    VEYE-MIPI-IMX462 on Seeed J401 Carrier Board + Orin Nano 4GB (JetPack 6.2 / L4T 36.4.3) – No /dev/video Device Detected
    11 Posts 3 Posters 5.3k Views 1 Watching
    • J Offline
      joe
      Dear Support Team,
      I’m trying to get the VEYE-MIPI-IMX462 camera working on the Seeed Studio J401 carrier board using a Jetson Orin Nano 4GB running JetPack 6.2 (L4T 36.4.3).
      I had previously set this up successfully on the Orin Nano Developer Kit, but I’m encountering issues with the J401 carrier board.
      Issue Summary:
      Initially, the camera was not being detected at all. After reviewing related posts on the forum, I found that a USB firmware update is required for compatibility with VEYE cameras on the J401. I followed the instructions provided here:
      https://wiki.seeedstudio.com/Solution_for_the_Compatibility_Issue_between_reComputer_and_VEYE_Camera/
      After applying the update, the camera appears to be detected according to the dmesg output:
      dmesg | grep veye
      [ 12.510227] veyecam 9-003b: probing v4l2 sensor
      [ 12.510462] veyecam 9-003b: tegracam sensor driver:veyecam_v2.0.6
      [ 12.525207] veyecam 9-003b: camera id is veyecam
      [ 12.525824] veyecam 9-003b: sensor is IMX462
      [ 12.525829] veyecam 9-003b: board type is ONE board
      [ 12.526117] veyecam 9-003b: check hdver 7
      [ 12.526464] tegra-camrtc-capture-vi tegra-capture-vi: subdev veyecam 9-003b bound
      [ 12.526468] veyecam 9-003b: Detected VEYECAM sensor
      [ 12.531848] veyecam 10-003b: probing v4l2 sensor
      [ 12.531985] veyecam 10-003b: tegracam sensor driver:veyecam_v2.0.6
      [ 12.541616] veyecam 10-003b: probe failed
      [ 12.541623] veyecam 10-003b: board setup failed
      Note: Camera at 10-003b is not physically connected, so its failure is expected.
      Problem:
      Despite the sensor being detected, no video device (e.g., /dev/video0 or /dev/video1) shows up in the system.
      Configuration Details:
      Here is the relevant section from /boot/extlinux/extlinux.conf:
      LABEL primary
      MENU LABEL primary kernel
      LINUX /boot/Image
      INITRD /boot/initrd
      APPEND ${cbootargs} root=PARTUUID=fd3507f9-7b1c-48fb-a981-9fbbe6d30d9a rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 nospectre_>
      FDT /boot/dtb/kernel_tegra234-j401-p3768-0000+p3767-0004-recomputer.dtb
      OVERLAYS /boot/veyecam/tegra234-p3767-camera-p3768-veyecam2m-dual.dtbo
      I also followed the JetPack 6.x setup guide as described in the official VEYE documentation:
      https://wiki.veye.cc/index.php/How_to_upgrade_the_Jetson_system_to_support_VEYE_cameras#For_Jetpack6.x_2
      Questions:
      What could be preventing /dev/video0 from being created, even though the sensor is detected by the kernel?
      In the past, on the Orin Nano Developer Kit, I used both the VEYE-MIPI-IMX462 and the RAW-MIPI-AR0234M simultaneously with your assistance by applying this device tree overlay:
      https://forum.veye.cc/topic/621/different-modules-simultaneously-on-jetson-nano-mipi-interface
      → tegra234-p3767-camera-p3768-veyecam2m-raw_ar0234m.dtbo
      Can I reuse this DTBO with JetPack 6.2 and the J401 carrier board, or is there a specific overlay I should use for this combination?
      Thank you for your support!
      Looking forward to your guidance.
      Best regards,
      Joe
        veye_xumm @joe
        @joe
        @joe said in VEYE-MIPI-IMX462 on Seeed J401 Carrier Board + Orin Nano 4GB (JetPack 6.2 / L4T 36.4.3) – No /dev/video Device Detected:
        Questions:
        Under normal circumstances, as long as the I2C communication is working, the /dev/video0 node should be generated properly. Based on my initial assessment, your issue likely stems from differences in the usage of MIPI CSI pins between the J401 carrier board and NVIDIA's official developer kit when paired with the Orin Nano core module. Since our DTBO is based on the device tree of NVIDIA's official developer board, it may not be fully compatible with the J401 out of the box. You can try analyzing the full dmesg output to identify any errors. I suggest reaching out to Seeed for further assistance on this issue.
        • J Offline
          joe @veye_xumm
          As you advised, I contacted Seeed Studio support for assistance. Their official response has made the situation clear. In short, Seeed Studio has confirmed they cannot and will not support the VEYE IMX462 camera on their J401 carrier board.
          Since the carrier board is the source of the incompatibility (due to its lack of support for your sensor in its device tree and drivers), I now need your help to find a working solution.
          Could you please provide a list of carrier boards for the Jetson Orin Nano module that you have tested and verified to be fully compatible with the VEYE IMX462 camera?
          Furthermore, I need to ensure that whichever carrier board is recommended has at least two MIPI CSI-2 connectors to run the IMX462 and AR0234 cameras together.
          Thank you for your time and support. I look forward to your detailed recommendations.
            veye_xumm @joe
            @joe
            Regarding the I2C issue with the J401 baseboard, we have previously resolved it, and the engineers at Seeed Studio have documented the solution on their wiki. Here are two links for your reference.
            https://forum.veye.cc/topic/539/imx327s-with-recomputer-xavier-nano/10
            • J Offline
              joe @veye_xumm
              As I detailed in my initial post, I have already successfully applied that exact solution. The USB firmware update from that link is what allowed the kernel to detect the sensor, as shown by the dmesg | grep veye output I included.
              The current state is:
              -The USB firmware update is applied.
              -The kernel probe is successful for the connected camera at 9-003b.
              -The sensor is correctly identified as IMX462.
              -The problem persists: No /dev/video0 device node is created.
              veye_xummV J 2 Replies Last reply Reply Quote 0
                veye_xumm @joe
                @joe Sorry for overlooking the information in the earliest post. I think the board in the link below is suitable, as it is compatible with the official nVidia development board.
                https://www.alibaba.com/product-detail/Nvidia-jetson-orin-nano-development-board_1600993126148.html?spm=a2747.product_manager.0.0.61e871d2RIVAmD
                • J Offline
                  joe @veye_xumm
                  Thank you for providing this option. I will review it and follow up if I encounter any issues.
                  • J Offline
                    john @joe
                    Hi @joe, @veye_xumm I have just encountered this issue, i.e., with a VEYE-MIPI-IMX462 camera on the Seeed J401 carrier board, flashed with Jetpack V6.2, except in this case with an Orin NX 8GB module.
                    It previously did work on exactly the same board (i.e., the /dev/video0 device was created) at Jetpack V6.1. Does that help explain anything?
                    Any ideas? (I need Jetpack V6.2 for PPP support, which was omitted from Jetpack V6.1).
                    John
                    PS I found the Seeed reComputer J4011B with Jetpack 6.2 does not detect the Veye I2C address even though it is supplied with the "fixed" USB hub firmware (version 08B3). Very similar to the J401, but with an internal USB connection that is used for a mini-PCIe adapter "extension board" (perhaps this has upset the firmware fix).
                    • J Offline
                      john @john
                      Hi @joe, @veye_xumm, I have now tested the VEYE-MIPI-IMX462 on the Seeed reComputer J4011B with Jetpack V6.1, and found the same result as at V6.2, i.e., the Veye I2C address 0x3b is not detected. And this is even though Jetpack V6.1 works on the J401 carrier board (with the USB hub firmware patch applied).
                      Seeed Tech Support are monitoring the situation, and it may be the J401 B based reComputers are now a priority for Seeed. There is a chance that some further information could also inform their response to the lack of video device generation on the J401 at Jetpack V6.2.
                      I can test the J4011B with Jetpack V6.1 using the modified camera @veye_xumm sent me with the I2C address 0x22. This was when we were diagnosing the original detection problem on the J401. As long as the CSI pins have not been remapped, the issue could be another version of the USB hub firmware fault (e.g., maybe the J401B mini-PCIe expansion board is doing something with I2C). If the 0x22 address is detected on the J4011B it should prove to Seeed that the issue it not the Veye driver. But I would appreciate help with the Device Tree overlay.
                      I have changed the references to 0x3b in the DTS and DTSI include source to 0x22, but am getting errors like:
                      i2c i2c-9: of_i2c: modalias failure on /bus@0/cam_i2cmux/i2c@1/rbpcv3_veyecam_c@3b
                      i2c i2c-9: Failed to create I2C device for /bus@0/cam_i2cmux/i2c@1/rbpcv3_veyecam_c@3b
                      I am not very familiar with DTS files, and clearly I have missed something, can you help with this please?
                      John
                        veye_xumm @john
                        @john
                        We compared the baseboards of the J401 and J401B and found no differences. Regarding the earlier issue with the J401, we suspect that the USB hub chip, which is mounted on the same I2C bus as the camera, was intercepting responses for the I2C address 0x3b. This aligns with your hypothesis.
                        Could you visually inspect the J401B and check if there are any version or sub-model changes in the USB hub chip compared to the J401?
                        Regarding your intention to test the response issue at address 0x22, you do not need to recompile the device tree blob (dtb). You can directly use the command i2cdetect -y -r i2cnum to perform the test.
                        • J Offline
                          john @veye_xumm
                          Hi @veye_xumm, thank you again for all your help. I found that the VEYE camera you made available with I2C address 0x22 does work on the J401B. And now, after a long series of follow-ups with Seeed Tech Support, I found that i2cdump generates I2C transfer timeouts at address 0x3b (but only 0x3b!).
                          Then Seeed noted that applying the VEYE "compatibility fix" updating the USB Hub firmware to 08C3 removed the timeouts. So I tried that with the VEYE camera and it works! (This with Jetpack 6.1).
                          A weird puzzle remains, I was sure the J401B had USB Hub Firmware version 08C3 as supplied, although with one of the "devices" giving different details to 08C3 on the J401. Hence I did not expect to need the "compatibility fix", and had some concerns that reapplying it could cause a problem. But reapplying the update just now the firmware version was initially 08B3!?
                          It has updated to 08C3, and has fixed camera access to 0x3b.
                          This has been time consuming, but I might now test JetPack 6.2
