At mgain=10 we don't see anything, neither hot pixels nor stars.
We see other people using the cam with mgain = 25 and no hot pixels at all.
And we had one set of parameters, where we didn't have hot pixels at mgain = 25 either.
It only lasted 5 minutes though.
Latest posts made by JaCC
RE: VEYE-MIPI-IMX385 hot pixels
Attached is a test shot. This particular shot has been taken at new_mgain=30 and 1 sec exposure, we do see ~30 bright hot pixels already at new_mgain=25 and 40 ms exposure.
Since this is fish eye shot, stars are to be expected only in the brighter circular area in the middle.
blocking the lens, we see the stars vanish and only the hot pixels remain. -
Thank you for answering quickly.
We work with:
new_mgain: 25 ... 45
new_mshutter: 40.000 ... 100.000Else we use the configuration posted above.
Hot pixels are there in every setting, but more prominent for higher sensitivity.
For ~5 minutes we got rid of most of the hot pixels with brightness set to 0x32, but with the next parameter setting (changing other parameters) they reappeared and afterwards we could not reproduce this behavior.An actual image will be available tomorrow.
And, is there an internal gamma correction available?
Hello,
during nighttime operation we noticed quite a large amount of hot pixels at gain values ≥ 25. Additionally, it seems like pixels below a certain brightness threshold get set to black? We believe this because objects in the foreground are clearly visible, but anything beyond approximately 2 meters becomes almost imperceptible.This is a script used to set the i2c parameters:
./veye_mipi_i2c.sh -w -f videoformat -p1 PAL sleep 1 ./veye_mipi_i2c.sh -w -f sharppen -p1 0 sleep 0.2 ./veye_mipi_i2c.sh -w -f irtrigger -p1 0 sleep 0.2 ./veye_mipi_i2c.sh -w -f lowlight -p1 0x00 #fixed 25 fps sleep 0.2 ./veye_mipi_i2c.sh -w -f wdrmode -p1 0x00 #back light mode off sleep 0.2 ./veye_mipi_i2c.sh -w -f wdrtargetbr -p1 0xff #for wdrmode 0x03 sleep 0.2 ./veye_mipi_i2c.sh -w -f denoise -p1 0x00 sleep 0.2 ./veye_mipi_i2c.sh -w -f daynightmode -p1 0xfe #Black and White mode sleep 0.2 ./veye_mipi_i2c.sh -w -f new_expmode -p1 1 sleep 0.2 ./veye_mipi_i2c.sh -w -f new_mshutter -p1 100000 # in µs sleep 0.2 ./veye_mipi_i2c.sh -w -f new_mgain -p1 45 #0.1 - 0.3 sleep 0.2 ./veye_mipi_i2c.sh -w -f brightness -p1 0x00Does anyone have some advice as to why this could be and how to fix it?
