    RAW-MIPI-SC132M camera working in raspberry pi 5. Cannot be configured to work with the libcamera2 and opencv libraries
    17 Posts 3 Posters 6.3k Views 1 Watching
    • A Offline
      alex_ai @Sheko
      Hi @sheko, I had same problem with RPi 5, did you build and install libcamera from veye github repository? For some reason it has config json file only for RPi 4.
      First step try run it with uncalibrated json :
      rpicam-still --tuning-file /usr/local/share/libcamera/ipa/rpi/pisp/data/uncalibrated.json -t 0
      Path may be different, if failed to load json file - try to find valid path.
      if video opened - we need just put to same folder mvcam_mono.json (or add to libcamera source code, update meson.build and rebuild + reinstall )
      and check if rpicam-hello or rpicam-still works without tuning file
      I attached my current config (rename it to json) but it adopted for night sky and you need fix in json file section : exposure_modes . normal, copy it for example from se327m12.json
      mvcam_mono.txt
        veye_xumm @alex_ai
        @alex_ai
        RAW-MIPI-SC132M does not support libcamera, nor software based on libcamera. Direct invocation via the v4l2 API is required.
        A S 3 Replies Last reply Reply Quote 0
        • A Offline
          alex_ai @veye_xumm
          Hi @veye_xumm, sorry for confusion, in previous time you guided me to install custom libcamera for veye_mvcam driver and seems like this step is outdated (but I'm still using libcamera).
          @Sheko try another pipeline in openCV:
          v4l2src device=/dev/video0 ! video/x-raw,format=UYVY, width=1920, height=1080,framerate=30/1 ! videoconvert ! video/x-raw,format=GRAY8 ! appsink sync=1
          • S Offline
            Sheko @alex_ai
            @alex_ai
            command not found(((
            ~ $ v4l2src device=/dev/video0 ! video/x-raw,format=UYVY, width=1920, height=1080,framerate=30/1 ! videoconvert ! video/x-raw,format=GRAY8 ! appsink sync=1
            bash: v4l2src: command not found
            • S Offline
              Sheko @veye_xumm
              I got the title wrong - I meant Picamera2. I need to start working in Opencv first.
              ~ $ rpicam-hello
              [3:42:19.883111801] [3703]  INFO Camera camera_manager.cpp:330 libcamera v0.5.2+99-bfd68f78
              [3:42:19.894406703] [3706]  INFO RPI pisp.cpp:720 libpisp version v1.2.1 981977ff21f3 29-04-2025 (14:13:50)
              [3:42:19.895982049] [3706]  WARN CameraSensorProperties camera_sensor_properties.cpp:499 No static properties available for 'mvcam'
              [3:42:19.896044820] [3706]  WARN CameraSensorProperties camera_sensor_properties.cpp:501 Please consider updating the camera sensor properties database
              [3:42:19.899758099] [3706] ERROR IPAProxy ipa_proxy.cpp:185 Configuration file 'mvcam_mono.json' not found for IPA module 'rpi/pisp'
              [3:42:19.899815776] [3706] ERROR IPARPI ipa_base.cpp:152 Could not create camera helper for mvcam
              [3:42:19.899835354] [3706] ERROR RPI pipeline_base.cpp:814 Failed to load a suitable IPA library
              [3:42:19.899850764] [3706] ERROR RPI pisp.cpp:947 Failed to register camera mvcam 10-003b: -22
              Made X/EGL preview window
              ERROR: *** no cameras available ***
              • A Offline
                alex_ai @Sheko
                @sheko
                This is pipeline which need place to openCV instead:
                to run it from command line you need use gstreamer, try :
                gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=UYVY, width=1920, height=1080,framerate=30/1 ! videoconvert ! video/x-raw,format=GRAY8 ! appsink sync=1
                • S Offline
                  Sheko @alex_ai
                  @alex_ai
                  ~ $ gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=UYVY, width=1920, height=1080,framerate=30/1 ! videoconvert ! video/x-raw,format=GRAY8 ! appsink sync=1
                  Pipeline is PREROLLED ...
                  New clock: GstSystemClock
                  Additional debug info:
                  ../sys/v4l2/gstv4l2src.c(976): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
                  Buffer pool activation failed
                  Execution ended after 0:00:00.003958838
                  Setting pipeline to NULL ...
                  ../libs/gst/base/gstbasesrc.c(3132): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
                  Freeing pipeline ...
                  • A Offline
                    alex_ai @Sheko
                    @sheko please update pipeline with your camera parameters (width, height, framerate). I just copied mine.
                    • S Offline
                      Sheko @alex_ai
                      @alex_ai How to do this?
                      • S Offline
                        Sheko @veye_xumm
                        @veye_xumm said in RAW-MIPI-SC132M camera working in raspberry pi 5. Cannot be configured to work with the libcamera2 and opencv libraries:
                        Требуется прямой вызов через v4l2 API.
                        Direct call via v4l2 API? What does that mean? Give an example for Python.
                        • A Offline
                          alex_ai @Sheko
                          @sheko
                          As I see your standard camera parameters are: 1080x1280 120fps
                          And as it configured in python script for first step try:
                          cap = cv2.VideoCapture('v4l2src device=/dev/video0')
                          if still failing try with passing parameters to gstreamer:
                          cap = cv2.VideoCapture('v4l2src device=/dev/video0 ! video/x-raw,format=UYVY, width=1080, height=1280,framerate=120/1 ! videoconvert ! video/x-raw,format=GRAY8 ! appsink sync=1')
                          or from command line to check if gstreamer works without python
                          gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=UYVY, width=1080, height=1280,framerate=120/1 ! videoconvert ! video/x-raw,format=GRAY8 ! appsink sync=1
                          if still failing try RAW8 format
                          gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=RAW8, width=1080, height=1280,framerate=120/1 ! appsink sync=1
                          if still failing, can't help, I don't have this sensor.
                          • S Offline
                            Sheko @alex_ai
                            @alex_ai
                            error
                            ~ $ cap = cv2.VideoCapture('v4l2src device=/dev/video0
                            bash: syntax error near unexpected token `('
                            ~ $ cap = cv2.VideoCapture('v4l2src device=/dev/video0 ! video/x-raw,format=UYVY, width=1080, height=1280,framerate=120/1 ! videoconvert ! video/x-raw,format=GRAY8 ! appsink sync=1')
                            ~ $ gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=UYVY, width=1080, height=1280,framerate=120/1 ! videoconvert ! video/x-raw,format=GRAY8 ! appsink sync=1
                            Execution ended after 0:00:00.003339447
                            ~ $ gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=RAW8, width=1080, height=1280,framerate=120/1 ! appsink sync=1
                            WARNING: erroneous pipeline: could not link v4l2src0 to appsink0, v4l2src0 can't handle caps video/x-raw, format=(string)RAW8, width=(int)1080, height=(int)1280, framerate=(fraction)120/1
                            • S Offline
                              Sheko
                              It turns out the manufacturer is ignoring requests for help. Only kind and caring people are helping... The problem remains unresolved.
                                veye_xumm @Sheko
                                @sheko Sorry, I just got back from the Chinese New Year holiday. Regarding using the RAW-MIPI-SC132M on the Raspberry Pi 5, I suggest you primarily refer to this document. It covers driver installation, how to use the V4L2 mode, and methods for previewing using OpenCV.
                                https://wiki.veye.cc/index.php/Mv_series_camera_appnotes_4_rpi
