    OrangePi cm5-tablet RAW-MIPI-SC132M
    35 Posts 3 Posters 15.7k Views 2 Watching
      veye_xumm @mparem
      @mparem
      Please post dmesg | grep mvcam output here.
      • M Offline
        mparem @veye_xumm
        sudo dmesg | grep mvcam
        [sudo] password for orangepi:
        [    6.581083] platform csi2-dcphy0: Fixed dependency cycle(s) with /i2c@fec80000/mvcam2@3b
        sudo i2cdetect -y 6
        20: -- -- UU -- -- -- -- -- -- -- -- -- -- -- -- --
        60: -- -- -- -- -- -- -- -- -- -- 6a -- -- -- -- --
        70: -- -- -- -- -- -- -- --
          veye_xumm @mparem
          @mparem said in OrangePi cm5-tablet RAW-MIPI-SC132M:
          his is the decompiled dts, which I modified (set i2c address to 0x3b and changed compatibility to veye,mvcam), compiled, then moved back into /boot/dtb*/rockchip/rk3588s-orangepi-cm5-tablet.dtb (faster than recompiling with orangepi-build)
          I haven't used this method before, and I didn't quite understand your source code.
          Now it seems the issue might still be with the DTS. I suggest you try editing the DTS source code using conventional methods.
          • M Offline
            mparem
            rk3588s-orangepi-cm5-tablet.dts.txt
            rk3588s-orangepi-cm5-tablet-camera2-veyemv.dtsi.txt
            [    6.458001] platform csi2-dcphy0: Fixed dependency cycle(s) with /i2c@fec80000/mvcam@3b
              veye_xumm @mparem
              @mparem
              Since I don't have the tablet board here, the following is just a suggested approach based on my guess. You can try commenting out the following two lines or modifying them as shown below:
              clocks = <&ext_cam_ov5647_clk>;
              clock-names = "xvclk";
              • M Offline
                mparem @veye_xumm
                I received the cm5-base board today, attempted to connect the camera, but dmesg does not show any logs when grepping for mvcam
                  veye_xumm @mparem
                  @mparem https://github.com/veyeimaging/rk35xx_orangepi/releases
                  please try the latest image or deb packages.
                    veye_xumm @mparem
                    @mparem
                    https://github.com/veyeimaging/rk35xx_orangepi/releases/tag/v1.2_mvcam_tablet_cm5
                    Please try this image file on cm5-tablet.
                    zoldatenZ 1 Reply Last reply Reply Quote 0
                    • zoldatenZ Offline
                      zoldaten @veye_xumm
                      got it!
                      should i change in my case rk3588s-orangepi-cm5-tablet.dtb directly like:
                      dtc -I dtb -O dts rk3588s-orangepi-cm5-tablet.dtb -o test.dts
                      dtc -I dts -O dtb test.dts -o rk3588s-orangepi-cm5-tablet.dtb
                      and put it back to PC ?
                      or should i work somehow with rk3588s-orangepi-cm5-tablet-camera2.dtsi as you change it ?
                        veye_xumm @zoldaten
                        @zoldaten
                        My recommended approach is to set up the system compilation environment following the official OrangePi method, then place our provided dtsi files and drivers into it to compile a new deb package.
                        Your suggested method might work as well, but I haven't personally tried it.
                        zoldatenZ 3 Replies Last reply Reply Quote 0
                        • zoldatenZ Offline
                          zoldaten @veye_xumm
                          @veye_xumm ok. i tried method you recommend but when i built new image step-by-step and burn it to sd nothing changed. no veye camera there and no drivers.
                          • zoldatenZ Offline
                            zoldaten @veye_xumm
                            @veye_xumm hi. i`ve built once again image folowing https://github.com/veyeimaging/rk35xx_orangepi/tree/main/linux
                            and nothing works:
                            could you check again instructions you provided ?
                            moreover, i took rk3588s-orangepi-cm5-tablet.dtb from image with drivers installed you provided above and rk3588s-orangepi-cm5-tablet.dts from original image to compare.
                            i decompiled `em to .dts and looked for differences.
                            as far as i see on your image you do not use overlays and put all changes to dts:
                            i looks like you changes overlap original ov5647, ov138*, etc and they stop working.
                            in addition, i see address drift in program list:
                            could your explain a bit how to make mixed up cameras working as you changes broke dts ?
                            • zoldatenZ Offline
                              zoldaten @veye_xumm
                              @veye_xumm and i do not see any overlays from here compiled on image
                              2026-02-26_11h44_43.png :
                                veye_xumm @zoldaten
                                @zoldaten I noticed you placed the compiled image onto the SD card. This is likely incorrect. You should refer to the official Orange Pi documentation and flash the compiled image to the eMMC storage that comes with the Orange Pi CM5 core board.
                                Additionally, you might wonder why we compile the camera's dtsi directly into the main dtb instead of building it separately as an overlay. This approach follows the practice recommended by the Orange Pi manufacturer.
                                • zoldatenZ Offline
                                  zoldaten @veye_xumm
                                  @veye_xumm got it.
                                  but why do you recommend flash eMMC ?
                                  i burned SD with your image provided and there veye presented. what`s the difference ?
                                    veye_xumm @zoldaten
                                    @zoldaten
                                    @zoldaten said in OrangePi cm5-tablet RAW-MIPI-SC132M:
                                    Sorry, I misunderstood you earlier. I thought you meant that following the steps to compile wasn't working at all. So, now that you've successfully compiled it, the veyecamera has appeared, correct?
                                    What you should do now is modify the source code of the DTS. For different MIPI interfaces, use different dtsi configurations to set it up for the specific camera or sensor model you want.
                                    • zoldatenZ Offline
                                      zoldaten @veye_xumm
                                      @veye_xumm veye appears only on image you provided via download link.
                                      the image i built has no veye on board.
                                      should i change the main dts after decompilation ...tablet.dbt > ...tablet.dts?
                                      or use somehow dtsi (https://github.com/veyeimaging/rk35xx_orangepi/tree/main/linux/drivers/cm5/cm5-mvcam-dts) to link with your ...tablet.dbt ?
                                        veye_xumm @zoldaten
                                        @zoldaten
                                        As long as you follow the steps and place our driver and DTS files into the Orange Pi source tree, then compile the image according to the official Orange Pi instructions and flash this image onto the board, the VEYE camera driver should appear correctly.
                                        Essentially, this operation just adds the driver to the original standard Orange Pi system. No additional steps are required after flashing the image. I suspect that you may not have fully applied the modifications in all the necessary parts of the source code.
                                        zoldatenZ 2 Replies Last reply Reply Quote 0
                                        • zoldatenZ Offline
                                          zoldaten @veye_xumm
                                          @veye_xumm hi. i`m trying to build Kernel itself left alone the full image.
                                          and see this error in compile the veye driver:
                                          so the problem in driver file - [0_1772540181473_veyecam2m.zip](Загрузка 100%)
                                          • zoldatenZ Offline
                                            zoldaten @veye_xumm
                                            @veye_xumm and could you check steps it did before start build process:
                                            sudo cp -r rk35xx_orangepi/linux/drivers/cm5/cm5-mvcam-dts orangepi-build/kernel/orange-pi-5.10-rk35xx/arch/arm64/boot/dts/rockchip/
                                            sudo cp rk35xx_orangepi/linux/drivers/cm5/config/linux-rockchip-rk3588-legacy.config orangepi-build/external/config/kernel/linux-rockchip-rk3588-legacy.config
                                            sudo cp -r rk35xx_veye_bsp/linux/drivers/kernel_v5.10 orangepi-build/kernel/orange-pi-5.10-rk35xx/drivers/media/i2c/
                                            sudo nano orangepi-build/kernel/orange-pi-5.10-rk35xx/drivers/media/i2c/Kconfig
                                            config VIDEO_DS90UB954
                                                   tristate "TI FDPLINK III support."
                                                   depends on I2C && VIDEO_V4L2 && VIDEO_V4L2_SUBDEV_API
                                                   help
                                                        Driver for TI FDPLINK III .
                                            config VIDEO_VEYECAM2M
                                                   tristate "VEYE 2M camera support."
                                                   depends on MEDIA_CAMERA_SUPPORT
                                                   help
                                                           Driver for veye 2m camera.
                                            config VIDEO_VEYEMVCAM
                                                   tristate "VEYE MV series camera support."
                                                   help
                                                           Driver for veye mv series camera.
                                            config VIDEO_VEYEVBYONE
                                                   tristate "VEYE V-by-One hs toolkit support."
                                                   help
                                                           Driver for vV-by-One hs toolkit .
                                            sudo nano orangepi-build/kernel/orange-pi-5.10-rk35xx/drivers/media/i2c/Makefile
                                            obj-$(CONFIG_VIDEO_DS90UB954) += ds90ub954.o
                                            obj-$(CONFIG_VIDEO_VEYEVBYONE) += veye_vbyone.o
                                            obj-$(CONFIG_VIDEO_VEYECAM2M) += veyecam2m.o
                                            obj-$(CONFIG_VIDEO_VEYEMVCAM) += veye_mvcam.o
                                            may be i miss something leads to empty image ?
