• 树莓派5 IMX264 RAW12完全不可用
    G
    @veye_xumm roi就是最大值,2464*2056 fps也是最大值,不过试过不同fps,最短的fps 1Hz也回出现这个问题。 试过了设置不同的roi也会出现。 感觉是2464不需要pad导致的问题,IMX178 有pad,RAW10也有pad都没问题。
  • 树莓派5能不能提供Y12格式?
    @golden0514 树莓派的piOS后面好像是去掉了unpacked格式的直接支持。回头我们再研究一下看看。
  • IMX462+树莓派zero 2w,无法正常控制曝光参数去拍照
    @veye_xumm said in IMX462+树莓派zero 2w,无法正常控制曝光参数去拍照: @若兮鱼 你使用的是驱动模式,不需要调用camera_i2c_config 核心问题是i2c_write这个可执行文件无法执行。可能是发布的release版本,与你的系统在可执行文件格式方面兼容性不好。你可以进入source目录下,编译一下。然后重新执行。 首先可以通过读取devid来确认你的i2c命令通道,veye_mipi_i2c.sh脚本是否正常了。 你好,谢谢,重新编译source目录里的文件后都正常了。问题已解决。
  • Can't get v4l2 to work, rasbperry pi 4b, rpi os x64, 6.12.57-v8+
    29
    12k Views
    J
    @veye_xumm it is resolved now, the image is shown. Before with the steps on the forum the .dtbo file was also missing, I copied it from another folder and it didn't work. The right and supported way of installing drivers is very confusing, I tried installing by wiki guide and then compiling locally (github), since it didn't work. Thank you for your patience.
  • 有一些错误 ,大神们 请指教啊raspi5 +imx78
    @nian 不客气
  • buildme failed
    7
    4k Views
    I
    @veye_xumm Thanks! I'll read and reinstall the SO. Hopefully, I'll be able to show if the problem is resolved in the next few days.
  • Raspberry Pi 5 IMX264 + IMX287
    4k Views
    O
    @veye_xumm Thanks my problem is solved.
  • Raspberry pi 5 6.6.51+rpt-rpi-2712
    @opti Please check this: https://github.com/veyeimaging/raspberrypi_v4l2/releases/tag/v1.22
  • 树莓派5 + RAW-MIPI-IMX462M编译出错
    8
    @chenhaoyu 这个实现不了,树莓派只有两个mipi口。
  • 树莓派5 一个mipi接口连接相机无法识别问题
    @sqf121 这个问题已经解决,请参考一下github上的更新。 https://github.com/veyeimaging/raspberrypi_v4l2
  • 树莓派5+bookworm +IMX365 遇到问题
    F
    pi@raspberrypi:~/raspberrypi_v4l2/i2c_cmd/source $ sudo ./make.sh 问题: i2c_read.c: In function ‘main’: i2c_read.c:112:42: warning: passing argument 4 of ‘i2c_rd’ from incompatible pointer type [-Wincompatible-pointer-types] 112 | i2c_rd(fd, device_addr,reg_addr, &value, num); | ^~~~~~ | | | unsigned char (*)[512] i2c_read.c:20:68: note: expected ‘unsigned char ’ but argument is of type ‘unsigned char ()[512]’ 20 | static int i2c_rd(int fd, uint8_t i2c_addr, uint16_t reg, uint8_t *values, uint32_t n) [image: 1714405783705-5157972e-2e6f-451a-b0df-c2344adf9ed2-001.jpg] pi@raspberrypi:~/raspberrypi_v4l2/i2c_cmd/source $ dmesg | grep veye [ 2.947096] veyecam2m: loading out-of-tree module taints kernel. [ 2.957137] veyecam2m 4-003b: Unable to load ds90ub954 driver,will go on [ 2.984139] rp1-cfe 1f00110000.csi: found subdevice /axi/pcie@120000/rp1/i2c@88000/veyecam2m@3b [ 2.984914] rp1-cfe 1f00128000.csi: found subdevice /axi/pcie@120000/rp1/i2c@80000/veyecam2m@3b [ 3.082974] veyecam2m 4-003b: camera id is veyecam2m [ 3.084546] veyecam2m 4-003b: sensor is IMX385 [ 3.084552] veyecam2m 4-003b: board type is ONE board [ 3.084970] rp1-cfe 1f00128000.csi: Using sensor veyecam2m 4-003b for capture [ 3.106635] veyecam2m 4-003b: veyecam2m camera probed [ 3.113508] veyecam2m 6-003b: Unable to load ds90ub954 driver,will go on [ 3.229811] veyecam2m 6-003b: probe failed pi@raspberrypi:~/raspberrypi_v4l2/i2c_cmd/source $ cd cd raspberrypi_v4l2/rpi5_scripts ./media_setting_rpi5.sh veyecam2mpi@raspberrypi:~ $ cd raspberrypi_v4l2/rpi5_scripts pi@raspberrypi:~/raspberrypi_v4l2/rpi5_scripts $ ./media_setting_rpi5.sh veyecam2m This is a Raspberry Pi 5. camera is YUV type camera name veyecam2m; width 1920; height 1080; media_fmt UYVY8_1X16; pixel_fmt UYVY CAM1 probed: media device is /dev/media2 set CAM1 finish, plese get frame from /dev/video0 and use /dev/v4l-subdev2 for camera setting veyecam2m 6 NOT FOUND pi@raspberrypi:~/raspberrypi_v4l2/rpi5_scripts $
  • IMX-287M: How to synchronize video frame capture with an LED?
    4k Views
    E
    @veye_xumm Okay, thank you very much for the replies.
  • 0 Votes
    10k Views
    F
    [image: 1713706038286-livepushstream_2024-04-21_04.49.41.300_04.49.44.300_%E6%B5%81%E6%98%9F%E6%95%B01.jpg] http://hainanftp.net/lx/LivePushStream_2024-04-21_04.49.41.300_04.49.44.300_流星数1.mp4
  • 树梅派4B 如何搭建RTSP?
    F
    已解决,请访问 https://forum.veye.cc/topic/581/树莓派4b-imx462-ffmpeg-meteor-master-ai-流星监控方案-不断更新
  • 树莓派64位连接CS-MIPI-IMX307问题
    26
    11k Views
    F
    @veye_xumm 楼主,我用的这个微雪的树莓派CM4扩展板, https://www.waveshare.net/wiki/CM4-IO-BASE-A 能麻烦帮我看看么?
  • 树莓派5下MV_IMX287使用mv_mipi_i2c.sh错误
    H
    @veye_xumm 好的,已经解决了感谢
  • veye_mipi_i2c.sh Raspberry Pi 5
    @natzguk Raspberry Pi 5 is special, its i2c bus is 4 and 6. meanwhile, Raspberry Pi need to configure the parameters in advance, please refer to this link below: https://wiki.veye.cc/index.php/V4L2_mode_for_Raspberry_Pi#Raspberry_Pi_5_Setting
  • How to set exposure for IMX-287M?
    @etale_cohomology said in How to set exposure for IMX-287M?: It turns out you must manually select the I2C bus number (I also enabled I2C on raspi-config). Since I'm using CAM0 on RPI5, the bus is 6. Example: ./mv_mipi_i2c.sh -r -f manufacturer -b 6 This works. Yes
  • 树莓派的流模式和硬触发模式
    @lizi 好的。
  • RaspberryPi OS 64-bit
    N
    @veye_xumm For anyone else. This works perfectly. Note that when recompiling on 64-bit Pi, the following warning is produced. It still builds. Just copy the outputs to bin and the scripts work fine. ./make.sh i2c_read.c: In function ‘main’: i2c_read.c:112:35: warning: passing argument 4 of ‘i2c_rd’ from incompatible pointer type [-Wincompatible-pointer-types] 112 | i2c_rd(fd, device_addr,reg_addr, &value, num); | ^~~~~~ | | | unsigned char (*)[512] i2c_read.c:20:68: note: expected ‘unsigned char *’ but argument is of type ‘unsigned char (*)[512]’ 20 | static int i2c_rd(int fd, uint8_t i2c_addr, uint16_t reg, uint8_t *values, uint32_t n)
