    OrangePi cm5-tablet RAW-MIPI-SC132M
    35 Posts 3 Posters 15.7k Views 2 Watching
    • M Offline
      mparem @veye_xumm
      Dmesg | grep mvcam:
      csi2-dcphy0: Fixed dependency cycle(s) with /i2c@fec80000/mvcam@3b
      @veye_xumm said in OrangePi cm5-tablet RAW-MIPI-SC132M:
      @mparem
      1. mvcam's i2c address is 0x3b, not 0x36.
      2. please set rkcif_mipi_lvds's status as okay.
      good luck!
      • M Offline
        mparem @mparem
        update: I modified the device tree a few times, and reached a different error message:
        i2c-6: Failed to create I2C device for /i2c@fec80000/mvcam@3b
        How can I verify that the drivers were correctly installed?
        neither lsmod nor less /proc/modules show anything veye-related
          veye_xumm @mparem
          @mparem
          Because on the RK platform, the mvcam driver needs to be built into the kernel, it will not appear in the lsmod list.
          Please send me your current DTS and the related error so I can take a look.
          The cam2 interface on the tablet corresponds to dcphy0 and i2c6, which is correct.
          • M Offline
            mparem
            tablet_3b2.dts.txt
            This is the decompiled dts, which I modified (set i2c address to 0x3b and changed compatibility to veye,mvcam), compiled, then moved back into /boot/dtb*/rockchip/rk3588s-orangepi-cm5-tablet.dtb (faster than recompiling with orangepi-build)
            sudo dmesg | grep ov5647
            [    6.594040] i2c i2c-6: of_i2c: modalias failure on /i2c@fec80000/ov5647-cam2@36
            [    6.594051] i2c i2c-6: Failed to create I2C device for /i2c@fec80000/ov5647-cam2@36
            [    6.594128] platform csi2-dcphy0: Fixed dependency cycle(s) with /i2c@fec80000/ov5647-cam2@3b
            [    6.607375] i2c i2c-7: of_i2c: modalias failure on /i2c@fec90000/ov5647-cam3@36
            [    6.607381] i2c i2c-7: Failed to create I2C device for /i2c@fec90000/ov5647-cam3@36
            [    6.607412] platform csi2-dcphy1: Fixed dependency cycle(s) with /i2c@fec90000/ov5647-cam3@3b
            sudo dmesg | grep csi2-dcphy0
            [    5.600344] platform csi2-dcphy0: Fixed dependency cycle(s) with /mipi0-csi2
            [    6.824192] rockchip-csi2-dphy csi2-dcphy0: csi2 dphy0 probe successfully!
            sudo dmesg | grep i2c
            [    5.612002] platform fed80000.phy: Fixed dependency cycle(s) with /i2c@fec80000/fusb302@22/connector
            [    6.408625] platform fc000000.usb: Fixed dependency cycle(s) with /i2c@fec80000/fusb302@22
            [    6.423672] i2c_dev: i2c /dev entries driver
            [    6.584542] platform csi2-dphy0: Fixed dependency cycle(s) with /i2c@fea90000/ov13850-1@10
            [    6.584625] i2c i2c-1: 1 i2c clients have been registered at 0x0c
            [    6.584679] platform csi2-dphy0: Fixed dependency cycle(s) with /i2c@fea90000/ov13855-1@36
            [    6.594013] i2c i2c-6: of_i2c: modalias failure on /i2c@fec80000/imx219-cam2@10
            [    6.594028] i2c i2c-6: Failed to create I2C device for /i2c@fec80000/imx219-cam2@10
            [    6.607497] platform csi2-dcphy1: Fixed dependency cycle(s) with /i2c@fec90000/imx219-cam3@10
            [    6.708500] [Awinic] [1-0059]aw87xxx_i2c_probe: succeed, dev_index=[0], g_aw87xxx_dev_cnt= [1]
            [    6.709515] [Awinic] [1-005a]aw87xxx_i2c_probe: succeed, dev_index=[1], g_aw87xxx_dev_cnt= [2]
              veye_xumm @mparem
              @mparem
              Please post dmesg | grep mvcam output here.
              • M Offline
                mparem @veye_xumm
                sudo dmesg | grep mvcam
                [sudo] password for orangepi:
                [    6.581083] platform csi2-dcphy0: Fixed dependency cycle(s) with /i2c@fec80000/mvcam2@3b
                sudo i2cdetect -y 6
                20: -- -- UU -- -- -- -- -- -- -- -- -- -- -- -- --
                60: -- -- -- -- -- -- -- -- -- -- 6a -- -- -- -- --
                70: -- -- -- -- -- -- -- --
                  veye_xumm @mparem
                  @mparem said in OrangePi cm5-tablet RAW-MIPI-SC132M:
                  I haven't used this method before, and I didn't quite understand your source code.
                  Now it seems the issue might still be with the DTS. I suggest you try editing the DTS source code using conventional methods.
                  • M Offline
                    mparem
                    rk3588s-orangepi-cm5-tablet.dts.txt
                    rk3588s-orangepi-cm5-tablet-camera2-veyemv.dtsi.txt
                    [    6.458001] platform csi2-dcphy0: Fixed dependency cycle(s) with /i2c@fec80000/mvcam@3b
                      veye_xumm @mparem
                      @mparem
                      Since I don't have the tablet board here, the following is just a suggested approach based on my guess. You can try commenting out the following two lines or modifying them as shown below:
                      clocks = <&ext_cam_ov5647_clk>;
                      clock-names = "xvclk";
                      • M Offline
                        mparem @veye_xumm
                        I received the cm5-base board today, attempted to connect the camera, but dmesg does not show any logs when grepping for mvcam
                          veye_xumm @mparem
                          @mparem https://github.com/veyeimaging/rk35xx_orangepi/releases
                          please try the latest image or deb packages.
                            veye_xumm @mparem
                            @mparem
                            https://github.com/veyeimaging/rk35xx_orangepi/releases/tag/v1.2_mvcam_tablet_cm5
                            Please try this image file on cm5-tablet.
                            zoldatenZ 1 Reply Last reply Reply Quote 0
                            • zoldatenZ Offline
                              zoldaten @veye_xumm
                              got it!
                              should i change in my case rk3588s-orangepi-cm5-tablet.dtb directly like:
                              dtc -I dtb -O dts rk3588s-orangepi-cm5-tablet.dtb -o test.dts
                              dtc -I dts -O dtb test.dts -o rk3588s-orangepi-cm5-tablet.dtb
                              and put it back to PC ?
                              or should i work somehow with rk3588s-orangepi-cm5-tablet-camera2.dtsi as you change it ?
                                veye_xumm @zoldaten
                                @zoldaten
                                My recommended approach is to set up the system compilation environment following the official OrangePi method, then place our provided dtsi files and drivers into it to compile a new deb package.
                                Your suggested method might work as well, but I haven't personally tried it.
                                zoldatenZ 3 Replies Last reply Reply Quote 0
                                • zoldatenZ Offline
                                  zoldaten @veye_xumm
                                  @veye_xumm ok. i tried method you recommend but when i built new image step-by-step and burn it to sd nothing changed. no veye camera there and no drivers.
                                  • zoldatenZ Offline
                                    zoldaten @veye_xumm
                                    @veye_xumm hi. i`ve built once again image folowing https://github.com/veyeimaging/rk35xx_orangepi/tree/main/linux
                                    and nothing works:
                                    could you check again instructions you provided ?
                                    moreover, i took rk3588s-orangepi-cm5-tablet.dtb from image with drivers installed you provided above and rk3588s-orangepi-cm5-tablet.dts from original image to compare.
                                    i decompiled `em to .dts and looked for differences.
                                    as far as i see on your image you do not use overlays and put all changes to dts:
                                    i looks like you changes overlap original ov5647, ov138*, etc and they stop working.
                                    in addition, i see address drift in program list:
                                    could your explain a bit how to make mixed up cameras working as you changes broke dts ?
                                    • zoldatenZ Offline
                                      zoldaten @veye_xumm
                                      @veye_xumm and i do not see any overlays from here compiled on image
                                      2026-02-26_11h44_43.png :
                                        veye_xumm @zoldaten
                                        @zoldaten I noticed you placed the compiled image onto the SD card. This is likely incorrect. You should refer to the official Orange Pi documentation and flash the compiled image to the eMMC storage that comes with the Orange Pi CM5 core board.
                                        Additionally, you might wonder why we compile the camera's dtsi directly into the main dtb instead of building it separately as an overlay. This approach follows the practice recommended by the Orange Pi manufacturer.
                                        • zoldatenZ Offline
                                          zoldaten @veye_xumm
                                          @veye_xumm got it.
                                          but why do you recommend flash eMMC ?
                                          i burned SD with your image provided and there veye presented. what`s the difference ?
                                            veye_xumm @zoldaten
                                            @zoldaten
                                            @zoldaten said in OrangePi cm5-tablet RAW-MIPI-SC132M:
                                            Sorry, I misunderstood you earlier. I thought you meant that following the steps to compile wasn't working at all. So, now that you've successfully compiled it, the veyecamera has appeared, correct?
                                            What you should do now is modify the source code of the DTS. For different MIPI interfaces, use different dtsi configurations to set it up for the specific camera or sensor model you want.
