imx415_out2>;
      		port@1 {
      			reg = <1>;
      			#size-cells = <0>;
      			csidphy0_out: endpoint@0 {
      				reg = <0>;
      &mipi2_csi2 {
      	status = "okay";
      	ports {
      		#size-cells = <0>;
      		port@0 {
      			reg = <0>;
      			#size-cells = <0>;
      				reg = <1>;
      		port@1 {
      			reg = <1>;
      			#size-cells = <0>;
      				reg = <0>;
      &rkcif {
      	status = "okay";
      &rkcif_mipi_lvds2 {
      	status = "okay";
      	port {
      		cif_mipi2_in0: endpoint {
      &rkcif_mipi_lvds2_sditf {
      	status = "okay";
      	port {
      		mipi_lvds2_sditf: endpoint {
      &rkcif_mmu {
      	status = "okay";
      &rkisp1 {
      	status = "okay";
      &isp1_mmu {
      	status = "okay";
      &rkisp1_vir0 {
      	status = "okay";
      	port {
      		#size-cells = <0>;
      		isp1_vir0: endpoint@0 {
      			reg = <0>;
        veye_xumm @jihua
        @jihua dts这么看,看不出啥问题。
        你是不是有一个转接板,这个板子原理应该没问题的吧?
        另外你现在接我们sc132,启动之后
        dmesg | grep mvcam
        dmesg | grep rkcif
        发给我看一下
        • J Offline
          jihua @veye_xumm
          执行指令结果如下:
          硬件是有转接板的,量过了线序是对应的上的:
          e879d659-7b46-4beb-96cd-039196f1506c-e764d81e-9d1c-4ba5-b1ca-151e0dcfba18.jpg [图片]
            veye_xumm @jihua
            @jihua
            1处排线插歪了。
            2处的排线没有用处建议去掉,保证mipi信号的质量。
            • J Offline
              jihua @veye_xumm
              读取相机的datarate返回是-1代表什么意思。
                veye_xumm @jihua
                @jihua 应该是这个版本的固件还没有支持这个寄存器。不影响正常出图和对接的。
                • J Offline
                  jihua @veye_xumm
                  内核打印的信息显示datarate是1.5G,用示波器测量不到时钟波形,只能测到数据波形,这个模块的实际datarate是多少的?现在抓图的时候,内核驱动报crc错误,怀疑是排线太长或者datarate对不上。
                    veye_xumm @jihua
                    @jihua
                    按照1.5G配置是没问题的,我们在多个rk3588上面都调通的。
                    你用的排线是多长的?可否拍个照片我看看。
                    • J Offline
                      jihua @veye_xumm
                      排线长度有26厘米长
                      d573eebf-ed60-4955-872c-b7609ef8ecc0-ad04fd8f-6c28-4da6-a785-2304d7f0e416.jpg [图片]
                        veye_xumm @jihua
                        @jihua 线长也没有很夸张。你测测摄像头这端,入口地方的3.3V供电,实际电压是多少?
                        • J Offline
                          jihua @veye_xumm
                          VCC3V3 测量到是3.3V,MIPI_CK_N 时钟是固定的吗?时钟是多少的?设置帧率后这个时钟会变吗?
                            veye_xumm @jihua
                            @jihua 相机是固定的1188M,3588那头设置为1500M是没问题的。
                            你把现在报的错发给我看看。
                            • J Offline
                              jihua @veye_xumm
                              获取一张图片报错
                                veye_xumm @jihua
                                @jihua 我们在rk平台没有遇到过这个问题。看ecc2这个错误提示的话,像是mipi信号劣化了。
