    Jetson Nano Orin IMX462
    2019
    • D
      D_101 last edited by
      In short, I have a Jetson Orin Nano and a IMX462, despite the way I orientate the camera cable, my Orin Nano can not detect the IMX462 despite having the drivers properly installed
      Below are the specifications of my Orin Nano
      cat /etc/nv_tegra_release
      uname -r
      ls /boot/dtb
      # R36 (release), REVISION: 4.7, GCID: 42132812, BOARD: generic, EABI: aarch64, DATE: Thu Sep 18 22:54:44 UTC 2025
      # KERNEL_VARIANT: oot
      5.15.148-tegra
      kernel_tegra234-p3768-0000+p3767-0005-nv-super.dtb
      The following are the steps I've taken to install the IMX462 driver
      wget https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tar.gz
      tar -xzvf nvidia_jetson_veye_bsp.tar.gz
      sudo cp -r nvidia_jetson_veye_bsp/ko/$(uname -r)/* /lib/modules/$(uname -r)/kernel/drivers/media/i2c/ -f
      sudo depmod
      sudo cp -r nvidia_jetson_veye_bsp/ko/5.15.148-tegra-l4t36.4.4/downstream/i2c/* /lib/modules/$(uname -r)/updates/drivers/media/i2c/ -f
      sudo cp -r nvidia_jetson_veye_bsp/ko/5.15.148-tegra-l4t36.4.4/downstream/terga-camera/tegra-camera.ko /lib/modules/$(uname -r)/updates/drivers/media/platform/tegra/camera -f
      sudo cp nvidia_jetson_veye_bsp/ko/5.15.148-tegra-l4t36.4.4/upstream/*.ko /lib/modules/$(uname -r)/kernel/drivers/media/v4l2-core/ -f
      sudo depmod
      ls /boot/dtb
      # Output : kernel_tegra234-p3768-0000+p3767-0005-nv-super.dtb
      # Create veyecam directory
      sudo mkdir -p /boot/veyecam
      # Copy the IMX462 overlay from JetPack 6.2.1 directory
      sudo cp nvidia_jetson_veye_bsp/dtbs/Orin/JetPack_6.2.1_Linux_JETSON_ORIN_TARGETS/orin_nx_nano/tegra234-p3767-camera-p3768-raw_imx462m-dual.dtbo /boot/veyecam/
      sudo nano /boot/extlinux/extlinux.conf
      # Edit extlinux.conf file
      #TIMEOUT 30
      #DEFAULT primary
      #MENU TITLE L4T boot options
      #LABEL primary
      #      MENU LABEL primary kernel
      #     LINUX /boot/Image
      #      INITRD /boot/initrd
       #     APPEND ${cbootargs} root=PARTUUID=<your-uuid> rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 video=efifb:off console=tty0 nv-auto-config
      #      FDT /boot/dtb/kernel_tegra234-p3768-0000+p3767-0005-nv-super.dtb
       #     OVERLAYS /boot/veyecam/tegra234-p3767-camera-p3768-veyecam2m-dual.dtbo
      sudo apt-mark hold nvidia-l4t-kernel nvidia-l4t-kernel-dtbs
      sudo reboot
      The following command was used to determine if the IMX462 was being detected
      # Check correct module is loaded
      lsmod | grep veyecam
      # Check dmesg for camera detection
      sudo dmesg | grep -i veyecam
      # Check I2C - camera should appear at 0x3b
      sudo i2cdetect -y -r 9
      # Check for video devices
      ls -l /dev/video*
      # Checking correct module
      veyecam                16384  0
      tegra_camera          253952  4 nvhost_isp5,nvhost_nvcsi_t194,veyecam,nvhost_vi5
      # Checking dmesg
      [   10.758731] veyecam 9-003b: probing v4l2 sensor
      [   10.758853] veyecam 9-003b: tegracam sensor driver:veyecam_v2.0.6
      [   10.771484] veyecam 9-003b: probe failed
      [   10.771489] veyecam 9-003b: board setup failed
      [   10.776701] veyecam 10-003b: probing v4l2 sensor
      [   10.776828] veyecam 10-003b: tegracam sensor driver:veyecam_v2.0.6
      [   10.787671] veyecam 10-003b: probe failed
      [   10.787678] veyecam 10-003b: board setup failed
      # Probing I2C bus
      00: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
      70: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
      # Checking video device
      ls: cannot access '/dev/video*': No such file or directory
      As a sanity check, I've double/triple checked the orientation of the camera cables to my Jetson, the camera pins to the board are facing DOWN, while to the IMX462 the pins are facing UP
        veye_xumm @D_101 last edited by
        @d_101
        1. I think your hardware connections are correct. Also, the Dupont wires are generally not required.
        2. I believe there are some issues with your operations on the .ko and .dtb files. Let me explain in detail below:
          Your camera model is VEYE-MIPI-IMX462, which is a color camera. You should only use the veyecam2m-labeled DTBO and veyecam.ko. There is no need to update the .ko files in the downstream and upstream directories.
        3. However, judging from the dmesg output, it seems that you have also performed some correct steps, because the command dmesg | grep veye shows that the driver has been loaded correctly and has attempted to probe the camera.
        Overall, I think there are some minor issues in your operations, but the general approach seems to be correct. Based on the following information:
        # Checking dmesg
        [   10.758853] veyecam 9-003b: tegracam sensor driver: veyecam_v2.0.6
        [   10.776828] veyecam 10-003b: tegracam sensor driver: veyecam_v2.0.6
        I can only suspect a hardware issue. Please remove the Dupont wires, or try using a different MIPI port.
        • D
          D_101 @veye_xumm last edited by
          @veye_xumm said in Jetson Nano Orin IMX462:
          @d_101
          # Checking dmesg
          Responding to " You should only use the veyecam2m-labeled DTBO" I see the following in the dtbs directory
          bash
          ct@ct-orin:~/nvidia_jetson_veye_bsp/dtbs/Orin/JetPack_6.2.1_Linux_JETSON_ORIN_TARGETS/orin_nx_nano$ ls
          Makefile-JP6.1
          Makefile-JP6.2
          README
          tegra234-camera-rbpcv3-csimx307.dtsi
          tegra234-camera-rbpcv3-cssc132.dtsi
          tegra234-camera-rbpcv3-veyecam2m-0x22.dtsi
          tegra234-camera-rbpcv3-veyecam2m.dtsi
          tegra234-camera-rbpcv3-veyecam2m_mvcam.dtsi
          tegra234-camera-rbpcv3-veye_gxcam.dtsi
          tegra234-camera-rbpcv3-veyeimx335.dtsi
          tegra234-camera-rbpcv3-veye_mvcam-4lane-cam0.dtsi
          tegra234-camera-rbpcv3-veye_mvcam-4lane-cam1-0.dtsi
          tegra234-camera-rbpcv3-veye_mvcam-4lane-cam1.dtsi
          tegra234-camera-rbpcv3-veye_mvcam.dtsi
          tegra234-fpdlink-dual-90ub954.dtsi
          tegra234-p3767-camera-p3768-csimx307-dual.dtbo
          tegra234-p3767-camera-p3768-csimx307-dual.dts
          tegra234-p3767-camera-p3768-cssc132-dual.dtbo
          tegra234-p3767-camera-p3768-cssc132-dual.dts
          tegra234-p3767-camera-p3768-raw_ar0234m-dual-4lane-cam1.dtbo
          tegra234-p3767-camera-p3768-raw_ar0234m-dual-4lane-cam1.dts
          tegra234-p3767-camera-p3768-raw_ar0234m-dual.dtbo
          tegra234-p3767-camera-p3768-raw_ar0234m-dual.dts
          tegra234-p3767-camera-p3768-raw_imx462m-dual.dts
          tegra234-p3767-camera-p3768-veyecam2m-dual-0x22.dts
          tegra234-p3767-camera-p3768-veyecam2m-dual.dts
          tegra234-p3767-camera-p3768-veyecam2m-fpdlink-dual.dtbo
          tegra234-p3767-camera-p3768-veyecam2m-fpdlink-dual.dts
          tegra234-p3767-camera-p3768-veyecam2m-raw_ar0234m.dts
          tegra234-p3767-camera-p3768-veye_gxcam-dual.dtbo
          tegra234-p3767-camera-p3768-veye_gxcam-dual.dts
          tegra234-p3767-camera-p3768-veyeimx335-dual.dtbo
          tegra234-p3767-camera-p3768-veyeimx335-dual.dts
          tegra234-p3767-camera-p3768-veye_mvcam-dual-4lane-cam1.dtbo
          tegra234-p3767-camera-p3768-veye_mvcam-dual-4lane-cam1.dts
          tegra234-p3767-camera-p3768-veye_mvcam-dual.dtbo
          tegra234-p3767-camera-p3768-veye_mvcam-dual.dts
          My question is
          • The only .dtbo file that looks right is the /tegra234-p3767-camera-p3768-veyecam2m-dual.dtbo which I did add to my extlinux.conf file as stated below
          TIMEOUT 30
          DEFAULT primary
          LABEL primary
                LINUX /boot/Image
                # FDT line added 1/6/25
                INITRD /boot/initrd
                APPEND ${cbootargs} root=PARTUUID=4467ef34-b907-4537-8470-c873fa849134 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 video=efifb:off console=tty0 nv-auto-config
                # IMX462
          # When testing a custom kernel, it is recommended that you create a backup of
          # the original kernel and add a new entry to this file so that the device can
          # fallback to the original kernel. To do this:
          # 1, Make a backup of the original kernel
          #      sudo cp /boot/Image /boot/Image.backup
          # 2, Copy your custom kernel into /boot/Image
          # 3, Uncomment below menu setting lines for the original kernel
          # 4, Reboot
          # LABEL backup
          #    MENU LABEL backup kernel
          #    LINUX /boot/Image.backup
          LABEL primary-backup
                MENU LABEL primary kernel backup
                LINUX /boot/Image
                INITRD /boot/initrd
          My question here is
          • Last listed in the directory above I only see tegra234-p3767-camera-p3768-veyecam2m-dual.dtbo and tegra234-camera-rbpcv3-veyecam2m.dtsi that come close to what you instructed earlier regarding me using the veyecam2m that was labeled with DTBO
          • Since I only have one IMX462 and you instructed me to
            The only veyecam2m-labeled DTBO file that I assumed I need to use tegra234-p3767-camera-p3768-veyecam2m-dual.dtbo
          Is that correct?
          Also, responding to the comment you made earlier regarding updating the .ko files up/downstream
          There is no need to update the `.ko` files in the **downstream** and **upstream** directories.
          It is stated in the wiki page to do just that
          Therefore, for Jetpack 6.2.1, the following commands should be modified as:
          sudo cp nvidia_jetson_veye_bsp/ko/5.15.148-tegra-l4t36.4.4/downstream/i2c/* /lib/modules/$(uname -r)/updates/drivers/media/i2c/ -f
          sudo cp nvidia_jetson_veye_bsp/ko/5.15.148-tegra-l4t36.4.4/downstream/terga-camera/tegra-camera.ko /lib/modules/$(uname -r)/updates/drivers/media/platform/tegra/camera -f
          If those steps aren't necessary for someone who's running Jetpack 6.2.1 I feel like it should be removed to lessen the confusion since the wiki page instructions aren't the easiest to follow in my opinion.
            @d_101
            @d_101 said in Jetson Nano Orin IMX462:
            Is that correct?
            Yes.
            Sorry, the Wiki article was not clear enough. We'll work on improving it.
            • D
              @veye_xumm So I've taken the following steps
              • Re-flashed my Orin with the NVIDIA SDK manager
              • Changed the CSI cable with the second cable that was provided by you guys. I also ensured the black tab on the Jetson Orin was facing 'up' while the pins on the wider end of the CSI cable that went to the IMX462 was facing 'towards' the tab (Please see pictures below for reference)
              • And below are the steps that I took that eventually lead to the same probing error that was mentioned earlier
              sudo depmod
              sudo depmod
              ls /boot/dtb
              sudo cp nvidia_jetson_veye_bsp/dtbs/Orin/JetPack_6.2.1_Linux_JETSON_ORIN_TARGETS/orin_nx_nano/tegra234-p3767-camera-p3768-veyecam2m-dual.dtbo /boot/veyecam/
              ################## Output from extlinux.conf file ##################
              TIMEOUT 30
              DEFAULT primary
              LABEL primary
                    LINUX /boot/Image
                    INITRD /boot/initrd
                    # IMX462
              # 4, Reboot
              # LABEL backup
                    LINUX /boot/Image
                    INITRD /boot/initrd
              sudo reboot
              After restarting the Orin, I got the following dmesg output
              sudo dmesg | grep veyecam
              [   11.201520] veyecam 9-003b: probing v4l2 sensor
              [   11.201648] veyecam 9-003b: tegracam sensor driver:veyecam_v2.0.6
              [   11.211991] veyecam 9-003b: probe failed
              [   11.212000] veyecam 9-003b: board setup failed
              [   11.212329] veyecam 10-003b: probing v4l2 sensor
              [   11.212455] veyecam 10-003b: tegracam sensor driver:veyecam_v2.0.6
              [   11.227303] veyecam 10-003b: probe failed
              [   11.227310] veyecam 10-003b: board setup failed
              I did my best to be as thorough as possible, but at this point I'm not sure what else I could be missing
              • D
                I decided to return the camera sensor and look for a better alternative despite my best efforts
                  @d_101 Sorry for the late reply. Based on the current situation, I can only suspect a hardware issue that is causing the I2C path to be unavailable. This could be a problem with your mainboard or with the camera itself. Please return the camera to us, and we will perform testing and inspection.
