    buildme failed
    7 Posts 2 Posters 4.4k Views 1 Watching
    • I Offline
      Israel_bolo
      Hi, I installed all libraries for python. I run the ./buildme
      with errores.
      tga.c: In function ‘load_tga’:
      tga.c:103:53: warning: comparison of integer expressions of different signedness: ‘size_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare]
       103 |                     if (fread(image, 1, buflen, fp) != buflen) {
      RaspiCamControl.c:201:4: warning: missing initializer for field ‘num_parameters’ of ‘COMMAND_LIST’ [-Wmissing-field-initializers]
       201 |    {CommandStatsPass,   "-stats",     "st", "Force recomputation of statistics on stills capture pass"},
      In file included from RaspiCamControl.c:42:
      RaspiCLI.h:38:8: note: ‘num_parameters’ declared here
        38 |    int num_parameters;
      RaspiCamControl.c:204:4: warning: missing initializer for field ‘num_parameters’ of ‘COMMAND_LIST’ [-Wmissing-field-initializers]
       204 |    {CommandStereoDecimate,"-decimate","dec", "Half width/height of stereo image"},
      RaspiCamControl.c:205:4: warning: missing initializer for field ‘num_parameters’ of ‘COMMAND_LIST’ [-Wmissing-field-initializers]
       205 |    {CommandStereoSwap,  "-3dswap",    "3dswap", "Swap camera order for stereoscopic"},
      RaspiCamControl.c: In function ‘raspicamcontrol_set_ROI’:
      RaspiCamControl.c:1468:4: warning: missing initializer for field ‘rect’ of ‘MMAL_PARAMETER_INPUT_CROP_T’ [-Wmissing-field-initializers]
      1468 |    MMAL_PARAMETER_INPUT_CROP_T crop = {{MMAL_PARAMETER_INPUT_CROP, sizeof(MMAL_PARAMETER_INPUT_CROP_T)}};
      In file included from /usr/include/interface/mmal/mmal_parameters.h:32,
                      from /usr/include/interface/mmal/mmal_port.h:42,
                      from /usr/include/interface/mmal/mmal.h:357,
                      from RaspiCamControl.c:36:
      /usr/include/interface/mmal/mmal_parameters_camera.h:594:28: note: ‘rect’ declared here
       594 |    MMAL_RECT_T             rect;    /**< Crop rectangle as 16P16 fixed point values */
      RaspiCamControl.c: In function ‘raspicamcontrol_zoom_in_zoom_out’:
      RaspiCamControl.c:1497:29: warning: comparison of integer expressions of different signedness: ‘int32_t’ {aka ‘int’} and ‘long unsigned int’ [-Wsign-compare]
      1497 |         if (crop.rect.width <= (zoom_full_16P16 + zoom_increment_16P16))
      RaspiCamControl.c:1511:28: warning: comparison of integer expressions of different signedness: ‘unsigned int’ and ‘int32_t’ {aka ‘int’} [-Wsign-compare]
      1511 |         if (increased_size < crop.rect.width) //overflow
      RaspiCamControl.c: In function ‘raspicamcontrol_set_annotate’:
      RaspiCamControl.c:1609:7: warning: missing initializer for field ‘enable’ of ‘MMAL_PARAMETER_CAMERA_ANNOTATE_V4_T’ [-Wmissing-field-initializers]
      1609 |       {{MMAL_PARAMETER_ANNOTATE, sizeof(MMAL_PARAMETER_CAMERA_ANNOTATE_V4_T)}};
      /usr/include/interface/mmal/mmal_parameters_camera.h:798:16: note: ‘enable’ declared here
       798 |    MMAL_BOOL_T enable;
      D_mipicam.c: In function ‘encoder_buffer_callback’:
      D_mipicam.c:610:19: warning: unused variable ‘new_handle’ [-Wunused-variable]
       610 |             FILE *new_handle;
      D_mipicam.c:598:11: warning: unused variable ‘bytes_written’ [-Wunused-variable]
       598 |       int bytes_written = buffer->length;
      D_mipicam.c: In function ‘D_start_yuv_stream’:
      D_mipicam.c:845:89: warning: unused parameter ‘userdata’ [-Wunused-parameter]
       845 | int D_start_yuv_stream(CAMERA_INSTANCE camera_instance, OUTPUT_CALLBACK callback, void *userdata)
      D_mipicam.c: In function ‘capture_buffer_callback’:
      D_mipicam.c:921:8: warning: unused variable ‘complete’ [-Wunused-variable]
       921 |    int complete = 0;
      D_mipicam.c: In function ‘D_capture’:
      D_mipicam.c:1184:20: warning: unused variable ‘time’ [-Wunused-variable]
      1184 |    struct timespec time;
      D_mipicam.c: In function ‘D_get_support_formats’:
      D_mipicam.c:1327:12: warning: unused variable ‘pcamera’ [-Wunused-variable]
      1327 |  DCAMERA * pcamera = (DCAMERA *)camera_instance;
      Someone could help me?
        veye_xumm @Israel_bolo
        @israel_bolo
        I see some warnings, but no errors. could you please continue and see if it compiles?
        I 1 Reply Last reply Reply Quote 1
        • I Offline
          Israel_bolo @veye_xumm
          I continued with the next lines:
          ./buildme
          sudo install -m 644 ./libdmipicam.so /usr/lib/
          The usr/lib directory I have the next files:
          apt                   firmware                              libBLT.2.5.so.8.6            libresid-builder.so.0.0.1  openssh               rp-prefapps
          arandr                gcc                                   libBLTlite.2.5.so.8.6        libRTIMULib.so             os-release            rsyslog
          arm-linux-gnueabihf   girepository-1.0                      libdfalt.so.0                libRTIMULib.so.7           p7zip                 runit-helper
          arm-linux-musleabihf  git-core                              libdfalt.so.0.0.0            libRTIMULib.so.7.2.1       pam.d                 sasl2
          aspell                gnome-session                         libdmipicam.so               libsidplay2.so.1           piclone               sftp-server
          bfd-plugins           gnome-settings-daemon-3.0             libgdal.so.28                libsidplay2.so.1.0.1       pipanel               ssl
          binfmt.d              gnupg                                 libgdal.so.28.0.2            libsigc-1.2.so.5           pkgconfig             sudo
          blt2.5                gnupg2                                libhardsid-builder.so.0      libsigc-1.2.so.5.0.7       pkg-config.multiarch  sysctl.d
          chromium-browser      gold-ld                               libhardsid-builder.so.0.0.1  libsupp.a                  pm-utils              systemd
          compat-ld             groff                                 libident.so.0                libvpf.so.4                policykit-1           sysusers.d
          console-setup         gui-pkinst                            libident.so.0.22             libvpf.so.4.1              pppd                  tasksel
          cpp                   gvfs                                  libmfhdfalt.so.0             locale                     printer-driver-escpr  tc
          crda                  ifupdown                              libmfhdfalt.so.0.0.0         lsb                        pulse-14.2            tcltk
          cups                  init                                  libogdi.so.4                 lxinput                    pypy                  terminfo
          dbus-1.0              ispell                                libogdi.so.4.1               lxplugins                  python2.7             thunar-archive-plugin
          debug                 jni                                   libpigpiod_if2.so            man-db                     python3               tmpfiles.d
          dhcpcd                kernel                                libpigpiod_if2.so.1          menu-cache                 python3.9             udev
          diet                  klibc                                 libpigpiod_if.so             mime                       qpdfview              udisks2
          dpkg                  klibc-krh8Sgsh8PW7Qbsa0KsFm65rfDw.so  libpigpiod_if.so.1           modprobe.d                 raspberrypi-net-mods  userconf-pi
          emacsen-common        ld-linux-armhf.so.3                   libpigpio.so                 modules                    raspberrypi-sys-mods  valgrind
          environment.d         ld-linux.so.3                         libpigpio.so.1               modules-load.d             raspi-config          vnc
          file                  libarmadillo.so.10                    libpypy-c.so                 NetworkManager             rc-gui                X11
          firewalld             libarmadillo.so.10.1.2                libresid-builder.so.0        ogdi                       resolvconf            xorg
          I compiled but when I executed any file in the python_demo directory I have the next error:
          Load libdmipicam fail
          I appreciate the answers
            @israel_bolo
            May I ask which version of piOS you are currently using? The libdmipicam mode is only suitable for the 32-bit legacy mode of piOS.
            I 1 Reply Last reply Reply Quote 0
            • I Offline
              @veye_xumm I'm using 64 bits piOS.
              I'll change the version and reinstall
                @israel_bolo Actually, for the development of new projects, I would recommend using the V4L2 mode, which is the material from the link below.
                https://wiki.veye.cc/index.php/V4L2_mode_for_Raspberry_Pi
                • I Offline
                  Israel_bolo
                  @veye_xumm Thanks! I'll read and reinstall the SO.
                  Hopefully, I'll be able to show if the problem is resolved in the next few days.
