    2. Scroll
    S
    Offline
    • Topics 1
    • Posts 2
    Scroll
    @Scroll
    Joined
    Last Online
    Scroll Unfollow Follow
    Latest posts made by Scroll
    • RE: RK3568 GC8034 相机预览画面异常绿屏
       EVB3568 V2 csi split mode
              vcc_camera: vcc-camera-regulator {
                      compatible = "regulator-fixed";
                      gpio = <&gpio0 RK_PD3 GPIO_ACTIVE_HIGH>;
                      pinctrl-names = "default";
                      pinctrl-0 = <&camera_pwr>;
                      regulator-name = "vcc_camera";
                      enable-active-high;
                      regulator-always-on;
                      regulator-boot-on;
              flash_sgm3141:flash-sgm3141 {
                      status = "okay";
                      compatible = "sgmicro,sgm3141";
                      label = "gpio-flash";
                      pinctrl-0 = <&flash_led_gpios>;
                      led-max-microamp = <20000>;
                      flash-max-microamp = <20000>;
                      flash-max-timeout-us = <1000000>;
                      strobe-gpios = <&gpio3 RK_PD4 GPIO_ACTIVE_HIGH>;
                      enable-gpios = <&gpio3 RK_PD5 GPIO_ACTIVE_HIGH>;
      &i2c4 {
      	status = "okay";
              dw9714: dw9714@0c {
      		compatible = "dongwoon,dw9714";
      		status = "okay";
      		reg = <0x0c>;
      		rockchip,vcm-max-current = <100>;
      		rockchip,vcm-start-current = <0>;
      		rockchip,vcm-rated-current = <100>;
      		rockchip,vcm-step-mode = <0xd>;
      		rockchip,vcm-dlc-enable = <0>;
      		rockchip,vcm-mclk = <0>;
      		rockchip,vcm-t-src = <0>;
      		rockchip,camera-module-facing = "back"; //"fornt";
              gc8034: gc8034@37 {
      		status = "okay";
      		compatible = "galaxycore,gc8034";
      		reg = <0x37>;
                      clocks = <&cru CLK_CAM0_OUT>;
                      clock-names = "xvclk";
                      power-domains = <&power RK3568_PD_VI>;
                      pinctrl-0 = <&cam_clkout0>;
      		//pinctrl-1 = <&cam_split_2>;
      		// power-gpios = <&gpio4 RK_PD2 GPIO_ACTIVE_HIGH>;
      		// reset-gpios = <&gpio3 RK_PD6 GPIO_ACTIVE_HIGH>;
      		// pwdn-gpios = <&gpio3 RK_PD7 GPIO_ACTIVE_HIGH>;
                      reset-gpios = <&gpio4 RK_PA0 GPIO_ACTIVE_LOW>;
                      pwdn-gpios = <&gpio4 RK_PA1 GPIO_ACTIVE_LOW>;
                      rockchip,grf = <&grf>;
                      rockchip,camera-module-name = "RK-CMK-8M-2-v1";
                      rockchip,camera-module-lens-name = "CK8401";
                      lens-focus = <&dw9714>;
                      flash-leds = <&flash_sgm3141>;
      		port {
      			gc8034_2_out: endpoint {
      				remote-endpoint = <&dphy1_in>;
      				data-lanes = <1 2>;
              ov8858: ov8858@36 {
                      status = "disabled";
                      compatible = "ovti,ov8858";
                      reg = <0x36>;                     //36,10
                      //pinctrl-1 = <&cam_split_1>;
                      reset-gpios = <&gpio4 RK_PA0 GPIO_ACTIVE_HIGH>;
                      pwdn-gpios = <&gpio4 RK_PA1 GPIO_ACTIVE_HIGH>;
                      rockchip,camera-module-index = <1>;
                      rockchip,camera-module-facing = "front";
                      rockchip,camera-module-name = "HS5885-BNSM1018-V01";
                      rockchip,camera-module-lens-name = "default";
                      port {
                              ov8858_out: endpoint {
                                      remote-endpoint = <&dphy1_in_ov8858>;
                                      data-lanes = <1 2>;
      &i2c2 {
              status = "okay";
              pinctrl-0 = <&i2c2m1_xfer>;
              dw9714: dw9714@0c {
      		status = "okay";
      		reg = <0x0c>;
              gc8034: gc8034@37 {
      		status = "okay";
      		reg = <0x37>;
                      clocks = <&cru CLK_CAM1_OUT>;
                      pinctrl-0 = <&cam_clkout1>;
      		reset-gpios = <&gpio3 RK_PD6 GPIO_ACTIVE_LOW>;
      		pwdn-gpios = <&gpio3 RK_PD7 GPIO_ACTIVE_LOW>;
      		port {
      				remote-endpoint = <&dphy2_in>;
      				data-lanes = <1 2>;
      &csi2_dphy0 {
      &csi2_dphy1 {
              status = "okay";
              * dphy1 only used for split mode,
              * can be used  concurrently  with dphy2
              * full mode and split mode are mutually exclusive
              ports {
                      #address-cells = <1>;
                      #size-cells = <0>;
                      port@0 {
                              reg = <0>;
                              #size-cells = <0>;
                              dphy1_in_ov8858: endpoint@1 {
                                              reg = <1>;
                                              remote-endpoint = <&ov8858_out>;
                                              data-lanes = <1 2>;
                      port@1 {
                              reg = <1>;
                              #size-cells = <0>;
                              dphy1_out: endpoint@1 {
                                              reg = <1>;
                                              remote-endpoint = <&isp0_in>;
      &csi2_dphy2 {
              status = "okay";
              * dphy2 only used for split mode,
              * can be used  concurrently  with dphy1
              ports {
                      #size-cells = <0>;
                      port@0 {
                              reg = <0>;
                              #size-cells = <0>;
                              dphy2_in: endpoint@1 {
                                              reg = <1>;
                                              remote-endpoint = <&gc8034_2_out>;
                                              data-lanes = <1 2>;
                      port@1 {
                              reg = <1>;
                              #size-cells = <0>;
                              dphy2_out: endpoint@1 {
                                              reg = <1>;
                                              remote-endpoint = <&mipi_csi2_input>;
      &mipi_csi2 {
              status = "okay";
              ports {
                      #size-cells = <0>;
                      port@0 {
                              reg = <0>;
                              #size-cells = <0>;
                              mipi_csi2_input: endpoint@1 {
                                              reg = <1>;
                                              remote-endpoint = <&dphy2_out>;
                                              data-lanes = <1 2>;
                      port@1 {
                              reg = <1>;
                              #size-cells = <0>;
                              mipi_csi2_output: endpoint@0 {
                                              reg = <0>;
                                              remote-endpoint = <&cif_mipi_in>;
                                              data-lanes = <1 2>;
      &rkcif_mipi_lvds {
              status = "okay";
              port {
                      cif_mipi_in: endpoint {
                              remote-endpoint = <&mipi_csi2_output>;
                              data-lanes = <1 2>;
      &rkcif_mipi_lvds_sditf {
              status = "okay";
              port {
                      mipi_lvds_sditf: endpoint {
                              remote-endpoint = <&isp1_in>;
                              data-lanes = <1 2>;
      &csi2_dphy_hw {
      	status = "okay";
      &rkisp {
      	status = "okay";
      &rkisp_mmu {
      	status = "okay";
      &rkisp_vir0 {
              status = "okay";
              port {
                      #size-cells = <0>;
                      isp0_in: endpoint@0 {
                              reg = <0>;
                              remote-endpoint = <&dphy1_out>;
      &rkisp_vir1 {
              status = "okay";
              port {
                      #size-cells = <0>;
                      isp1_in: endpoint@0 {
                              reg = <0>;
                              remote-endpoint = <&mipi_lvds_sditf>;
      &rkcif_mmu {
          status = "okay";
      &rkcif {
          status = "okay";
      &pinctrl {
              cam {
                      camera_pwr: camera-pwr {
                              rockchip,pins =
                                      /* camera power en */
                                      <0 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>;
      	camera_pins {
      		cam_split_1: cam_split-1 {
      			rockchip,pins = <4 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>,
                                              <4 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>;
                      cam_split_2: cam_split-2 {
      			rockchip,pins = <3 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>,
                                              <3 RK_PD7 RK_FUNC_GPIO &pcfg_pull_up>;
              flash-led {
                      flash_led_gpios: flash-led {
                              rockchip,pins =
                                      /* flash led enable*/
                                      <3 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>,
                                      <3 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>;
      posted in Rockchip App camera
      S
      Scroll
    • RK3568 GC8034 相机预览画面异常绿屏
      描述
      我这边用的是2 lane配置,dts文件如下
      S
      Scroll
