    UNSOLVED GX-MIPI-IMX662 on RK3588 with Kernel 6.1 - MIPI CSI Errors
    Rockchip App camera
    1458
    • X
      xLWvU7mX last edited by
      Hello everyone,
      I'm continuing my evaluation of the GX-MIPI-IMX662 cameras as potential replacements for the VEYE-MIPI-IMX462. First, thank you for uploading the kernel 6.1 drivers, it saved significant porting effort.
      I've built a system image based on linux-rockchip 6.1 with the provided drivers and adapted the device tree overlays for my dev board. I used my existing working overlay for the VEYE-MIPI-IMX462 on CSI0 and the provided GX camera examples for Firefly and Orange Pi boards on github.
      However, I've encountered a problem during testing. My board has two identical 31-pin 0.3mm CSI connectors: CSI0 and CSI1. When a GX camera is connected to CSI0, the video stream fails to start and the kernel log is spammed with MIPI_CSI2 ERR1/ERR2 errors. The camera is correctly detected via I2C judging by correct output of gx_probe.sh. When connected to CSI1, frames are received at the expected 60 FPS, but the kernel log still has some errors (though much fewer).
      Some additional context:
      The cameras are always connected via the same adapter pcb (camera 22-pin to board 31-pin, 4-lane MIPI-CSI) that handles pinout and i2c levels. The adapter has a hardware limitation and both gpio pins (5 and 6) on camera side are pulled high (3.3V).
      The VEYE series cameras work without any issues on CSI0 using the same adapter and 15-pin to 22-pin stock cable. The GX cameras have external 5VDC connected (5.05V measured while running the test command) using stock dupont wires.
      I have tried updating the GX camera firmware but found it was already at the latest version referenced in the GX camera firmware update manual on wiki. I've also tried replacing the GX camera module with another one (I have two of them).
      Testing:
      GX-MIPI-IMX662 connected to CSI0 (fails)
      The camera probe is successful, but the v4l2-ctl command hangs.
      source rk35xx_veye_bsp/gx_i2c_tools/gx_probe.sh 3
      Found veye_gxcam camera on i2c-3.
      Setenv I2C_BUS = 3
      Setenv CAMERAMODEL = GX-MIPI-IMX662
      Setenv FPS = 60
      Setenv WIDTH = 1920
      Setenv HEIGHT = 1080
      v4l2-ctl --set-fmt-video=width=$WIDTH,height=$HEIGHT,pixelformat=UYVY --stream-mmap --stream-count=-1 --stream-to=/dev/null
      ^C
      The dmesg output for this test shows a good amount of various MIPI CSI-2 errors (ecc, crc, frame sync):
      [   75.870155] (0xfdd30000)MIPI_CSI2 ERR1:0x10000000 (ecc2)
      [   75.870764] (0xfdd30000)MIPI_CSI2 ERR1:0x10000000 (ecc2)
      [   75.871912] (0xfdd30000)MIPI_CSI2 ERR2:0x100 (ecc,vc: 0)
      [   75.871924] (0xfdd30000)MIPI_CSI2 ERR1:0x10 (fs/fe mis,vc: 0)
      [   75.874969] (0xfdd30000)MIPI_CSI2 ERR2:0x8800 (ecc,vc: 3) (err id,vc: 3)
      [   75.875197] (0xfdd30000)MIPI_CSI2 ERR1:0x8000000 (crc,vc: 3)
      ... (many similar lines) ...
      [   75.989465] rockchip-mipi-csi2 mipi2-csi2: stream off, src_sd: 00000000833c3caa, sd_name:rockchip-csi2-dphy0
      [   75.989477] rockchip-mipi-csi2 mipi2-csi2: stream OFF
      GX-MIPI-IMX662 connected to CSI1 (works with errors)
      The camera probe is successful, and frames are streamed at ~60 FPS.
      source rk35xx_veye_bsp/gx_i2c_tools/gx_probe.sh 4
      Found veye_gxcam camera on i2c-4.
      Setenv I2C_BUS = 4
      Setenv FPS = 60
      Setenv WIDTH = 1920
      <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 61.62 fps
      <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 60.94 fps
      <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 60.63 fps
      <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 60.46 fps
      ^C
      However, dmesg still reports some crc and data errors:
      [   53.285363] rkcif-mipi-lvds4: stream[0] start streaming
      [   53.288967] rockchip-csi2-dphy3: dphy3, data_rate_mbps 1188
      [   53.711971] (0xfdd50000)MIPI_CSI2 ERR1:0x1000000 (crc,vc: 0)
      [   53.713534] (0xfdd50000)MIPI_CSI2 ERR1:0x1000000 (crc,vc: 0)
      [   53.715025] (0xfdd50000)MIPI_CSI2 ERR1:0x1000 (err_data,vc: 0)
      ... (error lines continue throughout stream) ...
      [   65.103234] rockchip-mipi-csi2 mipi4-csi2: stream off, src_sd: 00000000d08c0081, sd_name:rockchip-csi2-dphy3
      Device tree overlays used
      GX Camera on CSI0: rk3588-camera-gxcam-csi0.dts
      /dts-v1/;
      /plugin/;
      #include <dt-bindings/clock/rk3588-cru.h>
      #include <dt-bindings/power/rk3588-power.h>
      #include <dt-bindings/gpio/gpio.h>
      #include <dt-bindings/pinctrl/rockchip.h>
      	fragment@0 {
      		target = <&i2c3>;
      		__overlay__ {
      			status = "okay";
      			#address-cells = <1>;
      			#size-cells = <0>;
      			pinctrl-names = "default";
      			pinctrl-0 = <&i2c3m0_xfer>;
      			gxcam: gxcam@3b{
      				status = "okay";
      				compatible = "veye,gxcam";
      				reg = <0x3b>;
      				clocks = <&cru CLK_MIPI_CAMARAOUT_M3>;
      				clock-names = "xvclk";
      				pinctrl-0 = <&mipim0_camera3_clk>;
      				rockchip,grf = <&sys_grf>;
      				pwdn-gpios = <&gpio1 RK_PB0 GPIO_ACTIVE_HIGH>;
      				reset-gpios = <&gpio4 RK_PA0 GPIO_ACTIVE_HIGH>;
      				port {
      					gxcam_out0: endpoint {
      						data-lanes = <1 2>;
      	fragment@1 {
      		target = <&csi2_dphy0_hw>;
      		__overlay__ {
      			status = "okay";
      	fragment@2 {
      		target = <&csi2_dphy0>;
      		__overlay__ {
      			status = "okay";
      			ports {
      				#size-cells = <0>;
      				port@0 {
      					reg = <0>;
      					#size-cells = <0>;
      						reg = <1>;
      						remote-endpoint = <&gxcam_out0>;
      						data-lanes = <1 2>;
      				port@1 {
      					reg = <1>;
      					#size-cells = <0>;
      					csidphy0_out: endpoint@0 {
      						reg = <0>;
      	fragment@3 {
      		target = <&mipi2_csi2>;
      		__overlay__ {
      			status = "okay";
      			ports {
      				#size-cells = <0>;
      				port@0 {
      					reg = <0>;
      					#size-cells = <0>;
      						reg = <1>;
      				port@1 {
      					reg = <1>;
      					#size-cells = <0>;
      						reg = <0>;
      	fragment@4 {
      		target = <&rkcif>;
      		__overlay__ {
      			status = "okay";
      	fragment@5 {
      		target = <&rkcif_mipi_lvds2>;
      		__overlay__ {
      			status = "okay";
      			port {
      				cif_mipi2_in0: endpoint {
      	fragment@6 {
      		target = <&rkcif_mipi_lvds2_sditf>;
      		__overlay__ {
      			status = "disabled";
      			port {
      				mipi_lvds2_sditf: endpoint {
      	fragment@7 {
      		target = <&rkcif_mmu>;
      		__overlay__ {
      			status = "okay";
      	fragment@8 {
      		target = <&rkisp0>;
      		__overlay__ {
      	fragment@9 {
      		target = <&isp0_mmu>;
      		__overlay__ {
      	fragment@10 {
      		target = <&rkisp0_vir2>;
      		__overlay__ {
      			port {
      				#size-cells = <0>;
      				isp0_vir2: endpoint@0 {
      					reg = <0>;
      GX Camera on CSI1: rk3588-camera-gxcam-csi1.dts
      /dts-v1/;
      /plugin/;
      	fragment@0 {
      		target = <&i2c4>;
      		__overlay__ {
      			status = "okay";
      			#size-cells = <0>;
      			pinctrl-0 = <&i2c4m1_xfer>;
      			gxcam_1: gxcam_1@3b {
      				status = "okay";
      				reg = <0x3b>;
      				clocks = <&cru CLK_MIPI_CAMARAOUT_M2>;
      				pinctrl-0 = <&mipim0_camera2_clk>;
      				pwdn-gpios = <&gpio3 RK_PA2 GPIO_ACTIVE_HIGH>;
      				reset-gpios = <&gpio3 RK_PA0 GPIO_ACTIVE_HIGH>;
      				port {
      					gxcam_out1: endpoint {
      						remote-endpoint = <&mipidphy3_in_ucam3>;
      						data-lanes = <1 2>;
      	fragment@1 {
      		target = <&csi2_dphy1_hw>;
      		__overlay__ {
      			status = "okay";
      	fragment@2 {
      		target = <&csi2_dphy3>;
      		__overlay__ {
      			status = "okay";
      			ports {
      				#size-cells = <0>;
      				port@0 {
      					reg = <0>;
      					#size-cells = <0>;
      					mipidphy3_in_ucam3: endpoint@1 {
      						reg = <1>;
      						remote-endpoint = <&gxcam_out1>;
      						data-lanes = <1 2>;
      				port@1 {
      					reg = <1>;
      					#size-cells = <0>;
      					csidphy3_out: endpoint@0 {
      						reg = <0>;
      						remote-endpoint = <&mipi4_csi2_input>;
      	fragment@3 {
      		target = <&mipi4_csi2>;
      		__overlay__ {
      			status = "okay";
      			ports {
      				#size-cells = <0>;
      				port@0 {
      					reg = <0>;
      					#size-cells = <0>;
      					mipi4_csi2_input: endpoint@1 {
      						reg = <1>;
      						remote-endpoint = <&csidphy3_out>;
      				port@1 {
      					reg = <1>;
      					#size-cells = <0>;
      					mipi4_csi2_output: endpoint@0 {
      						reg = <0>;
      						remote-endpoint = <&cif_mipi_in4>;
      	fragment@4 {
      		target = <&rkcif>;
      		__overlay__ {
      			status = "okay";
      	fragment@5 {
      		target = <&rkcif_mipi_lvds4>;
      		__overlay__ {
      			status = "okay";
      			port {
      				cif_mipi_in4: endpoint {
      					remote-endpoint = <&mipi4_csi2_output>;
      	fragment@6 {
      		target = <&rkcif_mipi_lvds4_sditf>;
      		__overlay__ {
      			port {
      				mipi4_lvds_sditf: endpoint {
      					remote-endpoint = <&isp1_vir1>;
      	fragment@7 {
      		__overlay__ {
      			status = "okay";
      	fragment@8 {
      		target = <&rkisp1>;
      		__overlay__ {
      	fragment@9 {
      		target = <&isp1_mmu>;
      		__overlay__ {
      	fragment@10 {
      		target = <&rkisp1_vir1>;
      		__overlay__ {
      			port {
      				#size-cells = <0>;
      				isp1_vir1: endpoint@0 {
      					reg = <0>;
      					remote-endpoint = <&mipi4_lvds_sditf>;
      Working VEYE camera on CSI0: rk3588-camera-veyecam2m-csi0.dts
      /dts-v1/;
      /plugin/;
      	compatible = "rockchip,rk3588";
      	fragment@0 {
      		target = <&i2c3>;
      		__overlay__ {
      			status = "okay";
      			#size-cells = <0>;
      			veyecam2m_0: veyecam2m@3b{
      				status = "okay";
      				reg = <0x3b>;
      				reset-gpios = <&gpio4 RK_PA0 GPIO_ACTIVE_LOW>;
      				port {
      					veyecam2m_0_out: endpoint {
      						data-lanes = <1 2>;
      	fragment@1 {
      		__overlay__ {
      			status = "okay";
      	fragment@2 {
      		__overlay__ {
      			status = "okay";
      			ports {
      				#size-cells = <0>;
      				port@0 {
      					reg = <0>;
      					#size-cells = <0>;
      						reg = <1>;
      						remote-endpoint = <&veyecam2m_0_out>;
      						data-lanes = <1 2>;
      				port@1 {
      					reg = <1>;
      					#size-cells = <0>;
      						reg = <0>;
      	fragment@3 {
      		__overlay__ {
      			status = "okay";
      			ports {
      				#size-cells = <0>;
      				port@0 {
      					reg = <0>;
      					#size-cells = <0>;
      						reg = <1>;
      				port@1 {
      					reg = <1>;
      					#size-cells = <0>;
      						reg = <0>;
        fragment@4 {
      		target = <&rkcif>;
      		__overlay__ {
      		  status = "okay";
        fragment@5 {
      		__overlay__ {
      		  status = "okay";
        fragment@6 {
      		__overlay__ {
      		  status = "okay";
            port {
        fragment@7 {
      		__overlay__ {
            port {
        fragment@8 {
      		target = <&rkisp0>;
      		__overlay__ {
        fragment@9 {
      		__overlay__ {
        fragment@10 {
      		target = <&rkisp0_vir0>;
      		__overlay__ {
            port {
              #size-cells = <0>;
              isp0_vir0: endpoint@0 {
                reg = <0>;
      I'm still trying to figure out the issue. The most obvious difference is the GX camera's higher data rate. Any help or debugging steps would be greatly appreciated. I'm happy to run any tests or provide more details about my setup if it helps.
        veye_xumm @xLWvU7mX last edited by veye_xumm
        @xlwvu7mx
        Hello, the MIPI data rate of the GX series products is indeed higher than that of the VEYE series: GX: 1188 Mbps, VEYE: 594 Mbps. Based on the issues you are experiencing, I mainly suspect the MIPI signal quality. Please pay special attention to the following:
        • What is the length of your FFC cable?
        • About your adaptor board:
        1. Have the differential pairs been length-matched? (This is required.)
        2. Has impedance matching been implemented? (Strongly recommended.)
        3. Are there any ESD protection devices with large junction capacitance on the signal lines?
        • Could you take a photo of your actual connection and send it to me for review?
        • X
          Thank you for your reply. The lenghts were:
          • 20 cm from camera to adapter using stock white 22-pin FFC cable
          • 10 cm from the adapter to the board itself using 31-pin cable.
          I've done some experiments today with different cable length combinations and various results.
          CSI0:
          • 22-pin 20 cm + 31 pin 15 cm. 0 fps, ecc2, fs/fe, f_seq errors.
          • 22-pin 10 cm + 31 pin 10 cm. 14-38 fps, very unstable with dropped buffers, ecc2, fs/fe, f_seq errors.
          • 22-pin 20 cm + 31 pin 10 cm. 0 fps, ecc2, fs/fe, f_seq errors.
          • 22-pin 10 cm + 31 pin 15 cm. 0 fps, ecc2, fs/fe, f_seq errors.
          CSI1:
          • 22-pin 20 cm + 31 pin 15 cm. 60 fps, no errors.
          • 22-pin 10 cm + 31 pin 10 cm. 60 fps, crc, err_data errors.
          • 22-pin 20 cm + 31 pin 10 cm. 60 fps, crc, err_data errors.
          • 22-pin 10 cm + 31 pin 15 cm. 60 fps, no errors.
          So, the new information is that CSI0 managed to receive at least some data and there are combinations of cable length (that are suprisingly longer) that make errors disappear completely on CSI1. As far as I can judge, this indicates hardware problems rather than issues with, for example, dt overlays.
          Regarding your question about adapter board. Differential pairs are length matched. I will request information about impedance matching from the developer of that board. The adapter only contains voltage stab and I2C level adapter - MIPI lanes are connected directly.
            @xlwvu7mx
            Based on our experience, under normal circumstances an FFC cable length within 50 cm does not cause any issues. We have tested a setup with a 20 cm FFC cable + an adapter board + a 50 cm FFC cable, and it worked normally. Could you please provide some photos of the actual setup so we can take a look?
            • X
              xLWvU7mX @veye_xumm last edited by
              Sure, here is my setup.
              The dev board is https://docs.armsom.org/armsom-sige7.
                @xlwvu7mx
                I don't think it's a cable length issue or a DTS problem. Have you tried testing with a different adapter board or a different mainboard? I tested it with an Orange Pi CM5, using a 50cm FFC cable plus a 20cm FPC cable, and the image was very stable.
                • X
                  With your setup in mind it seems that the issue can be in my adapter, main board or 31 pin FFC cable connection. I will continue investigation of the issue possibly with another main board and adapter. Thank you for your advice so far.
                  Also, I've noticed that GX manuals for Firefly and Orange Pi mention FFC cables that connect camera to the board directly and GX-MIPI-IMX662 Data Sheet page tells the camera now accepts I2C 1.8V level. So I think I will try direct connection as well.
                    @xlwvu7mx said in GX-MIPI-IMX662 on RK3588 with Kernel 6.1 - MIPI CSI Errors:
                    OK
                    • X
                      I have conducted some more experiments with another similar board, different kernel versions, with some electrical adapter modifications and a much shorter 31-pin FFC cable. The issue is exactly the same however.
                      I think the problem is probably in my adapter board, less likely in a board layout itself. I am considering making and FPC for direct connection from sensor to camera like ones that you now offer for Firefly boards.
                      Do you have any recomendations on a FPC cable design? And could you please confirm the 22-pin connector pinout featured on the GX-MIPI-IMX662 Data Sheet page (as I have seen both reset_gpio and pwdn_gpio pins in the driver source code where the page mentions only PWR_ENABLE).
                        Sorry, I am currently on the Spring Festival holiday. As for the camera, in fact only one pin is functional:PWR_ENABLE
                        https://wiki.veye.cc/index.php/GX-MIPI-IMX662_Data_Sheet
                        • X
                          Thanks for the answer, have a happy holiday!
