    RAW-MIPI-SC132M camera working in raspberry pi 5. Cannot be configured to work with the libcamera2 and opencv libraries
    17 Posts 3 Posters 6.3k Views 1 Watching
    • S Offline
      Sheko @veye_xumm
      I got the title wrong - I meant Picamera2. I need to start working in Opencv first.
      ~ $ rpicam-hello
      [3:42:19.883111801] [3703]  INFO Camera camera_manager.cpp:330 libcamera v0.5.2+99-bfd68f78
      [3:42:19.894406703] [3706]  INFO RPI pisp.cpp:720 libpisp version v1.2.1 981977ff21f3 29-04-2025 (14:13:50)
      [3:42:19.895982049] [3706]  WARN CameraSensorProperties camera_sensor_properties.cpp:499 No static properties available for 'mvcam'
      [3:42:19.896044820] [3706]  WARN CameraSensorProperties camera_sensor_properties.cpp:501 Please consider updating the camera sensor properties database
      [3:42:19.899758099] [3706] ERROR IPAProxy ipa_proxy.cpp:185 Configuration file 'mvcam_mono.json' not found for IPA module 'rpi/pisp'
      [3:42:19.899815776] [3706] ERROR IPARPI ipa_base.cpp:152 Could not create camera helper for mvcam
      [3:42:19.899835354] [3706] ERROR RPI pipeline_base.cpp:814 Failed to load a suitable IPA library
      [3:42:19.899850764] [3706] ERROR RPI pisp.cpp:947 Failed to register camera mvcam 10-003b: -22
      Made X/EGL preview window
      ERROR: *** no cameras available ***
      • A Offline
        alex_ai @Sheko
        @sheko
        This is pipeline which need place to openCV instead:
        to run it from command line you need use gstreamer, try :
        gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=UYVY, width=1920, height=1080,framerate=30/1 ! videoconvert ! video/x-raw,format=GRAY8 ! appsink sync=1
        • S Offline
          Sheko @alex_ai
          @alex_ai
          ~ $ gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=UYVY, width=1920, height=1080,framerate=30/1 ! videoconvert ! video/x-raw,format=GRAY8 ! appsink sync=1
          Pipeline is PREROLLED ...
          New clock: GstSystemClock
          Additional debug info:
          ../sys/v4l2/gstv4l2src.c(976): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
          Buffer pool activation failed
          Execution ended after 0:00:00.003958838
          Setting pipeline to NULL ...
          ../libs/gst/base/gstbasesrc.c(3132): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
          Freeing pipeline ...
          • A Offline
            alex_ai @Sheko
            @sheko please update pipeline with your camera parameters (width, height, framerate). I just copied mine.
            • S Offline
              Sheko @alex_ai
              @alex_ai How to do this?
              • S Offline
                Sheko @veye_xumm
                @veye_xumm said in RAW-MIPI-SC132M camera working in raspberry pi 5. Cannot be configured to work with the libcamera2 and opencv libraries:
                Требуется прямой вызов через v4l2 API.
                Direct call via v4l2 API? What does that mean? Give an example for Python.
                • A Offline
                  alex_ai @Sheko
                  @sheko
                  As I see your standard camera parameters are: 1080x1280 120fps
                  And as it configured in python script for first step try:
                  cap = cv2.VideoCapture('v4l2src device=/dev/video0')
                  if still failing try with passing parameters to gstreamer:
                  cap = cv2.VideoCapture('v4l2src device=/dev/video0 ! video/x-raw,format=UYVY, width=1080, height=1280,framerate=120/1 ! videoconvert ! video/x-raw,format=GRAY8 ! appsink sync=1')
                  or from command line to check if gstreamer works without python
                  gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=UYVY, width=1080, height=1280,framerate=120/1 ! videoconvert ! video/x-raw,format=GRAY8 ! appsink sync=1
                  if still failing try RAW8 format
                  gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=RAW8, width=1080, height=1280,framerate=120/1 ! appsink sync=1
                  if still failing, can't help, I don't have this sensor.
                  • S Offline
                    Sheko @alex_ai
                    @alex_ai
                    error
                    ~ $ cap = cv2.VideoCapture('v4l2src device=/dev/video0
                    bash: syntax error near unexpected token `('
                    ~ $ cap = cv2.VideoCapture('v4l2src device=/dev/video0 ! video/x-raw,format=UYVY, width=1080, height=1280,framerate=120/1 ! videoconvert ! video/x-raw,format=GRAY8 ! appsink sync=1')
                    ~ $ gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=UYVY, width=1080, height=1280,framerate=120/1 ! videoconvert ! video/x-raw,format=GRAY8 ! appsink sync=1
                    Execution ended after 0:00:00.003339447
                    ~ $ gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=RAW8, width=1080, height=1280,framerate=120/1 ! appsink sync=1
                    WARNING: erroneous pipeline: could not link v4l2src0 to appsink0, v4l2src0 can't handle caps video/x-raw, format=(string)RAW8, width=(int)1080, height=(int)1280, framerate=(fraction)120/1
                    • S Offline
                      Sheko
                      It turns out the manufacturer is ignoring requests for help. Only kind and caring people are helping... The problem remains unresolved.
                        veye_xumm @Sheko
                        @sheko Sorry, I just got back from the Chinese New Year holiday. Regarding using the RAW-MIPI-SC132M on the Raspberry Pi 5, I suggest you primarily refer to this document. It covers driver installation, how to use the V4L2 mode, and methods for previewing using OpenCV.
                        https://wiki.veye.cc/index.php/Mv_series_camera_appnotes_4_rpi
