    OrangePi cm5-tablet RAW-MIPI-SC132M
    35 Posts 3 Posters 16.8k Views 2 Watching
    • zoldatenZ Offline
      zoldaten @veye_xumm
      @veye_xumm veye appears only on image you provided via download link.
      the image i built has no veye on board.
      should i change the main dts after decompilation ...tablet.dbt > ...tablet.dts?
      or use somehow dtsi (https://github.com/veyeimaging/rk35xx_orangepi/tree/main/linux/drivers/cm5/cm5-mvcam-dts) to link with your ...tablet.dbt ?
        veye_xumm @zoldaten
        @zoldaten
        As long as you follow the steps and place our driver and DTS files into the Orange Pi source tree, then compile the image according to the official Orange Pi instructions and flash this image onto the board, the VEYE camera driver should appear correctly.
        Essentially, this operation just adds the driver to the original standard Orange Pi system. No additional steps are required after flashing the image. I suspect that you may not have fully applied the modifications in all the necessary parts of the source code.
        zoldatenZ 2 Replies Last reply Reply Quote 0
        • zoldatenZ Offline
          zoldaten @veye_xumm
          @veye_xumm hi. i`m trying to build Kernel itself left alone the full image.
          and see this error in compile the veye driver:
          so the problem in driver file - [0_1772540181473_veyecam2m.zip](Загрузка 100%)
          • zoldatenZ Offline
            zoldaten @veye_xumm
            @veye_xumm and could you check steps it did before start build process:
            sudo cp -r rk35xx_orangepi/linux/drivers/cm5/cm5-mvcam-dts orangepi-build/kernel/orange-pi-5.10-rk35xx/arch/arm64/boot/dts/rockchip/
            sudo cp rk35xx_orangepi/linux/drivers/cm5/config/linux-rockchip-rk3588-legacy.config orangepi-build/external/config/kernel/linux-rockchip-rk3588-legacy.config
            sudo cp -r rk35xx_veye_bsp/linux/drivers/kernel_v5.10 orangepi-build/kernel/orange-pi-5.10-rk35xx/drivers/media/i2c/
            sudo nano orangepi-build/kernel/orange-pi-5.10-rk35xx/drivers/media/i2c/Kconfig
            config VIDEO_DS90UB954
                   tristate "TI FDPLINK III support."
                   depends on I2C && VIDEO_V4L2 && VIDEO_V4L2_SUBDEV_API
                   help
                        Driver for TI FDPLINK III .
            config VIDEO_VEYECAM2M
                   tristate "VEYE 2M camera support."
                   depends on MEDIA_CAMERA_SUPPORT
                   help
                           Driver for veye 2m camera.
            config VIDEO_VEYEMVCAM
                   tristate "VEYE MV series camera support."
                   help
                           Driver for veye mv series camera.
            config VIDEO_VEYEVBYONE
                   tristate "VEYE V-by-One hs toolkit support."
                   help
                           Driver for vV-by-One hs toolkit .
            sudo nano orangepi-build/kernel/orange-pi-5.10-rk35xx/drivers/media/i2c/Makefile
            obj-$(CONFIG_VIDEO_DS90UB954) += ds90ub954.o
            obj-$(CONFIG_VIDEO_VEYEVBYONE) += veye_vbyone.o
            obj-$(CONFIG_VIDEO_VEYECAM2M) += veyecam2m.o
            obj-$(CONFIG_VIDEO_VEYEMVCAM) += veye_mvcam.o
            may be i miss something leads to empty image ?
              veye_xumm @zoldaten
              @zoldaten
              In the source code of veyecam2m.c, please comment out this function.
              Additionally, since you are using the RAW-MIPI-SC132M camera, you only need the mvcam driver and its corresponding dtb.
              zoldatenZ 1 Reply Last reply Reply Quote 0
              • zoldatenZ Offline
                zoldaten @veye_xumm
                @veye_xumm ok. i just del it and remove from Makefile.
                and changed in main dts - uncomment camera-1.
                build kernel package without full image.
                installed to jammy 20.04 via dpkg.
                and... my mixed cams start working !
                later i`ll tried to repair broken driver for veye you provided.
                thanks for help!
                  veye_xumm @zoldaten
                  @zoldaten looking forward to your good news.
                  • zoldatenZ Offline
                    zoldaten @veye_xumm
                    @veye_xumm hi. could you provide link to image kernel 6.* image with cameras integrated ?
                    as far as i saw there are only kernel 5.10 links...
                      veye_xumm @zoldaten
                      @zoldaten Sorry, we currently only provide kernel version 5.x images for Orange Pi. If you need version 6.x, you will need to compile it yourself based on our open-source code.
                      • zoldatenZ Offline
                        zoldaten @veye_xumm
                        @veye_xumm got it. i tried to do that but have segmentation fault - something wrong with mali drivers. at the same time drivers for cameras built correctly.
                        • zoldatenZ Offline
                          zoldaten @veye_xumm
                          @veye_xumm said in OrangePi cm5-tablet RAW-MIPI-SC132M:
                          hi. i built kernel 6.1.99 - but the errors almost the same as in start of the spoiler to this topic:
                          in build progress i saw strange missing packages errors.
                          could your check your instructions ? may be them got obsolete ?
                            veye_xumm @zoldaten
                            @zoldaten You can ignore the warning shown in your screenshot. However, your probe information is incomplete; it seems that the mvcam probe function has not been triggered.
                            • zoldatenZ Offline
                              zoldaten @veye_xumm
                              @veye_xumm i think so.
                              please see screens attached:
                              when i copied .dts files from veye i saw errors building missing files.
                              i tried to build on:
                              • orange pi 5 tablet
                              • VM machine with Ubuntu 22.04 installed
                                got the same errors.
                                please check your files.
