    RPI Camera IMX327 different brightness values between startups
    15 Posts 2 Posters 4.7k Views 1 Watching
    • S Offline
      Seka @Seka
      @seka regarding example code: I still run the i2c commands and just raspistill, and that is all i guess... how much sleep between i2c commands do you recommend between commands and before taking image?
        veye_xumm @Seka
        @seka
        I see your question.
        There is no need to test with raspistill, the result should be the same as your python test.
        I have some test suggestions that you can try.
        1. Do not enable low_light mode.
        2. Increase the speed of ae adjustment at the beginning of your scripts.
        . / veye_mipi_i2c.sh-w-f aespeed-p1 0x64-p2 0x64
        It's just for the purpose of pure testing.
        • S Offline
          Seka @veye_xumm
          @veye_xumm I just checked and another problem I have: I get no return value from the whitebalance mode and I cannot read its state also....
          • S Offline
            Seka @Seka
            @seka Sorry, realised I had this error before: Problem: not current veye_mipi_i2c.sh ... solved now
            • S Offline
              Seka @Seka
              @seka with regarding to your suggestion " do not enable low_light mode": When I disable it, images are very dark.... and I already have longest shutter settings....
              • S Offline
                Seka @Seka
                @seka another problem that now occurs (and which has occured seldomly before): images are corrupted:
                • S Offline
                  Seka @Seka
                  @seka ok, I understand now what the problem is: os.system does not reliably execute shell commands. When executing directly in the terminal ---> problem is gone. Thank you
                    veye_xumm @Seka
                    @seka
                    All problems sloved?
                    • S Offline
                      Seka @veye_xumm
                      @veye_xumm No, but I am currently assessing wether it is a light source problem or camera problem. Will get back soon..
                      • S Offline
                        Seka @Seka
                        @seka Seems to be fixed right now
                          veye_xumm @Seka
                          @seka OK~
