imx462与rk3588无法出图问题
下载官方驱动,移植官方设备树后,可以看到video0到video7.但是所有video都是无法打开,cannot open错误。
修改驱动以后,可以正常打开,正常出图。
原驱动中veyecam2m_g_bus_config()函数是屏蔽的,释放以后,并增加pad-id参数,type改为V4L2——MBUS——CSI2_DPHY,即可正常使用。
同时906行的.get_mbus_config也要释放掉,之前也是注释掉的。
调试了很久,最终通过修改驱动方式解决了。
原驱动还少一个break编译无法通过。
希望别人少走我的弯路。 -
@乔康 感谢你的分享。
这个问题应该还是跟kernel版本有关系。我们开始调的3588的kernel版本不需要veyecam2m_g_bus_config功能。
总是,驱动调试你们很棒了~
@veye_xumm 您好。
同一块板卡,同样的设备树和摄像头驱动,之前使用的是5.10.66和5.10.106的内核。均推流正常。换成5.10.226的内核后,推流时遇到报错如下。
root@ema:/home/ema# Setting pipeline to PAUSED ...
error: XDG_RUNTIME_DIR not set in the environment.
[ 226.467123] rkcif rkcif-mipi-lvds4: rkcif_alloc_buffer failed ret:-22
[ 226.467128] rkcif-mipi-lvds4: Failed to allocate the memory for dummy buffer, size 0
New clock: GstSystemClock
[ 226.467130] rkcif-mipi-lvds4: Failed to create dummy_buf, -12
Additional debug info:
gstv4l2src.c(701): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Buffer pool activation failed
Execution ended after 0:00:00.002934167
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...摄像头驱动与设备树详见附件。驱动已经正常启动。
ema@ema:~$ dmesg | grep veye
[ 3.884344] veyecam2m 3-003b: veye camera driver version: 00.01.01
[ 3.884362] veyecam2m 3-003b: Failed to get power-gpios, maybe no use
[ 3.884385] veyecam2m 3-003b: Failed to get pwdn-gpios, maybe no use
[ 3.884410] veyecam2m 3-003b: supply avdd not found, using dummy regulator
[ 3.884459] veyecam2m 3-003b: supply dovdd not found, using dummy regulator
[ 3.884478] veyecam2m 3-003b: supply dvdd not found, using dummy regulator
[ 3.884501] veyecam2m 3-003b: Success to get veyecam2m endpoint data lanes, dts uses 2 lanes
[ 4.008523] veyecam2m 3-003b: camera id is veyecam2m
[ 4.011133] veyecam2m 3-003b: sensor is IMX462
[ 4.011153] veyecam2m 3-003b: board type is ONE board推流指令“gst-launch-1.0 v4l2src device=/dev/video0 ! \video/x-raw,format=NV12,width=1920,height=1080,framerate=30/1 ! autovideosink&”
请问驱动需要相应升级吗?报错能看出什么问题吗?
@乔康
这个问题我们没有遇到。
你可以试试直接用v4l2-ctl抓图,看看效果如何?
https://wiki.veye.cc/index.php/VEYE_CS_Camera_on_Firfly_Boards/zh#.E6.8A.93.E5.8F.96.E5.9B.BE.E7.89.87
