    OrangePi cm5-tablet RAW-MIPI-SC132M
    35 Posts 3 Posters 16.8k Views 2 Watching
    • zoldatenZ Offline
      zoldaten @veye_xumm
      @veye_xumm and could you check steps it did before start build process:
      sudo cp -r rk35xx_orangepi/linux/drivers/cm5/cm5-mvcam-dts orangepi-build/kernel/orange-pi-5.10-rk35xx/arch/arm64/boot/dts/rockchip/
      sudo cp rk35xx_orangepi/linux/drivers/cm5/config/linux-rockchip-rk3588-legacy.config orangepi-build/external/config/kernel/linux-rockchip-rk3588-legacy.config
      sudo cp -r rk35xx_veye_bsp/linux/drivers/kernel_v5.10 orangepi-build/kernel/orange-pi-5.10-rk35xx/drivers/media/i2c/
      sudo nano orangepi-build/kernel/orange-pi-5.10-rk35xx/drivers/media/i2c/Kconfig
      config VIDEO_DS90UB954
             tristate "TI FDPLINK III support."
             depends on I2C && VIDEO_V4L2 && VIDEO_V4L2_SUBDEV_API
             help
                  Driver for TI FDPLINK III .
      config VIDEO_VEYECAM2M
             tristate "VEYE 2M camera support."
             depends on MEDIA_CAMERA_SUPPORT
             help
                     Driver for veye 2m camera.
      config VIDEO_VEYEMVCAM
             tristate "VEYE MV series camera support."
             help
                     Driver for veye mv series camera.
      config VIDEO_VEYEVBYONE
             tristate "VEYE V-by-One hs toolkit support."
             help
                     Driver for vV-by-One hs toolkit .
      sudo nano orangepi-build/kernel/orange-pi-5.10-rk35xx/drivers/media/i2c/Makefile
      obj-$(CONFIG_VIDEO_DS90UB954) += ds90ub954.o
      obj-$(CONFIG_VIDEO_VEYEVBYONE) += veye_vbyone.o
      obj-$(CONFIG_VIDEO_VEYECAM2M) += veyecam2m.o
      obj-$(CONFIG_VIDEO_VEYEMVCAM) += veye_mvcam.o
      may be i miss something leads to empty image ?
        veye_xumm @zoldaten
        @zoldaten
        In the source code of veyecam2m.c, please comment out this function.
        Additionally, since you are using the RAW-MIPI-SC132M camera, you only need the mvcam driver and its corresponding dtb.
        zoldatenZ 1 Reply Last reply Reply Quote 0
        • zoldatenZ Offline
          zoldaten @veye_xumm
          @veye_xumm ok. i just del it and remove from Makefile.
          and changed in main dts - uncomment camera-1.
          build kernel package without full image.
          installed to jammy 20.04 via dpkg.
          and... my mixed cams start working !
          later i`ll tried to repair broken driver for veye you provided.
          thanks for help!
            veye_xumm @zoldaten
            @zoldaten looking forward to your good news.
            • zoldatenZ Offline
              zoldaten @veye_xumm
              @veye_xumm hi. could you provide link to image kernel 6.* image with cameras integrated ?
              as far as i saw there are only kernel 5.10 links...
                veye_xumm @zoldaten
                @zoldaten Sorry, we currently only provide kernel version 5.x images for Orange Pi. If you need version 6.x, you will need to compile it yourself based on our open-source code.
                zoldatenZ 2 Replies Last reply Reply Quote 0
                • zoldatenZ Offline
                  zoldaten @veye_xumm
                  @veye_xumm got it. i tried to do that but have segmentation fault - something wrong with mali drivers. at the same time drivers for cameras built correctly.
                  • zoldatenZ Offline
                    zoldaten @veye_xumm
                    @veye_xumm said in OrangePi cm5-tablet RAW-MIPI-SC132M:
                    hi. i built kernel 6.1.99 - but the errors almost the same as in start of the spoiler to this topic:
                    in build progress i saw strange missing packages errors.
                    could your check your instructions ? may be them got obsolete ?
                      veye_xumm @zoldaten
                      @zoldaten You can ignore the warning shown in your screenshot. However, your probe information is incomplete; it seems that the mvcam probe function has not been triggered.
                      • zoldatenZ Offline
                        zoldaten @veye_xumm
                        @veye_xumm i think so.
                        please see screens attached:
                        when i copied .dts files from veye i saw errors building missing files.
                        i tried to build on:
                        • orange pi 5 tablet
                        • VM machine with Ubuntu 22.04 installed
                          got the same errors.
                          please check your files.
