    imx462与rk3588无法出图问题
    4 Posts 2 Posters 2.3k Views 1 Watching
    • 乔 Offline
      乔康
      下载官方驱动,移植官方设备树后,可以看到video0到video7.但是所有video都是无法打开,cannot open错误。
      修改驱动以后,可以正常打开,正常出图。
      原驱动中veyecam2m_g_bus_config()函数是屏蔽的,释放以后,并增加pad-id参数,type改为V4L2——MBUS——CSI2_DPHY,即可正常使用。
      同时906行的.get_mbus_config也要释放掉,之前也是注释掉的。
      调试了很久,最终通过修改驱动方式解决了。
      原驱动还少一个break编译无法通过。
      希望别人少走我的弯路。
        veye_xumm @乔康
        @乔康 感谢你的分享。
        这个问题应该还是跟kernel版本有关系。我们开始调的3588的kernel版本不需要veyecam2m_g_bus_config功能。
        总是,驱动调试你们很棒了~👍
        • 乔 Offline
          乔康 @veye_xumm
          @veye_xumm 您好。
          同一块板卡,同样的设备树和摄像头驱动,之前使用的是5.10.66和5.10.106的内核。均推流正常。换成5.10.226的内核后,推流时遇到报错如下。
          root@ema:/home/ema# Setting pipeline to PAUSED ...
          error: XDG_RUNTIME_DIR not set in the environment.
          [ 226.467123] rkcif rkcif-mipi-lvds4: rkcif_alloc_buffer failed ret:-22
          [ 226.467128] rkcif-mipi-lvds4: Failed to allocate the memory for dummy buffer, size 0
          New clock: GstSystemClock
          [ 226.467130] rkcif-mipi-lvds4: Failed to create dummy_buf, -12
          Additional debug info:
          gstv4l2src.c(701): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
          Buffer pool activation failed
          Execution ended after 0:00:00.002934167
          Setting pipeline to READY ...
          Setting pipeline to NULL ...
          Freeing pipeline ...
          摄像头驱动与设备树详见附件。驱动已经正常启动。
          ema@ema:~$ dmesg | grep veye
          [ 3.884344] veyecam2m 3-003b: veye camera driver version: 00.01.01
          [ 3.884362] veyecam2m 3-003b: Failed to get power-gpios, maybe no use
          [ 3.884385] veyecam2m 3-003b: Failed to get pwdn-gpios, maybe no use
          [ 3.884410] veyecam2m 3-003b: supply avdd not found, using dummy regulator
          [ 3.884459] veyecam2m 3-003b: supply dovdd not found, using dummy regulator
          [ 3.884478] veyecam2m 3-003b: supply dvdd not found, using dummy regulator
          [ 3.884501] veyecam2m 3-003b: Success to get veyecam2m endpoint data lanes, dts uses 2 lanes
          [ 4.008523] veyecam2m 3-003b: camera id is veyecam2m
          [ 4.011133] veyecam2m 3-003b: sensor is IMX462
          [ 4.011153] veyecam2m 3-003b: board type is ONE board
          推流指令“gst-launch-1.0 v4l2src device=/dev/video0 ! \video/x-raw,format=NV12,width=1920,height=1080,framerate=30/1 ! autovideosink&”
          请问驱动需要相应升级吗?报错能看出什么问题吗?
            veye_xumm @乔康
            @乔康
            这个问题我们没有遇到。
            你可以试试直接用v4l2-ctl抓图,看看效果如何?
            https://wiki.veye.cc/index.php/VEYE_CS_Camera_on_Firfly_Boards/zh#.E6.8A.93.E5.8F.96.E5.9B.BE.E7.89.87
