    GX-MIPI-IMX662 on RK3588 with Kernel 6.1 - MIPI CSI Errors
    15 Posts 2 Posters 8.2k Views 1 Watching
    • X Offline
      xLWvU7mX
      Thank you for your reply. The lenghts were:
      • 20 cm from camera to adapter using stock white 22-pin FFC cable
      • 10 cm from the adapter to the board itself using 31-pin cable.
      I've done some experiments today with different cable length combinations and various results.
      CSI0:
      • 22-pin 20 cm + 31 pin 15 cm. 0 fps, ecc2, fs/fe, f_seq errors.
      • 22-pin 10 cm + 31 pin 10 cm. 14-38 fps, very unstable with dropped buffers, ecc2, fs/fe, f_seq errors.
      • 22-pin 20 cm + 31 pin 10 cm. 0 fps, ecc2, fs/fe, f_seq errors.
      • 22-pin 10 cm + 31 pin 15 cm. 0 fps, ecc2, fs/fe, f_seq errors.
      CSI1:
      • 22-pin 20 cm + 31 pin 15 cm. 60 fps, no errors.
      • 22-pin 10 cm + 31 pin 10 cm. 60 fps, crc, err_data errors.
      • 22-pin 20 cm + 31 pin 10 cm. 60 fps, crc, err_data errors.
      • 22-pin 10 cm + 31 pin 15 cm. 60 fps, no errors.
      So, the new information is that CSI0 managed to receive at least some data and there are combinations of cable length (that are suprisingly longer) that make errors disappear completely on CSI1. As far as I can judge, this indicates hardware problems rather than issues with, for example, dt overlays.
      Regarding your question about adapter board. Differential pairs are length matched. I will request information about impedance matching from the developer of that board. The adapter only contains voltage stab and I2C level adapter - MIPI lanes are connected directly.
        veye_xumm @xLWvU7mX
        @xlwvu7mx
        Based on our experience, under normal circumstances an FFC cable length within 50 cm does not cause any issues. We have tested a setup with a 20 cm FFC cable + an adapter board + a 50 cm FFC cable, and it worked normally. Could you please provide some photos of the actual setup so we can take a look?
        • X Offline
          xLWvU7mX @veye_xumm
          Sure, here is my setup.
          The dev board is https://docs.armsom.org/armsom-sige7.
            veye_xumm @xLWvU7mX
            @xlwvu7mx
            I don't think it's a cable length issue or a DTS problem. Have you tried testing with a different adapter board or a different mainboard? I tested it with an Orange Pi CM5, using a 50cm FFC cable plus a 20cm FPC cable, and the image was very stable.
            • X Offline
              xLWvU7mX @veye_xumm
              With your setup in mind it seems that the issue can be in my adapter, main board or 31 pin FFC cable connection. I will continue investigation of the issue possibly with another main board and adapter. Thank you for your advice so far.
              Also, I've noticed that GX manuals for Firefly and Orange Pi mention FFC cables that connect camera to the board directly and GX-MIPI-IMX662 Data Sheet page tells the camera now accepts I2C 1.8V level. So I think I will try direct connection as well.
                veye_xumm @xLWvU7mX
                @xlwvu7mx said in GX-MIPI-IMX662 on RK3588 with Kernel 6.1 - MIPI CSI Errors:
                OK
                • X Offline
                  xLWvU7mX @veye_xumm
                  I have conducted some more experiments with another similar board, different kernel versions, with some electrical adapter modifications and a much shorter 31-pin FFC cable. The issue is exactly the same however.
                  I think the problem is probably in my adapter board, less likely in a board layout itself. I am considering making and FPC for direct connection from sensor to camera like ones that you now offer for Firefly boards.
                  Do you have any recomendations on a FPC cable design? And could you please confirm the 22-pin connector pinout featured on the GX-MIPI-IMX662 Data Sheet page (as I have seen both reset_gpio and pwdn_gpio pins in the driver source code where the page mentions only PWR_ENABLE).
                    veye_xumm @xLWvU7mX
                    Sorry, I am currently on the Spring Festival holiday. As for the camera, in fact only one pin is functional:PWR_ENABLE
                    https://wiki.veye.cc/index.php/GX-MIPI-IMX662_Data_Sheet
                    • X Offline
                      xLWvU7mX @veye_xumm
                      Thanks for the answer, have a happy holiday!
                      • X Offline
                        xLWvU7mX
                        Sorry for bumping an old thread but I would like to provide an update that might be relevant.
                        Since the last post I've transitioned to custom designed FPC with length matching and impedance made correctly. With the same software stack, csi0 showed no progress (still getting those ecc errors), the csi1 worked perfectly.
                        I have also tried the recent fix to rk35xx_veye_bsp (13684db), and to my surprise, the situation is now different. The camera on csi0 now shows 60 fps picture, but with colors distorted (heavy red, green, blue splashes over the objects) and the dmesg shows the following:
                        [  110.638757] (0xfdd30000)MIPI_CSI2 ERR1:0x1000000 (crc,vc: 0)
                        [  110.638772] (0xfdd30000)MIPI_CSI2 ERR1:0x1000000 (crc,vc: 0)
                        [  110.638786] (0xfdd30000)MIPI_CSI2 ERR1:0x1000000 (crc,vc: 0)
                        [  110.638800] (0xfdd30000)MIPI_CSI2 ERR1:0x1000000 (crc,vc: 0)
                        [  110.638814] (0xfdd30000)MIPI_CSI2 ERR1:0x1000000 (crc,vc: 0)
                        [  110.638828] (0xfdd30000)MIPI_CSI2 ERR1:0x1000000 (crc,vc: 0)
                        [  110.638842] (0xfdd30000)MIPI_CSI2 ERR1:0x1000000 (crc,vc: 0)
                        [  110.638856] (0xfdd30000)MIPI_CSI2 ERR1:0x1000000 (crc,vc: 0)
                        [  110.638871] (0xfdd30000)MIPI_CSI2 ERR1:0x1000000 (crc,vc: 0)
                        [  110.638891] (0xfdd30000)MIPI_CSI2 ERR1:0x1000 (err_data,vc: 0)
                        [  110.638925] rockchip-mipi-csi2 mipi2-csi2: stream off, src_sd: 00000000ae59244c, sd_name:rockchip-csi2-dphy0
                        [  110.638935] rockchip-mipi-csi2 mipi2-csi2: stream OFF
                        When connected to csi1, the picture is as good as always.
                        I hope that my update will help you with your debugging effort. Feel free to ask me to do some additional testing.
                          veye_xumm @xLWvU7mX
                          @xLWvU7mX
                          Regarding your question, we have recently made some research progress that I'd like to share with you.
                          Concerning the signal robustness of MIPI CSI-2, we are planning a major board revision for the GX-MIPI-IMX662 in the near future. We will be adding a MIPI equalizer chip to it. We've already tested this addition, and it will significantly optimize and improve the transmission adaptability and robustness of the MIPI CSI-2 signals.
                          Additionally, during this board revision, we will also update the PCB dimensions to a 29x29mm two-board structure, which is identical to our MV series cameras. This redesign is expected to be completed within two months. Meanwhile, we will soon release a firmware update to optimize and upgrade the ISP image quality.
                          • X Offline
                            xLWvU7mX @veye_xumm
                            I am looking forward to check out the revised version as soon as it is available. Thanks for digging into the signal integrity issues.
                            It would help greatly if you could provide newer version's connector pinout when it is stabilized so I could adjust and order the adapter FPC beforehand.
                              veye_xumm @xLWvU7mX
                              @xLWvU7mX As planned, the interface of our redesigned camera module will be fully compatible with our current MV series products. You can check its pinout from this link: https://wiki.veye.cc/index.php?title=MV-MIPI-GMAX4002M_Data_Sheet.
                              Based on this, our ADP-MV1-V2 adapter board will be fully compatible and will convert the signals of the new GX-MIPI-IMX662 to match the legacy version. You can refer to the interface definition of the ADP-MV1-V2 here: https://wiki.veye.cc/index.php?title=ADP-MV1-V2_Adapter_Board_Data_Sheet
