    SOLVED RAW-MIPI-SC53M maximum exposure length
    General Discussion
    6086
    • I
      Izaak last edited by
      Hello, I am looking at the RAW-MIPI-SC53M 5MP camera module, and the documentation states the maximum exposure time is equal to 1/(max fps) which is less than 1 second. However, I would like to take long exposure images (up to 60 seconds exposure) - can this camera do that?
        veye_xumm @Izaak last edited by
        @izaak In fact, in the Video streaming mode, it is impossible to achieve an exposure time of 1 second. I conducted a test in the 2 - lane raw8 format, as follows:
        pi@raspberrypi:~/mvcamera/mv_tools_rpi $ ./mv_mipi_i2c_new.sh -w fps 0.01
        w fps 0.01
        pi@raspberrypi:~/mvcamera/mv_tools_rpi $ ./mv_mipi_i2c_new.sh -r fps
        r fps is 3.48 fps
        pi@raspberrypi:~/mvcamera/mv_tools_rpi $ ./mv_mipi_i2c_new.sh -w metime 1000000
        w manual exp time is 1000000 us
        pi@raspberrypi:~/mvcamera/mv_tools_rpi $ ./mv_mipi_i2c_new.sh -r exptime
        r current exptime is 287129 us
        It can be achieved in Pulse Trigger Mode. However, due to the excessive accumulated dark current, the signal noise will be very high. I don't think it has practical value.
        • G
          golden0514 @veye_xumm last edited by
          @veye_xumm 这种情况下如何采集图像,使用mv_mipi_i2c_new.sh可以设置曝光时间,但是如何采集,没有demo。
            veye_xumm @golden0514 last edited by
            @golden0514 你的嵌入式平台是什么?
            • G
              @veye_xumm 树莓派4b
                @golden0514
                可以参考这篇文章进行取图。
                https://wiki.veye.cc/index.php/Mv_series_camera_appnotes_4_rpi/zh
                • G
                  @veye_xumm 按照这篇文章里修改曝光时间没有效果,设置成1或者255,采集的图像几乎不变。
                    @golden0514 这篇文章没有修改曝光时间的东西吧? 有设置格式,分辨率,帧率,取图相关的内容。
                    • G
                      @veye_xumm 刚才试过了,问题解决,最大曝光时间0.3″,基本够用了
                        @golden0514 你可以进一步将fps设置小,相应的最大曝光时间也会拉长。
                        • G
                          曝光时间设置还是有问题,fps一直是30,最大曝光时间一直是33ms,264m。
                          请看看怎么才能调整长一些曝光时间,比如1s。
                            @golden0514 你好。
                            我们相机有一个底层逻辑,fps参数会优先于曝光时间设置。
                            如果你想要1秒的曝光时间,需要先将帧率设置为1帧/秒,然后再设置曝光时间即可。
