    SOLVED Taking images with IMX462 in Python
    1402
    • S
      Seka last edited by
      can I use the same scripts for python with IMX462 camera as I use for IMX327?
      I somehow cannot initialize the camera:
      import D_mipicamera as Dcam
      camera = Dcam.mipi_camera()
      camera.init_camera()
      import os
      status = os.system('sh ./veye_mipi_i2c.sh -w -f cameramode -p1 0x0 -b 10')
      print status
      status = os.system('sh ./veye_mipi_i2c.sh -w -f daynightmode -p1 0xFC -p1 0x00 -b 10')
      #print status
      ##turn off automatic exposure
      status = os.system('sh ./veye_mipi_i2c.sh -w -f agc -p1 0 -b 10')
      print status
      ##turn off white balance
      status = os.system('sh ./veye_mipi_i2c.sh -w -f wbmode -p1 0x1b -b 10')
      print status
      status = os.system('sh ./veye_mipi_i2c.sh -w -f lowlight -p1 0x09  -b 10')
      print status
      directory="/home/pi/testmipi/"
      date = datetime.datetime.now().strftime("%m_%d_%Y_%H_%M_%S")
      frame = camera.capture(encoding = 'jpeg')
      camera.release_buffer(frame)
      del frame
      time.sleep(1)
      frame.as_array.tofile((directory)+"nm590"+ date + ".jpg")
      del frame
        veye_xumm @Seka last edited by
        @seka
        I think you need to run
        ./rpi3-gpiovirtbuf s 133 1
        to power up VEYE-MIPI-IMX462 first. Because on imx462 module, the reset pin is effective.
        I will upgrade our python demo later.
        • S
          Seka last edited by
          Thank you Xu,
          ok, I can now initiate the camera but get another pointer access error when running:
           frame = camera.capture(encoding = 'raw')
              frame.as_array.tofile((directory)+"nm280"+ date + ".raw")
          The error I get is:
          In [48]: frame.as_array.tofile((directory)+"nm280"+ date + ".raw")
          Traceback (most recent call last):
            File "<ipython-input-48-46dc4d541567>", line 1, in <module>
            File "D_mipicamera.py", line 208, in as_array
              return np.ctypeslib.as_array(self.buffer_ptr[0].data, shape=(self.length,))
          ValueError: NULL pointer access
          Can you please send me a line of code with which I can create a raw image ?
          Many thanks
            @seka
            sorry for reply late.
            I think this camera do not support [raw format].
            Since it only support YUV422(UYVY/YUYV), the python demo only support capture file format :
            IMAGE_ENCODING_JPEG, IMAGE_ENCODING_I420,IMAGE_ENCODING_BMP,IMAGE_ENCODING_PNG
            • S
              Seka @veye_xumm last edited by
              @veye_xumm so is here a way to create raw images at all? with bash script?
              Can you please write a line of code in python or bash with which I can capture images in raw format?
              Many thanks
                @seka
                hi,
                This camera module can not output raw data.
                It has an ISP module built-in, the output format is YUV.
                • S
                  @veye_xumm Is there a way to capture with 10 or 12 bit depth as the sensor is capable of?
                  This is part of the manual that I received from you.
                  It seems like this is raw format, no?
                  • S
                    @veye_xumm but yuv is 10 or 12 bit?? that would be ok for me too...
                    Can you please adjust my code so that I capture in 10- or 12 bit YUV?
                    Thank you
                    • S
                      Seka @Seka last edited by
                      @seka ```
                      frame = camera.capture(encoding = 'i420')
                             frame.as_array.tofile("test.yuv")
                      probably like this??
                        @seka
                        hi, VEYE-MIPI-IMX462 do not support YUV 10BIT/12BIT.
